Question about Whirlpool Washing Machines
The (model no LSQ9110PWO) washer motor will run, but will not spin. It is a direct-drive motor. We think it is the clutch. Do we order a clutch kit or brake drive tube or basket drive Kit???
  • 61 Answers
Here's a link for your model with a parts break down. Looks like what you need is in diagram #5. Not sure I can use live links so replace the "x"s with a "h" in the beginning of the address.
hxxp://www.appliancepartspros.com/partsearch/model.aspx?model_id=5152738&diagram_id=950815#d950815
Posted on Sep 06, 2010
Washer fills with water as usual then it will try to agitate and spin at same time.
WASHER SPINS AND AGITATES AT SAME TIME:
( Belt drive) I SUSPECT YOU HAVE A BAD TRANSMISSION SPRING ITS NOT THAT EXPENSIVE OR DIFFICULT TO FIX. YOU CAN INSPECT IT BY TURNING MACHINE ON ITS SIDE AND LOOKING AT THE TRANSMISSION SPINDLE, SHOULD BE LOCATED UNDER THE PULLEY WHEELS AND MOTOR ( ON BELT DRIVE MODELS). U WILL NOTICE A SPRING ABOUT 2-3 INCHES LONG GOING AROUND THE SPINDLE IT SHOULD ALL BE ONE PIECE IF IYTS BROKEN OR CRACKED ETC IT NEEDS REPLACING. -
Another thing to Check is the wig/wag solenoid also in some models. The cam shaft may have slid and broken away from wig wag solenoid
( Direct drive) a simple way of determining with spin or agitate problem is with your washer's transmission (also called a gearcase) or some other part like a clutch or a drive motor coupler. And usually the problem is in the transmission itself in direct drive models. When it comes to spin and agitate at same time.
your next step is toremove the cabinetand jumper the lid switch harness (tan to gray). Put the unit in spin and watch the shiny metal clutch disc that is on top of the transmission where the shaft comes out. If the machine starts and runs in spin, check to see if the disc is spinning. If it is, then the problem isnot in the gearcase- look for trouble in theclutch(see the "Clutch" section below),basket driveor thetub drive block(see the "Drive Block" section below).
If, on the other hand, the disc is NOT spinning, check for a problem withthe motor drive coupleror one of its retainers. This washer doesn't have a belt. Instead, the motor is directly coupled to the gearcase by a drive coupler; that's why it's called a direct drive washer. BTW, replacing the motor coupler is probably the single most common repair on this washer.
Read more:Diagnosing and Repairing Spin and Agitate Problems in a Whirlpool / Kenmore Direct Drive Washerhttp://fixitnow.com/wp/2010/07/07/diagnosing-and-repairing-spin-and-agitate-problems-in-a-whirlpool-kenmore-direct-drive-washer/#ixzz3XW7eZwiNBy the way my advice is free cuz God is good!
Apr 13, 2017 | Washing Machines
My Inglis by Whirlpool washer doesnt spin. Its a Direct drive unit so Im guessing that the clutch is bad?
does the motor run when its supposed to spin? if not its probebly a lid swich problem. if the motor runs it may be a coupler or poss. cluch. sometimes a sock in between the tubs.
May 07, 2014 | Whirlpool Inglis IP4400 Washer
Kenmore Direct Drive Washer Slow Spin 11023812100
there is a switch on the motor check the wiring make sure it is working
Apr 05, 2014 | Kenmore Washing Machines
The machine doesn't spin properly and doesn't drain the water
see this causes and fix it. God bless you
Lid Switch Assembly If the washer won't spin the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Motor Coupling If the washer won't spin the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission. Another common problem is the lid switch.
Drive Belt If the washer won't spin, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin properly.
Door Lock Motor and Switch Assembly If the washer spin the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Drive Block If the washer won't spin the drive block might be worn out or may have come loose. Underneath the agitator the drive block connects the inner tub (the one that spins around) to the transmission. If the drive block wears out the transmission shaft will still spin but the tub may not - or it may spin slowly. This also usually causes a lot of noise. The drive block is relatively easy to replace.
Clutch Assembly If the washer won't spin, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Clutch Band kit If the washer won't spin, the clutch band kit might be worn out. The clutch makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. If the washer won't spin, this clutch band kit may need to be replaced.
Drive Motor If the washer won't spin the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged It will have to be replaced.
Tub Bearing If the washer won't spin the tub bearing might have seized. This is a common problem and relatively easy to replace.
