SOURCE: Macbook pro + IBM m4000
Depends on the connections you have on both. Most MacBook Pros have a DVI connector on the side. If the IBM projector takes that sort of input, then all you need is that cable.
If the IBM projector has a VGA input, then you'll need an adaptor from DVI to VGA.
(VGA input is standard monitor looking connector.)
SOURCE: macbook recognizes dell projector, but not vice versa
Your Macbook should automaticaly find the best resolution, if everything was OK. Is there any HDMI input on the dell projector? What projector is it? Is there is an HDMI input, you can use a HDMI to mini DVI cable: better picture and sound than VGA, and will probably solve your problem
SOURCE: Apple MacBook Pro with 17
If there is no liquid spill involved, then it needs new Logic Board.
SOURCE: My apple aluminum keyboard not working with Macbook Air
try to connect your keyboard to the mac air while mac book is connected to internet (by wifi) then update your programs (apple menu - update).
SOURCE: problem with internet connection
By "USB wireless internet" I assume you are referring to a communication card from a cellular telephone carrier.
I also assume that despite the fact that you have singled out Safari, in reality you will find cannot access the internet at all through this device, e.g., sending and receiving mail through Apple Mail, using iChat, using Software Update, etc. I say this because when Safari refuses to access the internet through a particular device, it's very rare that the problem turns out to be peculiar only to Safari. (To answer your original question, no, no special settings are needed.)
Many of these cellular internet cards come with "install me first" software for the Mac that is written badly and doesn't work on the most current versions of the Mac OS. Your first step (assuming you have another working route to the internet) is to visit your provider's website and download the current version of his Mac connection software (which will almost always NOT be the version you got in your product box). Install and run it exactly according to the instructions (they are often so fragile that any variation at all will break them), and then try again.
