Question about Vacuums
I have lost my manual for my ZEON TECH translator and don't know how to change the time and date.
HELLO MY CLOCK DID NOT DO AUTO DAYLIGHT TIME HOW DO I FIX THE TIME TO ADJUST TO ONE HOUR A HEAD THANK YOU INGER WELCH
All you need to do to advance your clock an hour for daylight savings time, is hold down your clock button without letting it go. Then press your hour button once and you should be all set.
Most clocks that are older than when they changed the date of daylight savings time will either not change it for you on the right day anymore. Or they don't have that feature in it.
If yours does have an automatic daylight savings feature...you may find it helpful to take it off "automatic" and just change it manually from now on. That's what I do with my VCR. It has an automatic daylight savings time feature, but it's useless now that they have changed the date when we set our clocks for DST.
Some manufacturers will give you instructions on how to change the feature settings so your product will again work correctly for you. But not all will or can. You can look it up at your manufacturers website to know for sure.
Good Luck...and I hope this helps you.
Mar 13, 2011 | Vacuums
I have a Sio/Scan Atomic Clock that gives time, indoor and outdoor temp. I have lost the instruction manuel and cannot set time or date since I changed batteries. CN5 V00 U Can you help me?
The Sio/Scan Atomic clocks should automatically set the time and date.
Place the clock in a window facing towards Colorado and give it 24 hrs to update
If that fails here's the web site for them:
http://www.skyscaninfo.com/content/manuals.html
Jan 03, 2011 | Vacuums
How do you work it?
below is a website to retreive a free manual for yours. have the model number ready so you can find it much easier....
bye.
http://homeappliance.manualsonline.com/manuals/mfg/bissell/bissell_vacuum_cleaner_product_list.html
Feb 07, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Manual
http://geeksquad.fixya.com/ThreadView.aspx?prdid=83399&thid=768341
Manual
Posted by sarpent_8 on Jul 11, 2008
I have a Bagless Stick Shark, Model EP601, and production date - 28/02.
I have misplaced my manual and don't know how to attach the hose and attachments. HELP! Margaret sarpent_8@msn.com
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The best way to get an owner’s manual is to contact the Shark factory of which I will supply the website address and cust serv phone # so you can either download a owner’s manual or they can mail you a owner’s manual from the factory. Please include the brand name and model # of your vacuum. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.sharkvac.com/ Customer Tech Support 1-800-798-7398
These are the other brands that use the same tech support line
Shark / Euro-Pro / Infinity / Bravetti / and Fantom
Hours are Monday thru Saturday from 9:00 AM to 6:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 11, 2008 | Euro-Pro V1828 Shark Stick Vac Bagless...
I need to replace the belt on my vaccum. I lost my manual.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=698951
Generic problem for all Vacuums
Posted by 4eversofia on Jun 23, 2008
I need to replace the belt on my vacuum. I lost my manual.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. In order to change your belt I would need to know the brand name and the model # in order to give you the correct information to change your belt, so a little bit more information needed as to what you have and then I can direct you in the belt change. Normally there are screws in the bottom of the vacuum and once you remove the screws or clips you can either change it from the bottom or the top cover will lift off and then you can get @ the belt from the top.The average and recommended belt change for a flat belt is every 4 to 6 months and if you have a geared belt it is once a year for the best cleaning. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Go Ahead. Use Us.
Jun 23, 2008 | Vacuums
DONT KNOW HOW TO CHANGE MY BELT
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=698891
Posted by mommyhop1 on Jun 23, 2008
I LOST MY MANUAL TO SEE HOW TO CHANGE MY BELT. TRYING TO FIND THE USERS MANUAL FOR MY ELECTROLUX 3500 SR
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The best way to get the owner’s manual is to contact the Electrolux factory and either download the owners manual from the website or call the customer service phone # and give them the model and serial # of the machine and they will send you out an owners manual for the product. Or you can contact your local vacuum cleaner dealer in your area and they would assist you in changing your belt. Usually there are screws in the bottom of the vacuum and either the bottom will come off or the top cover will lift off and then you can change the belt. The average and recommended belt change for a flat belt is every 4 to 6 months and if you have a geared belt it is once a year for the best cleaning. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Go Ahead. Use Us.
Vacuums Logo
139 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
