Question about NEC Galileo 845GL (N4-IBFGL) Motherboard
Intel 845 GL mother board no display ;processor memory & SMPS are working fine in another mother board
  • rkrishnakuma Sep 07, 2010
    Details : The Processor;Memory;SMPS
  • 166 Answers
Does it have any beep sounds on switching on( some computers won't produce beep sound) or does your monitor is not getting any signals from computer even though it is ON and has shown any message or menu screen of Monitor functions then,
You will be having a faulty RAM or your Graphic port has some hardware malfunction.Or it can be also from a new unsupported hardware installation that will prevent computer from booting up.
If your monitor does not provide any of the above monitor functions successfully then
It would be a monitor problem. Check wires or cables of monitors or contact nearby technical support
Posted on Sep 06, 2010
  • Deep_003 Apr 25, 2011
    Plz give beter salution
Every thing is working fine but no display as i changed the display & also checked the same display on another set it is working ok changed display ic but still same problem
Power off your computer and remove the smps 24 pin connector to the motherboard and short the green and black pin and see if the SMPS is working if not replace the smps.
Remove memory from the memory slot and switch on the computer if you hear beeps clean the memory or change it with new one that fixes the memory slot
If no beeps by removing the memory then remove the processor fan and clean it with soft cloth and apply thin layer of heat sink compound and switch on the computer
If you still not hear the beeps then change the processor
If still no beeps take the motherboard to a chip level Technion the secondary power supply or the clock,reset etc in the mother board has gone wrong or not producing them
Apr 01, 2011 | Computers & Internet
I brought a new Intel H55Tc Mother board, Core i3 Processor, 2GB DDR3 Ram. Now my system fan and smps fans spindling is not continue. But My SMPS is working well with other mother board.
Dear vijay, Please check your power ic of mother board there is problem. When you change it then your cpu and processor fan will be working.
Thanks. Rakesh.
Nov 26, 2010 | Intel H55TC Motherboard Core i5 650...
NO Post, No Display & No Beep. I have an MSI 045GCM5-F V2 Mother Board & Intel Core 2 Duo Processor. Plz help.
That is a symptom of burned SMPS or RAM. Try to replace SMPS only cost worth about 20$
Jul 29, 2010 | MSI 945GCM5 Motherboard
I have assembled PC with Intel P4 boxed processor & Intel 845 GV moteher board.Now it is not not working.There is no display & PC is not booting.I refered to local technician but he is telling that...
you have to take you pc to a pc specialist who will check the problem and notify you of what has to be don whether replacements or just a small error that can be fixed.
good luck.
wonder
Oct 08, 2009 | Intel D845GBV (BOXD845GBVL) Motherboard
Display driver for intel 845 board
http://www.soft32.com/download_173342.html
Jan 22, 2009 | Intel Computers & Internet
Asus 845 chipset pb4 mother board not starting
it may be the circuit problem,inside the mother board.send it to service center
Jan 16, 2009 | ASUS Intel 845 Chipset P4B (P4B WOA)...
Intel 845 GVSR
90% in d845gvsr cpu dry problem , when we press fan after that swicth on the system may be it's giving display solution is bake cpu socket at 200 digree C, after it's working fine otherwise there is no solution. cpu socket problem like hang, restart, some time display , just bake the cpu socket with hot air gun or bga machine,
Nov 11, 2007 | Intel Motherboard
Ram support for intel 845 motherboard
Ok. So you've defined the Intel 845 chipset on your motherboard.
But is it the 845 or 845G chipset?
Click HERE for the specifications of the Intel 845 chipset.
Click HERE for the specifications of the Intel 845G chipset.
Peepnklown is only HALF right.
The Intel 845 chipset does NOT support PC133 memory.
The Intel 845G chipset DOES support both DDR and PC133 memory.
The difference?
The 845 has a single memory controller for DDR memory.
The 845G has two memory controllers. One for DDR and one for PC133.
Although you're going to need DDR memory as it is FASTER and less expensive than the older PC133 memory. (Believe it or not.)
I do NOT recommend using Corsair's ValuSelect memory on this chipset. I have two boards with the 845G chipset and that type of memory does not allow the board to boot.
These boards typically come with DDR266 (PC2100) modules installed.
I would go ahead and buy DDR333 (PC2700) memory for it. The board you have may not utilize the full speed of that memory, but will use tighter memory timings if the RAM is clocked down by the board. This will result in better efficiency of memory use by the processor.
Think of it as giving the motherboard "breathing room".
I could recommend PNY memory for the most basic compatability. (Not that they manufacture their own RAM modules...) Or perhaps Nanya, Infineon or Microtek.
Look for memory compatability lists for your particular motherboard module online. You could also use PNY's memory configurator on their website.
Click HERE for PNY's memory configurator.
Good luck.
Cyryl
Nov 10, 2007 | Intel Motherboard
NEC Galileo 845GL (N4-IBFGL) Motherboard Logo
150 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
