Maytag 15.6 cu. ft. Upright Freezer MQU1656B Logo
Posted on Sep 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MY FREEZER5 ALARM GOES OFF BUT THE FREEZER IS RUNN[NG AND THE TEMP IS 32 o
Level 3:
  • Maytag Master 17,130 Answers
  • Posted on Sep 06, 2010
Maytag Master
Level 3:
Answers
17130
Questions
0
Helped
3635236
Points
52372
Fault in the controller board as it must be tripping off the alarm without the sensor giving the signal.
You will need to check the conttroller board for sorting out , other wise just disconnect the alarm as the freezer working and the thermostat is controlling the temperature correctly
Why is the temperature alarm light on, on my freezer Model# FFU21M8CW?
Good Afternoon Friend,
I understand that the temperature alarm light is on for your Frigidaire freezer, model# FFU21M8CW. This feature is designed to provide a warning of a possible malfunction. If the temperature of the food rises to a level unsafe for long-term storage, the buzzer will sound. The red light, if equipped, will also glow. The Temp Alarm feature operates on household electricity. If power fails, the alarm will not function. An ON/OFF switch allows you to deactivate the Temp Alarm when not wanted. Your freezer is shipped with the Temp Alarm in the OFF position. After your freezer has run approximately 4 hours, the red light, if equipped, will go off. Then you may activate the Temp Alarm without the alarm sounding. Press the ON switch to activate the Temp Alarm. To deactivate, press the OFF switch. If the alarm sounds, be sure freezer is properly leveled, and the door closes freely, and seals properly. If you suspect a technical malfunction, call an authorized servicer immediately. Hope this is helpful.
-Best Regards-
WP
I can't turn my Kenmore upright freezer on.
Try disconnecting power for about 30 seconds, and then restore power. This will reboot the control and maybe restart.
Miele F7131 S The red alarm and the orange -32 degrees orange light on the front of my under counter freezer keep flashing. I have defrosted it. It appears cold but the lights will not stop flashing.
Freezer Temp. shoud be 0 to -5 Deg. if to warm it will set off the alarm. try unpluging or turn off power to freezer for 1 or 2 min. to see if it will reset.
May 17, 2010 • Freezers
1helpful
Sears Ken Elite upright freezer model no 25329082991 temp alarm
alarm should go off when freezer reaches minus 18c or lower.
Feb 05, 2010 • Freezers
Low temp alarm goes off on Kenmore upright freezer
The alarm is there for a reason. I wouldn't disconnect it. Maybe the compressor is low on gas. If your thermostat is on extremely low, try moving it up to a less cold position. Look in your owner's manual for recommended settings.
Failing that, get ready to shell out some bucks to the service man!
Freezer Temp Alarm
Temp alarm come on, yet temp (fan blowing and cold air) working. Turn the temp control just a notch up and immediately the temp lite goes out. Later it will start up again. It seems the freezer is working fine, just the temp moritoring system is malfuncting.
Sep 06, 2008 • Freezers
1helpful
Its keeps peeping
Hello twins49
Welcome to Fixya,
You said, your Frigidaire freezer 17 cu. ft. , it keeps buzzing or peeping
The alarm may be malfunctioning or it may be warning you of low temperature.
You can go to any hard ware store and buy a refrigerator thermometer and ask them if it can go into a freezer too!It can, But ask anyway!
If it is cold enough then it is a faulty alarm going off.
Your freezer may be equipped with an alarm.
Here is some information that may help you find it and turn it off if you wish
Temp Alarm (audible only or audible with warning light)
This feature is designed to provide a warning of possible malfunction. If the
sound. The red light will also glow on models so equipped. The Temp Alarm feature
operates on household electricity. If power fails, the alarm will not perform. An ON/
OFF switch allows you to deactivate the Temp Alarm when not wanted. The freezer
is shipped with Temp Alarm in the OFF position. After freezer has run approximately
immediately.
Let me no what you find.
Huuum
Please remember to leave a rating before you leave
Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
1helpful
Frigidaire 25' chest freezer alarm goes off eventhough it is very cold
The temp sensor for the over temp alarm is probably maifunctioning if you are sure that the temp isnt rising
Dec 27, 2007 • Freezers
Top Maytag Freezers Experts
john h
ADMIN Andrew
ADMIN Andrew
vince
Are you a Maytag Freezer Expert? Answer questions, earn points and help others
