Question about Stiga Sport & Outdoor - Others
How do i install the steering cable on a stiga park 2000E
Need wiring diagram for a stiga park 16 hst pro riding mower model13-1441-17 serial 1002087
I would check on the internet and with the manufacturer for your information.
Mar 28, 2016 | Garden
How to fix the linkage on the transmission on 2001 Lincoln navigator
First thing is to get safety glasses,block wheels securely !!...set emergency brake..,get a good flashlight.Disconnect negative battery cable...Some can wear inside the steering column,some can be a worn linkage cable ...The lever on the transmission located under vehicle Trans at lower part of trans,driver side can become loose or possibly damaged...First get under vehicle with safety glasses and observe operation of the lever where shift cable is mounted while assistant puts it in park...make sure the trans shift lever mounting nut is tight before shifting..If assistant can't get it in park use your hand and push forward on the linkage arm and it should go into park manually...If this is the problem you need to change shift cable...Some wear inside the column where steering wheel is mounted..If cab shifter feels very loose ..You will have to remove steering wheel and column cover to inspect."..The cable runs from trans to the steering column..Look between gas and brake pedal and verify cable coming up through floor board and runs to steering column...Double check shifter lever at trans is tight because it is mounted on a splined stud and it can strip the stud threads if it becomes loose..If loose remove lever and inspect splines for damage..Call dealer and make sure they have the part..Remove old cable from trans and put it in park with your hand...Remove and replace cable..Be sure lever inside cab and lever on the trans are both fully engaged into park while cable is removed before installing new cable....Attach new cable.....
Oct 16, 2014 | 2001 Lincoln Navigator
I need to know how to remove the dashboard froma 03 taurus.
SECTION 501-12: Instrument Panel and Console 2003 Taurus/Sable Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 01/21/2004 Instrument Panel adobe.gif Printable View (307 KB) Removal and Installation
  1. Depower the supplemental restraint system (SRS). For additional information, refer to Supplemental Restraint System (SRS) Depowering and Repowering in Section 501-20B.
  1. If equipped with a floor console selector lever, remove the selector lever. For additional information, refer to Section 307-05.
  1. Remove the front door scuff plates.
  1. Position the front door weather-strips aside.
  1. NOTE: When installing the A-pillar trim panels, be sure the alignment tabs are positioned correctly.
    Remove the A-pillar trim panels.
  1. NOTE: Lift upwards on the rear edge of the defroster grille then slide rearward to remove.
    Remove the defroster grille.
    • If equipped, disconnect the sunload/headlamp sensor electrical connector.
  1. Remove the three instrument panel cowl top bolts.
  1. Release the parking brake cable from the parking brake actuator.
    1. Release the cable from the parking brake actuator.
    1. Release the cable conduit from the parking brake actuator.
  1. Remove the parking brake release handle.
    1. Remove the retainer clip.
  1. Disconnect the generic electronic module (GEM) electrical connector.
  1. Loosen the bolts and disconnect the bulkhead electrical connectors.
  1. Loosen the bolt and disconnect the steering column bulkhead electrical connector.
  1. Separate the intermediate shaft from the steering column.
    1. Remove the pinch bolt.
  1. If equipped with a steering column selector lever, disconnect the transmission shift cable.
    1. Disconnect the cable from the steering column shift tube lever.
    1. Disconnect the cable from the steering column bracket.
  1. Remove the pin-type retainers and the passenger side instrument panel insulator.
  1. Disconnect the blower motor, resistor block and blend door actuator jumper harness.
  1. Remove the two instrument panel side finish panels.
  1. Remove the four instrument panel cowl side bolts.
  1. NOTE: This step requires an assistant.
    Remove the instrument panel.
