Question about Zebra Symbol MC5590 Wireless Enterprise Digital Assistant Barcode Scanner
What I would like to know is if there is any way to format this device back to factory or boot files from the mini sd.? I do not have the usb cord (25-108022-01R) . The reason for asking this is because some software comes up (manager mc55) and i cannot exit the software and i do not have the admin login password.
  • Patrick Van
    Patrick Van Nov 06, 2011
    Were you able to bypass manager mc55? I'm having the same problem
    Scholar:
  • 117 Answers
Hi, you can use the mini SD Card and clean boot files provided at support.symbol.com , see the link http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=12197&sliceId=&dialogID=191034383&stateId=1%200%20191024978
Instructions are provided in the zip file.
If you have an cradle for the MC55, you could connect it with an PC and use some kind of remote control software to kill the application and then erase the autostart entry.
Posted on Sep 08, 2010
  • Dennis Wieringa
    Dennis Wieringa Apr 21, 2018
    do you by any chance still have that reset zip?
    the link is dead due to the transision of Symbol > Zebra
How can I view from a mini sd card camera?
If you want to view information from any kind of SD card on a tablet or phone you have a few options that may cost up to $30 or so. The fastest one would be to get a Micro USB to Female USB cord I've attached below. I can't speak for the quality of this one, but it's the idea of what you need. Next find yourself a SD reader that connects through USB. Plug the adapter cable into your phone, then the card reader into the female USB end of the cord, and use a file manager app to view the contents! Keep in mind older devices will not support this. Make sure you keep your receipts in case this doesn't work for your device!
It may be more technical than you're looking for, but good luck!
Aug 21, 2015 | ASUS Tablets & eReaders
How do you move your memory from phone to sd card?
  • 1 Insert your new SD card into your cell phone. For most devices, you will have to slide the card into a slot on the side of the phone or remove the battery and insert the card into an encasement. Replace the battery (in the latter case) and boot up the phone.
  • 2 Connect the cell phone to a computer using a USB cord (make sure the cord is compatible with your particular mobile device). This cord sometimes comes in the package when you buy a new phone.
  • 3
    Wait for the computer to recognize your new hardware (the phone). A dialog box will appear asking you for instructions regarding the new portable device. Click the option to open your device's file folder. You should see a folder for the media card and your device memory.
  • 4 Go to the device folder first and select all of the files and folders that you want to transfer to the SD card. Press "Ctrl" and "X" to cut the files from that folder.
  • 5 Navigate back to the media card folder. Press "Ctrl" and "V" to paste the files onto the SD card.
  • Mar 25, 2012 | Cell Phones
    Sandisk ultra sdhc card won't record in my canon digital camera. i get a memory card error
    All you have to do is
    Step One
    To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
    1. Download and install EASEUS Data Recovery
    2. Insert micro SD
    3. Open EASEUS Data Recovery, choose Complete Recovery - Next
    4. Select the drive micro SD - Next
    5. Save the data to the hard disk (max. 1GB)
    6. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4, 5)
    After all data is secure, do the process repair micro SD
    Step Two
    The first alternative - use the software HP Drive Key Boot Utility
    Using the HP Drive Key Boot Utility, for Win XP
    1. Download and install the software HP Drive Key Boot Utility
    2. Then, double click the file cp006049.exe - select Install.
    3. Insert micro SD
    4. Then, open the program "HP Drive Key Boot Utility" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
    5. Remove the micro SD from the USB port, then insert it again.
    6. Quick format micro SD (FAT file system)
    7. Restore all data, to the micro SD.
    Using the HP Drive Key Boot Utility, for Win Vista or Seven
    2. Then, double click the file cp006049.exe - select Extract
    3. Insert micro SD
    4. Then, double click file hpdkbu.exe - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
    The second alternative - use software HDD Low Level Format Tool
    1. Download and install HDD Low Level Format Tool
    2. Insert micro SD
    3. Open program HDD Low Level Format Tool, select micro SD - continue
    4. Click S.M.A.R.T - click Get Smart Attributes
    5. Click LOW LEVEL FORMAT - click Format this device
    6. Wait until the process is complete - press OK
    7. Remove the micro SD from the USB port, then insert it again.
    8. Quick format micro SD (FAT file system)
    9. Restore all data, to the micro SD.
    I hope this information helps.
