Question about Sony VAIO FXA36 Notebook
How to replace backlight
My screen is dark, but with a strong light, I can see the image. So I'd like to replace the backlight but haven't figured out the mechanics of accessing it. Can't locate the screws to disassemble it.
Help appreciated.
Thanks
Paul
  • Marc Menzies May 11, 2010
    tell me the type of computer and I will find you the service manual
    Genius:
  • 1,554 Answers
It is not likely the backlight but the inverter as they blow most often.
it is also inside the lcd panel. it provides dc to high voltage to the lamps.
easy to find on ebay usually.
you will likely see some plastic dots around the frame , remove them and the screws are behind them.
other versions of frames just clip on and you have to insert your finger along the inside edge of the bezel plastic trim and pull it toward you and away from the edges to un-clip
don't put pressure on the lcd as you do this as it can leave marks.
once you get an edge loose you have to work your way around without breaking the snap clips.
Posted on May 13, 2008
What should I replace next, I have a samsung lcd with no backlights but picture shows with a flashlight in a dark room.
sir,
even if you changed the back light inverter the fault remain as same, it seems to be the back light LED is damaged carefully remove the outer frame of the panel then dis connect the LCD then remove the frame of the defuser screen , take out plug your TV, check the LEDs
Feb 15, 2016 | Samsung LN46E550 46 inch LCD HDTV 1080p...
My wife's presario cq60 widescreen laptop has a power problem. For a period of time now, several weeks, on occasion it will simply go dark and nothing lights up. I remove the battery and power cord...
By go dark do you mean it turns off? If not, LED lights on the front of the laptop continue to stay on, but the screen goes dark, this could mean the backlight of the screen is going bad. It might be intermittent, but, a screen consists of two elements, the display itself, and the backlight which is what makes the image bright. If you bring it into a well lit area when it is dark and tilt the screen back and forth, you might see the faint image on the screen. Sadly, screen repairs are expensive, easily exceeding $300 most of the time. It is often a better idea to replace it rather than repair it.
Aug 24, 2011 | Compaq Presario CQ60-220US PC Laptop
Will not retain screen image. Flashes the content when you push the on/off button and is clearly projecting data, but just in flashes.
It appears you may have a bad backlight. If you can see the picture content with a strong light shining at an angle to the screen while it is dark, then it is definitely the backlight. Most sets shut down shortly after getting a failure signal from the backlight inverter although you do not mention that happening.
The backlight uses two or more Cold Cathode Fluorescent Lamp (CCFL) tubes, and they'll have the same flickering as a failing standard fluorescent tube. If the light has a pinkish cast to it, this is a common sign that one or both of the tubes is bad. You may see the flashing on the top or the bottom and the other half of the screen will be dark; this means one tube is dead and the other is dying.
May 24, 2011 | Sony SDM-HS73P 17" LCD Monitor
Screen keeps t going blank but still have power
It may be the internal backlight that is failing. When the display has failed but still has power, take a flashlight and hold it close to the screen, move the flashlight all around the screen and check if you can see anything. The display will be dark, but you should be able to make out the image that is there with the flashlight technique. If you can see an image on-screen, then your backlight has failed and you will need to replace the monitor. Weather or not you see an image is not a critical issue, but a tool to verify if the backlight is off or some other issue is causing the problem.
Note, it may be difficult to detect an image on the un-light display, for example if you have a dark image as your desktop background. So make sure to fully scan your display (top to bottom, and left to right covering the entire screen) with the flashlight technique in order to see any image on-screen.
Mar 24, 2011 | Xerox XG-91D 19" LCD Monitor
My proview 19 in turn on but then it goes black is it a capasitor and how to fix it or is ther a reset on it
It may be the internal backlight that is failing. You can take a flashlight and hold it close to the screen, move the flashlight all around the screen and check if you can see anything. The display will be dark, but you should be able to make out the image that is there with the flashlight technique. If you can see an image on-screen, then your backlight has failed and you will need to replace the monitor. Weather or not you see an image is not a critical issue, but a tool to verify if the backlight is off or some other issue is causing the problem.
