Where to change the filter for carrier model fa4anf030?
Carrier model FCBNF030 where is the filter located in the unit?
There may not be one. Most filter messages on a thermostat go by accumilated run time. They are just a reminder and the thermostat message has to be reset. If its there it would be at the unit inlet were the return plenum connects to the unit. They dont usually have both if you have filters in the return grills you dont need them at the unit.
Jan 13, 2014 | Carrier Heating & Cooling
Carrier fa4anf030
Sounds like the reversing valve is the problem
The reversing valve is located near the compressor
It has four copper tubes coming from it
On this valve there is a solenoid which makes the valve open or close
You can check this by placing a strong magnet on it while the system is running which will activate or de activate the heating
You should hear a swoshing sound if it's working properly each time you remove the magnet if this doesn't happen it will need to be replaced by a licensed refrigeration technician if it does work you may have a gas leak which will require a friggy as well
Jan 04, 2014 | Carrier Computers & Internet
CARRIER FILTER FOR MODEL FA4BNF030
I can't find a filter to fit my Carrier air conditioner it needs 16 1/2x21 5/8x1 where can I find this can you please help, thank you
Jun 25, 2012 | Carrier Heating & Cooling
Carrier HVAC model 58sta090 filter size?
Carrier Furnace Model 58STA090-16120 (58STA09016120 ...
www.repairclinic.com/.../Model-58STA09016120-Carrier-Furnace-Filter...
Carrier Furnace Model 58STA090-16120 (58STA09016120) Filter Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Carrier HVAC model 58sta090 filter size? - Fixya
www.fixya.com/.../t11662616-carrier_hvac_model_58sta090_filter_size
Feb 12, 2012 - Carrier HVAC model 58sta090 filter size? - Air Conditioners ... Main house central air? = 3 tons ... I assume the filter goes in at the bottom of the air ...
CARRIER Base 80 Furnaces
Feb 12, 2012 | Heating & Cooling
How do you re-set error code for "change filter" when filter has been changed on Carrier programmlbe thermostat
Clean Filter Feature -
The thermostat will display the CLEAN FILTER indicator when it is time to change the filter. Press the Reset Filter button to restart the timer after the filter has been changed or cleaned. Helpful?
Dec 28, 2010 | Carrier TSTATHCP Programmable Thermostat...
I cannot find the model number on an older model Carrier Air
you should be able to remove the front cover and access the filters and a date sticker that tells the model no. The filters are likely to be reusable filters instead of disposable.
The covers of those through the wall systems are held on with clips or clips and hooks.
They can typically be removed by two methods.
1) pull the bottom out and then lift up and out.
2) lift the cover straight up and then pull out.
Some units have the filter mounted to the unit, others have it mounted to the inside of the cover.
Aug 29, 2009 | Carrier KCA101P Air Conditioner
AC blower runs but compressor will not.
It could be the CONTACTOR. It could be dirty and when the system calls to run, the contactor won't make contact and complete the circuit. Worse case scenario, compressor is siezed up. If you hear a clicking noise at the condensing unit where the compressor is located, that could be the overload protector clicking and breaking the circuit if the compressor is seized up. Good luck. I hope it is a contactor or a capacitor.
May 31, 2009 | Heating & Cooling
Intermittent heat
It sounds like the unit has lost its first stage of Heat (It uses the outside unit to bring heat in with freon) When the thermostat is put 3deg higher than room temp it uses Heat Pump and heat strips, this is probably the only time yours heats. Have it checked as you will pay a lot on next month's electric bill.
Jan 19, 2008 | Heating & Cooling
Carrier RADCO unit FA4ANF030
the best thing to use is any alkaline base with water
Aug 16, 2006 | Carrier IBM UNIT 2380 79F4796 Drive Case
Heating & Cooling Logo
278 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