  1. To install, reverse the removal procedure.
2010&c18=modelyear&c20=n147097&c35=wsm%2cinstrument%20panel%2cs3h%2c501-12%2cremoval%20and%20installation&s=1366x768&c=32&j=1.3&v=y&k=y&bw=995&bh=405&ct=lan&hp=n&[aqe]
Mar 07, 2011 | Ford Taurus X Cars & Trucks
Broken shifter cable, how do i repair it
Put park brake on or block wheels, and shift into neutral (if possible), If not go to tranny and pop the cable off the tranny lever (pry off with screwdriver). Turn tranny shift lever, until it clicks twice, leave here for later adjustment. Follow the cable to the adjuster, pull out the flat steel retainer clip, pinch the sides to remove cable from bracket. Remove upper covers below the steering wheel. Remove kick panel below steering colomn. Remove cable from steering wheel shifter assembly (pry off and remove clip same as at tranny). Remove the side kick panel and follow cable along floor. You may find it easier to remove the driver seat (4 nuts on floor and wiring). Pull cable thru floor and replace. Reverse procedure to install. Lock the cable and clip at steering colomn, but leave the clip off at tranny. The tranny should still be in neutral. Now turn key to run and shift the shifter into neutral. At the tranny side cable there is a white square button, press in and lock cable to lever. install retainer clip. move shifter thru ranges and ensure it locks in park. Readjust if needed by pressing button and moving shifter lever on tranny.
Jan 27, 2011 | 1995 Chevrolet Silverado 2500
How to remove a heator core from a 2001 dodge caravan? do you have to take the dash out? or just the bottom pannel.
The 2001 Dodge caravan has 2 heater cores - front (the main one), and the rear. Removal of the
rear heater core is a whole different procedure than the front.
Front Heater Core - Removal and Installation
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Align the wheels in the straight-ahead position.
  3. Disconnect the negative battery cable.
    CAUTION Before working around the steering wheel or the instrument panel all 2 minutes to pass to allow the air bag module to discharge.
  4. Drain the cooling system into a clean container for reuse.
  5. Remove the steering column, by removing or disconnect the following:
    Lower left side steering column cover Parking brake release cable from the parking brake lever 10 steering column cover liner-to-instrument panel bolts and the cover liner
  6. Rotate the key to the LOCK position; then, rotate the steering wheel to the LOCKED position.
    Gear selector cable and its mounting bracket as an assembly from the upper steering column mounting bracket 2 instrument cluster trim bezel-to-instrument panel screws, retaining clips and bezel 2 steering column shroud-to-steering column screws and the shroud Steering column-to-intermediate steering shaft coupler
  7. Loosen but do not remove the 2 lower steering column mounting bracket nuts/washers.
    2 upper steering column mounting bracket nuts/washers Steering column assembly from the vehicle
  8. Remove or disconnect the following:
    Instrument panel-to-chassis harness interconnect and bracket Lower silencer boot, at the base of the steering shaft
  9. Working in the engine compartment, pinch off the heater hoses.
    Heater core cover. Position some towels under the heater core hoses. Heater core plate and the hoses
  10. Depress the heater core retaining clips.
  11. Lift the accelerator pedal and slide the heater core past it.
  12. Depress the brake pedal and remove the heater core from the heater/air conditioning housing assembly.
    Fig. View of the steering column assembly
    Fig. View of the interconnect and bracket
    Fig. View of the front heater core assembly
To install:
  1. Depress the brake pedal and install the heater core into the heater/air conditioning housing assembly.
  2. Lift the accelerator pedal and slide the heater core past it.
  3. Install or connect the following:
    Heater hoses (using new O-rings) and the heater core plate Heater core cover Heater hoses clamps, working in the engine compartment Lower silencer boot at the base of the steering shaft Instrument panel-to-chassis harness interconnect and bracket
  4. Install the steering column assembly by installing or connect the following:
    Steering column assembly, carefully into the vehicle. 2 upper and 2 lower steering column mounting bracket nuts/washers. Torque the nuts to 105 inch lbs. (12 Nm). Steering column-to-intermediate steering shaft coupler and tighten the pinch bolt to 21 ft. lbs. (28 Nm) 2 steering column shroud and the shroud-to-steering column screws Bezel, the retaining clips and the 2 instrument cluster trim bezel-to-instrument panel screws Gear selector cable and its mounting bracket as an assembly to the upper steering column mounting bracket 10 steering column cover liner and the cover liner-to-instrument panel bolts Parking brake release cable to the parking brake lever Lower left side steering column cover. Lower left side steering column cover
  5. Refill the cooling system.
  6. Connect the negative battery cable.
  7. Run the engine to normal operating temperatures; then, check the climate control operation and check for leaks.
Jan 02, 2011 | 2001 Dodge Caravan
How do I change the ignition switch in my 93 plymouth van?