Mar 22, 2011 | Proview PL926WBi 19" LCD Monitor
My brightness control does not work just turned on and can not hardly see anything it is up and running what now
Have you tested it with an external monitor?
I would say you either have a damaged inverter board or screen baclight lamp. Usually the inverter board fails in one of the following ways:
1. When you turn on the laptop, the screen lights up for a short period of time and then goes dark. You still can see an image but it is very dark, almost invisible and definitely not usable. When you restart the laptop, the screen lights up and then goes dark again. The laptop works fine with an external monitor.
2. Your laptop turns on but the screen remains dark all the time. You still can see a very dim image outline. The laptop works fine with an external monitor.
3. The laptop screen works fine for hours or even days, but sometimes it goes very dark as it mentioned above. When you restart the laptop, the screen works fine again.
Inverter failure symptoms are very similar to backlight lamp failure symptoms and in most cases you cannot tell which one is causing the problem until you replace either the inverter board or the backlight lamp. From my personal experience, inverter boards fail more often than backlight lamps. If you have to guess, replace the inverter first.
Mar 24, 2010 | Dell Inspiron 1545 Notebook
Screen is dark or dead on my 17" Macbook Pro
This could be a backlight issue, a board issue or an inverter issue. Look at the screen closely, if there is a faint image it's either a backlight issue or inverter issue. To weed out between the two you can just order on inverter, they're 20 bucks on ebay, if that doesn't work, replace the backlight. Backlight repairs are somewhat difficult. As much as I would like to be able to tell you a quickfix that will solve backlight the problem, you'll most likely have to google for guides that show you exactly how to replace the backlight or bring it in for repairs.I work for Mac Repair NYC and i have to fix this problem a lot.
May 21, 2009 | Apple MacBook Pro Notebook
Acer 6930 won't light?
You could have an inverter problem, it supplies high voltage to the CCFL backlight lamp or you have a faulty CCFL lamp.
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a very dim image or flicking image on the LCD screen it means you have a backlight problem.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 18, 2009 | Acer Aspire 6930-6455 Notebook PC
Dark Screen Inspiron 9100
If you replaced the inverter board and its still dark you need and new backlight itself http://cgi.ebay.com/LCD-Backlight-Lamp-for-Dell-Inspiron-9100-15-4-WXGA_W0QQitemZ150217509448QQcmdZViewItem
Dec 10, 2008 | Dell Inspiron 9100 Notebook
Sharp Actius A250 PC: Can the screen be replaced?
I'm a laptop technician and this is a very common fault. It sounds like the backlight or invertor for the laptop screen has failed.
The easy way to check this is to plug the laptop into a normal PC monitor (if you can) via the monitor out port on the laptop - you may have to press Ctrl + F5 to get a display on the PC screen. If you can get the laptop to show an image on the PC screen then the main laptop itself is fine, and the problem is almost certainly a failed invertor or backlight.
Assuming you *could* see an image on the PC screen, you should then press Ctrl + F5 so that you *can't* see an image on the PC screen any more (this is very important). Next unplug the laptop from the PC monitor (if you did the above) and look VERY closely at the laptop screen. You will hopefully *just* make out a very, very feint and very dark image on the laptop screen. Bear in mind that you may need to re-boot the laptop to get a moving image that you can detect (like the Windows boot up screen for example). If you *can* see a very, very dark and feint image on the screen then the backlight has failed. If the screen is plain bright white or there is no image then the invertor has gone.
The invertor is a smaller circuit board that sits in the screen housing, the backlight is a very thin "flourescent" kind of tube light that is built into the screen itself. The invertor can be removed and replaced pretty easily by most competent people without much trouble (takes maybe 30-45 minutes to do). The backlight on the other hand is very hard to remove without damaging the screen itself and should only be attempted by a specialist laptop repair company.
I hope this helps.
May 20, 2008 | Sharp Actius A250 Notebook
Sony VAIO FXA36 Notebook Logo
82 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