Tub Seal and Bearing Kit If the washer won't spin the tub seal and bearing might have seized. This is a common problem and relatively easy to replace.
Bearing If the washer won't spin the bearing might have seized. This is not common. The bearing doesn't require any normal maintenance. They generally go bad when the tub seal fails and allows water to leak past into the bearing.
Basket Drive If the washer won't spin the basket drive clutch might be worn out. The basket drive sits on top of the transmission and engages with the inner tub. If the basket drive wears out the tub won't spin.
Basket Drive Hub Kit If the washer won't spin the basket drive hub might be worn out. The hub is a set of plastic gears underneath the agitator. The basket drive hub kit is easy to replace with standard hand tools.
Transmission If the washer won't spin the transmission might be worn out or defective. There are numerous more likely causes when a washer won't spin, which should be checked first.
Sep 28, 2012 | Hotpoint Washing Machines
Does not spin as well as it used to. Towels and clothes used to come out almost dry and now they do not.
Drive motors are often a source of trouble. These motors often run in forward and reverse. They spin one way to agitate and the other to spin. Just because it works in one direction, does not mean that the other direction cannot be burnt out. This often happens and just because ?it works? people think the motor is okay. The motor still needs to be replaced if either direction goes bad.
GE and Whirlpool manufactured washers use a clutch system. This slowly bring the spin cycle up to speed as the water goes out of the washer. When this becomes worn the spin will not be as fast or may not spin at all. If your clutch needs to be replaced, you may want to hire that out as it is quite a project for most DIY?ers.
The final problem would be the bearing or basket drive. This gets worn or even will get tight so that the basket will not spin freely. If this goes bad you will usually have excessive noise when the washer spins. This too is a project that you may want help with.
As you can see there are many things that can go wrong to make problems with the spin cycle of a washer. You will have to do some detective work to figure out exactly what the problem is with your washing machine.
If you found this helpful please leave a thumbs up
Jan 07, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
GE washer, a little over 2yrs old - washer will fill, agitate, and drain, but will not go through the spin cycle.
GE manufactured washers use a clutch system. This slowly bring the spin cycle up to speed as the water goes out of the washer. When this becomes worn the spin will not be as fast or may not spin at all. If your clutch needs to be replaced, you may want to hire that out as it is quite a project for most DIY?ers.
Jan 07, 2011 | Washing Machines
My washer will spin but very slowly. Motor and shaft spins out of washer.
Your problem sounds like the drum/tub drive clutch is worn. Especially if the motor operates fine and attempts to spin the tub. This model is a direct drive unit, no belts, so if the motor operates during the spin and drain cycles but the tub is barely moving, only two problems can cause this, bad clutch (which is engaged only during the spin cycles) or worn drive coupling on the motor. If the coupling were a problem, though, you would also notice sluggish or erratic agitation during the wash cycle.
Hope this helps
kcomp1863
Jan 04, 2011 | Roper RAS6233KQ Top Load Washer
I have a kenmore 11023812100. no spin. bypassed lid switch and still no spin. does this model have any belts that could be loose? thanks, Gordon
Hi Gordon and welcome to FixYa I am Kelly. Your washer is direct drive for both agitation and spin. There is a centrifugal clutch for spin. If the motor is running and the unit is pumping out water then the clutch lining has failed.
See Item 6 this link:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11023812100/0582/0153200/P0111056/00005?blt=06&prst=&shdMod=
It can also be the motor coupling.
See this link under it pumps but doesn't spin:
http://www.repairclinic.com/Washing-Machine-Troubleshooting#Itdoesntspin
The video is a how to replace the clutch lining.
Thanks for choosing FixYa.
Kelly
Sep 27, 2010 | Kenmore 24642 Top Load Washer
My matag washing machine will spin but not agitate
It doesn't agitate If your washer doesn't agitate, check these: Lid switch Motor coupler Belts Clutch Drive motor Drive pulleys Transmission Agitator Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it. Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Feb 01, 2010 | Maytag Performa PAV3200
Washer will not spin
Tip the washer and try to turn the transmission pulley by hand counter clockwise.
If the pulley will not turn you likely have a seized drum bearing.
since your washer pumps out the water but doesn't spin, check these:
* The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
* The motor coupler may be broken. Most washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
* A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
* The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
* The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
* The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
* The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle.
Sep 09, 2008 | GE WSXH208A Front Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Sal De
