Question about Braun K 600 CombiMax Food Processor
Processor went "bang" and stopped operating. - Braun K 600 CombiMax Food Processor
  • 17,129 Answers
Check after opening if the motor has paccked up. Check the drive if it has jammed, check if the motor bushes are bad, the brushes are worn out.
Trace power line from plugg to switch and to the motor.
If there is atrip switch in between this see if this has reset.
Posted on Sep 06, 2010
Can I change the plastic motor spindle on a magimix 5100?
Yes you can, you can "cut" it off with a soldering iron by melting a slot down one side. When banging a new one on you need to remove the base and suppert the bottom of the shaft with something solid underneath it. The whole motor assembly will be sitting on this as you bang the new sleeve on with a soft mallet. If you don't there is a danger you will wreck the motor and you cannot afford to replace that bit.
Aug 29, 2014 | Magimix 5100 Cuisine Systeme Food...
Magimix 5100
The food processor stops working after use. I know there is a reset "hole" to make it start again. I can't see where it is and cannot find it in the manual. Please tell me where it is so I can...
Not all food processor have a reset button, some don't have. You have to be make sure that the unit is in fit, suited because it will on the interlock switch (the safety switch) before it operates normally.
I hope I give you idea regarding your food processor problem.
Mar 27, 2011 | Cuisinart DFP-14BC Custom Food Processor
How to use my food processor I have had it for a couple of years and never have used it Bravetti Platinum Pro Quad Blade 6 Cups Food Processor
I went to my user manuals sites and they did not list this brand.
the internet indicated the problem with this food processor was the inability to obtain parts. I advise keeping an eye on ebay if you need something in particular.
(if this has been helpful, please give me positive feedback)
May 28, 2010 | Bravetti Platinum Pro Quad-Blade Food...
4 speed food processor manual
I am like you - I have been given a food processor of this model, and I've never operated one before in my life. Here's the site I used to find the manual. Hope it helps!
http://kitchen.manualsonline.com/manuals/mfg/ge_appliances/106622.html?idRes=15555248
May 22, 2010 | GE 106622F Food Processor
I have a small Cuisinart food processor and I cannot figure out how to turn it on. It has two levers low and high. I have it plugged in and the lid on? Please help. Fiona Slattery 858-752-8591
Your PowerBlend Duet™ comes with a food processor button. This button is the perfect speed for all your food processing tasks. Always use this speed when using the food processor. You may also use the Pulse button with this function for pulse-chopping.
To use your food processor, make sure that the bowl is assembled properly and the blade or slicing/shredding disc and the cover are locked into place.
When you use the control panel, the LED will light next to each button you press.
Press the On button. For continuous operation, press the Food Processor button. Motor will start if you have followed assembly instructions.
To turn motor off, press the Food Processor button again or the Off button.
For on/off operation, called pulse-chopping or pulsing, press the On button, press the Pulse button, and then press and release the
Food Processor button the desired number of times. Motor runs as long as you hold the Food Processor button down. The motor stops when you release control switch. Try it a few times.
You control the duration and frequency of pulses by the length of time you hold the Food Processor button down and the rate at which you press it. Pulses should be short bursts. Allow enough time between pulses to let food in work bowl fall to bottom.
Always use the Food Processor button for pulse/chopping. Never turn cover back and forth to start and stop processor.
You can download manual from the below link
http://www.cuisinart.com/share/pdf/manuals/bfp-10ch.pdf
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 12, 2009 | Cuisinart Food Processors
I went through the same thing...as it turns out, everything was locked into place but I had the handle in the back rather than the front where the sensor is. Good luck. I hope that helps you.
Nov 03, 2007 | Cuisinart DLC-2011 PowerPrep Plus Food...
It just stopped working
Remove the work bowl from the base of the food processor, and separate the bowl, lid, and pusher sleeve.
Plug the base into the wall outlet, turn the food processor ON, and then use a pen to press in the dark grey or black button on top of the base of the food processor - if you hear some kind of noise, then your motor is still good.
Put the work bowl on first, with the handle facing the front of the food processor.
Put the lid on, with the hollow feed tube facing the back of the processor.
Put the pusher sleeve in the lid, with the sliding lock switch facing the front of the processor.
Your processor should now turn on.
If your food processor still does not turn on, call Cuisinart and see if you are eligible for an in-warranty repair - it has a 3-year warranty.
-Tha Mp3 Doctor (also loves Cuisinart)
Oct 29, 2007 | Cuisinart DLC-10S Pro Classic Food...
My food processor just stopped working?
A Cuisinart food processor doesn't start before the top is assembled properly, that is a safety feature. Their strong motors can withstand also hard to cut ingredients.
Aug 27, 2007 | Cuisinart DFP-14BC Custom Food Processor
Braun K 600 CombiMax Food Processor Logo
103 people viewed this question
Top Braun Food Processors Experts
eyecam
Ashutosh Khandelwal
Level 1 Expert
Are you a Braun Food Processor Expert? Answer questions, earn points and help others