    Oct 15, 2011 | SanDisk 2GB microSD Memory Card
    I have locked my memory card and forgotten the password. Format card also requires password and my laptop cannot read it. Please help.
    All you have to do is:
    Step One:
    2. Choose Complete Recovery - Next
    3. Choose the drive micro SD - Next
    4. Save the data to the hard disk (max. 1GB)
    5. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4)
    After all data is secure, do the process of removing the micro SD password
    Step Two:
    3. If you are using Win XP, double click the file cp006049.exe - select Install.
    4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extrack.
    5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Finish.
    6. Remove the micro SD from the USB port, then insert it again.
    7. Quick format micro SD (FAT file system)
    8. Restore all data, to the micro SD.
    2. Select micro SD - Continue
    3. Click S.M.A.R.T - click Get Smart Attributes
    4. Click LOW LEVEL FORMAT - click Format this device
    5. Wait until the process is complete - press OK
    I hope this information helps. Thank you for using FixYa!
    Oct 11, 2011 | SanDisk 2GB microSD Memory Card
    Micro sd 2gb tidak bisa format
    Hallo scorpio, semoga solusi ini membantu
    If the micro SD format fails, do not you repeat the formatting process. Because it will exacerbate the damage to the micro SD. Follow the steps below. Good luck.
    Step One:
    Step Two:
    If the second solution does not work, it means your micro SD damaged firmware. Based on experience, one of the causes of damage to the firmware is, the formatting process is done repeatedly, but always failed.
    How to factory default Mc75 device
    Resetting the MC75
    There are two reset functions, warm boot and cold boot. A warm boot restarts the MC75 by closing all running
    programs. A cold boot also restarts the MC75, and also resets the clock. Data saved in flash memory or a memory
    card is not lost.
    If the MC75 is not functioning properly, perform a warm boot first. If the MC75 still does not respond, perform a cold
    boot.
    Performing a Warm Boot
    Hold down the Power button for approximately five seconds. As soon as the MC75 starts to boot release the
    Power button.
    Performing a Cold Boot
    To perform a cold boot simultaneously press the Power button and the 1 and 9 keys.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
    Thanks, Joe
    I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
    Feb 01, 2011 | Motorola MC75
    Hi,ive just bought a t-flash usb 2.0 for downloding nintendo ds games,not sure if it is what i put on what product is it about, but how do i install it on my computer? i cant actually find where it is on...
    Once you plug the mini sd card into the usb device and plug the usb device into your computer it should show up as a hard drive in your My Computer area. If not you may have to initialize the hard drive.
    Good Luck,
    NOLA Tech
    Apr 07, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
    My mini sd card is in raw format and my computer can't read it - how do i change it back to fat file system ?
    1. Place the mini-SD card within the mini-to-SD card adapter. Make sure the tab on the mini-SD is facing the upper side of the adapter. Slide it in slowly, being careful not to damage the pins.
    2. Slide the adapter in an SD slot on your computer. If you do not have an SD slot, place the adapter in a USB card reader, and plug that into a USB slot on your computer. Give the computer time to read the card.
    3. Open "My Computer" (usually located in your start menu) and navigate to your mini-SD card. It will usually be recognized as a drive such as "E:" or "H:."
    4. Right-click on the drive and select the "Format" option. A menu window will open.
    5. Make sure that the drive size is set correctly, and that it is set to the file system you wish to use (usually FAT32 on an SD card). If you don't know what file system you should use, just leave it at the default setting.
    6. Enter a volume label, which is the name for the drive, then press start. This process should only take a few minutes.
    WARNING
    • Do not use the "Quick Format" option unless you have just recently formatted the mini-SD card. "Quick Format" doesn't completely erase all data and is not effective unless used after a full format.
    • When you format your mini-SD card, all of the data on it will be erased. Make sure to back up your files on the card before formatting
    Sep 25, 2009 | Electronics - Others
    Formatting the mini sd card
    Don't know if your sansa supports from the settings, info tab to select sd card and format, if not attach to pc (settings usb) and the first memory displayed will be internal the second will be microsd card.
    Apr 10, 2008 | SanDisk Sansa e250 MP3 Player
    Open Questions:
    See all Zebra Symbol MC5590 Wireless Enterprise Digital Questions
    Zebra Symbol MC5590 Wireless Enterprise Digital Assistant Barcode Scanner Logo
    908 people viewed this question
    Top Zebra Computers & Internet Experts
    Mike
    Lawrence Oravetz
    Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