FIRST OF ALL, TURN OFF RADIO,DISCONNECT NEGATIVE BATTERY CABLE. IF EQUIPPED WITH TILT STEERING COLUMN,REMOVE TILT LEVER.CAREFULLY REMOVE THE UPPER AND LOWER STEERING COLUMN COVERS. REMOVE THE 3 TAMPER PROOF TORX IGNITION SWITCH MOUNTING SCREWS USING SNAP ON TOOL TTXR15A2 OR EQUIVALENT. GENTLY PULL THE SWITCH AWAY FROM THE COLUMN AND REMOVE THE 2 ELECTRICAL CONNECTORS FROM THE IGNITION SWITCH. WITH THE KEY IN THE LOCK POSITION, DEPRESS THE KEY CYLINDER RETAINING PIN FLUSH WITH THE KEY CYLINDER SURFACE. ROTATE THE KEY CLOCKWISE TO THE OFF POSITION THE KEY CYLINDER SHOULD NOW BE UNSEATED. ROTATE THE KEY CYLINDER COUNTER CLOCKWISE BACK TO THE LOCK POSITION, AND REMOVE THE LOCK CYLINDER. ( TO INSTALL ) CONNECT THE ELECTRICAL CONNECTORS TO THE IGNITION SWITCH. BE SURE THE CONNECTORS ARE SECURELY LOCKED IN PLACE. MOUNT THE IGNITION SWITCH TO THE COLUMN 3 SCREWS FOR VECHICLES WITH THE TILT STEERING COLUMN THE SHIFTER MUST BE IN THE PARK POSITION AND THE PARK LOCK DOWEL PIN AND THE COLUMN LOCK FLAG MUST BE INDEXED BEFORE THE SWITCH IS INSTALLED. PLACE SHIFTER IN THE PARK POSITION. PLACE THE IGNITION SWITCH IN THE LOCK POSITION. THE SWITCH IS IN THE LOCK POSITION WHEN THE STEERING COLUMN LOCK FLAG IS PARALLEL TO THE IGNITION SWITCH TERMINALS. POSITION THE PARK LOCK DOWEL PIN OF THE IGNITION SWITCH SO IT ENGAGES THE STEERING COLUMN PARK LOCK SLIDER LINKAGE. APPLY A LIGHT COATING OF GREASE TO THE PARK LOCK DOWEL PIN AND THE COLUMN LOCK FLAG. POSITION THE IGNITION SWITCH AGAINST THE LOCK HOUSING OPENING ON THE STEERING COLUMN. BE SURE THE SWITCH PARK LOCK DOWEL PIN ENTERS THE SLOT IN THE PARK LOCK SLIDER LINKAGE INSTALL THE RETAINING SCREW AND BRACKET. TORQUE THE SCREW TO 26 INCH LBS. INSTALL THE STEERING COLUMN COVERS AND THE TILT LEVER IF REMOVED. WITH THE KEY CYLINDER AND THE IGNITION IN THE LOCK POSITION INSTALL THE KEY CYLINDER INTO THE SWITCH UNTIL IT BOTTOMS. RECONNECT THE NEGATIVE BATTERY CABLE AND THE CHECK THE IGNITION SWITCH FOR PROPER OPERATION OF HALO LIGHT SHIFT LOCK IF EQUIPPED AND COLUMN LOCK.ALSO CHECK FOR PROPER OPERATION OF THE IGNITION SWITCH ACCESSORY, LOCK OFF, RUN AND START FUNCTIONS.
