Question about Miele Dishwashers
I have a Miele G562 dishwasher (about 5 yrs old) that keeps tripping the circuit. Any tips?
5 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: top rack not cleaning
load 4 cups right side up in all four corners of top rack, move all wash arms to a known positon(pointing foward just want to check there rotaiton). start diswasher, when you hear it start washing give it 30 sec or so andpop it open try to focus on middle spray arm when opening, shlould be turning quite well. and glasses sould be starting to fill. at least thats how it SHOULD operate
Posted on Feb 26, 2008
  • 234 Answers
SOURCE: dishwasher won't cycle through to rinse/dry/stop
Your timer switch is most likely defective.
It probably needs to be replaced.
It is like a clock with switches at different times
If it is stuck at a particular time it will run there forever.
Before servicing disconnect power!!!!!!!!!!
You can remove inside door panel with about 6 phillips screws or so.
Timer is directly attached to the dial on your machine.
These cost about $100.00 or less.
Can also be found used online for cheaper.
Posted on Apr 15, 2009
SOURCE: adg450 about 5 yrs old. Beep Beep.....Beep
Hi, I have a very simular problem, I have just read that running the water in the kitchen sink until its hot may work, if not could you please let me know if you get an answer to this problem,
Thanks
Peter
Posted on Aug 24, 2009
SOURCE: Dishwasher tripped our main circuit breaker.
It may be that your water pump is leaking on to the motor...
Posted on Dec 09, 2009
Miele dishwasher G1040 stop starting then all three lights start flashing
Sounds like bad control board. Try calling the guys from the service, I don't think you'll be able to fix this by yourself. Source: PDF Keep
Dec 27, 2015 | Miele Dishwashers
Miele G 646 SC, Leaking.? My Miele G646SC is leaking, the red inlet/drain light is on and I suspect it may be one of the pump seals has perished. The machine is 11 yrs old and has never had a problem of...
The dishwasher must be removed from the counter so you can gain access to the pump. I would check with a parts supply company first to see if the pump is still available, and the cost. It may be too expensive to repair a dishwasher that old.
Removing the dishwasher is not very hard. Turn off the electrical breaker. detach the DW from the counter. Pull out. disconnect the water supply and drain. disconnect power supply if required.
Nov 28, 2017 | Miele 24 in. G646SC Plus Free-Standing...
Miele Advanta G2170 working fine 2 yrs, suddenly starts popping breakers and won't run (on any outlet) Electrical system in home is about 3 yrs old only.
Hi dear.If the washer is tripping circuit breaker,as long as you plug in,there is a Interference filter capacitor inside of the machine.Main power gets connect there first.It should be faulty & needs to be replaced.I hope that helps Thanks.
Aug 31, 2010 | Miele 24 in. Incognito G843SCVi Built-In...
Miele novotronic T640 about 9/10 yrs old tumble dryer keeps stoping and the start button flashes when it stops
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
Aug 26, 2010 | Miele Dryers
Hi, My Miele G527 dishwasher is tripping the circuit breaker
unlikely
I would suggest that you get in an electrician to test the washing machine for shorts and insulation problems as it could be shorting out in the motor or ground leakage from failing insulation
Apr 25, 2017 | Dishwashers
Trips circuit breaker when door is closed
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
Circuit Breaker Keeps Tripping
heatman101
Dec 15, 2009 | Baumatic 23 in. BDW5 Built-in Dishwasher
Dec 09, 2009 | KitchenAid KUDR01TJ Dishwasher
Dishwasher pops the circuit breaker
heatman101
Jul 01, 2009 | Whirlpool GU1100XTLB / GU1100XTLQ /...
Timer stuck on dry
i have Miele electronic G562 dishwasher which gets stuck in cycle exactly on 1/2 way main wash when the water is is comming in can i fix it myself?
Dec 21, 2007 | Dishwashers
Dishwashers Logo
116 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