Sep 18, 2010 | 1993 Plymouth Voyager
How do i remove the steering column cover to get at the ignition tumbler on a 1993 dodge dakota
CAUTION Disconnect and isolate the negative (ground) battery cable. This will disable the air bag system. Failure to disconnect the battery could result in accidental deployment and possible personal injury. Allow the system capacitor to discharge for two minutes then begin air bag system component removal. To install:
  1. Engage the electrical connectors to the ignition switch and make sure the switch locking tabs are fully seated.
  2. Before attaching the ignition switch to a tilt steering column, the transmission shifter must be in the PARK position. Also the park lock dowel pin and the column lock flag must be properly indexed before installing the switch as follows:
    1. Place the transmission shifter in the PARK position
    2. Place the ignition switch in the LOCK position. The switch is in the lock position when the column lock flag is parallel to the ignition switch terminals.
    3. Position the ignition switch park lock dowel pin so it will engage the steering column park lock slider linkage.
    4. Apply a light coating of grease to the column lock flag and the park lock dowel pin.
  3. Place the ignition switch against the lock housing opening on the steering column. Ensure that the ignition switch park lock dowel pin enters the slot in the park lock slider linkage in the steering column.
  4. Install the retaining bracket and ignition switch mounting screws, then tighten the screws to 22-30 inch lbs. (3-4 Nm).
  5. If the vehicle is equipped with a tilt steering column, install the tilt lever.
  6. With the key cylinder and the ignition switch in the LOCK position, insert the key cylinder into the ignition switch until it bottoms.
  7. Insert the ignition key into the lock cylinder. While pushing the key cylinder in toward the ignition switch, rotate the ignition key until the end of travel.
  8. Install the retaining screw into the bracket and lock cylinder. Tighten the screw to 22-30 inch lbs. (3-4 Nm).
  9. Install the steering column covers, then the tilt lever, if equipped.
  10. Connect the negative battery cable.
  11. Check for proper operation.
Jul 30, 2010 | 1993 Dodge Dakota
Hello i have a 2004 cavalier and it will not go into gear can you help me?
This Is Park Lock Cable Failure here is the Replacment Procedure
Park Lock Cable Replacement
Removal Procedure
  1. Disconnect the negative battery cable.
  1. Remove the console.
  2. Remove the knee bolster.
  3. Loosen the lower steering column bracket bolts.
  4. Lower the steering column.
  5. Place the transmission shift lever in the PARK position. Important: Do not proceed to the next step with the key in any position other than the RUN position.
  6. Turn the ignition key to the RUN position.
  7. Insert a screwdriver blade into the slot provided in the ignition switch inhibitor.
  8. Depress the cable latch. Pull the control cable from the inhibitor.
  1. Push the cable connector lock button at the shifter base to the up position.
  2. Unsnap the cable from the park/lock lever pin.
  3. Depress the two cable latches. Remove the control cable latches from the automatic transmission control.
  4. Remove the control cable clips.
Installation Procedure
Important: When installing a new park/lock cable, keep the shipping cover gauge attached until you are instructed to detach it. The shipping cover gauge will aid in the proper positioning of the cable.
  1. Ensure that the cable lock button is in the up position. Place the shift lever in the PARK position.
  2. Snap the control cable connector into the automatic transmission control.
  3. Place the ignition key in the RUN position. Important: Do not insert the cable with the key in any position other than the RUN position.
  1. Snap the control cable into the inhibitor housing until the snap lock is seated.
  2. Remove the shipping cover gauge.
  3. Turn the key to the LOCK position.
  1. Snap the control cable end onto the shift park/lock lever pin.
  2. Push the cable connector hose forward in order to remove any slack.
  3. With no load applied to the connector nose, snap the cable connector lock button down. Important: Inspect for proper operation of the park/lock control cable before installing the steering column to the instrument panel.
  4. Raise and connect the steering column.
  5. Tighten the lower steering column bracket bolts.
  6. Install the knee bolster.
Apr 08, 2010 | 2004 Chevrolet Cavalier
Sport & Outdoor - Others Logo
434 people viewed this question
Top Stiga Sport & Outdoor - Others Experts
Are you a Stiga Sport and Outdoor - Other Expert? Answer questions, earn points and help others
