Question about Panasonic CQ-VAD7300U Car DVD Player
Screen wont open or eject disc HELP!
I just bought this used and i tried to test it before installing it. I got the unit hooked up from the car battery where i get the blue light to where it powers up but when i press the eject button or try to get the screen to come out it dosent do either of the 2. I have the grounds hooked up and the parking brake wire grounded. The remote and power hooked up to the battery but all i get is the blue light to show the deck is getting power but no buttons will work. I dont know what else to do please help me out someone.
  • mangas1981 May 13, 2008
    I hooked up the yellow (battery) and red (acc) to the positive terminal on the battery and the black (ground) and blue (side brake) to the negative terminal. It powers up but the screen wont open and the eject wont work no buttons do.
Do you need to connect the blue remote wire? and where?
Posted on Jul 21, 2008
If you connected the blue remote wire to the batterry you burned the unit
Posted on May 13, 2008
Fiona@jossi have a mazda 3mps with 6 disc changer 3 of the discs wont eject and it keeps saying check cd. discs wont play either. can anyone help please!!!
sounds like you are using discs you have burnt yourself
these discs are thicker than the ones you get in stores and frquently get stuck and dont work in units not built to handle these discs
it is very hard to get out without removing unit and opening it
you might be able to carefully grab or hook disc if it partially ejects but you risk damaging disc or unit you might need to bring it to repair shop
good luck
Mar 13, 2011 | Car Audio & Video
Disc drive wont open. i pressed the eject button on my keyboard but it makes a clunk sounds but wont open.
This wil show you how to take it apart if that becomes necessary. But try this instead. First hold the eject button down for 5 seconds. I that fails look for a tiny hole near the disc slot. Use a straightened paper clip and push it in the hole firmly. This should eject the disc. Another option is to use firmware to eject the disc. Follow these directions: To eject a disc with Open Firmware commands, follow these steps:
  1. Restart the computer.
  2. Immediately after the startup sound, press and hold the key combination Command-Option-O-F.
    Note: The Command key has the Apple and (commandkeysymbol.gif) icons on it.
  3. Release the keys when you see a white screen that says "Welcome to Open Firmware."
  4. At the prompt, type: eject cd
  5. Press Return, then wait a few seconds. The disc drive should eject any disc that is present, and "ok" appears behind your command when the action is complete.
  6. Type: mac-boot
  7. Press Return.
  8. Your computer should now start up normally.
  9. Instructions curtorsey eh.mac.ca
Aug 16, 2010 | Apple iMac G4 Desktop
APPLE IMAC G4 - TRYING TO INSTALL OS WITHOUT DISK EJECT BUTTON
Reastart the iMac and at the same time hold down the mouse left click button. If that does not work.
  6. Type: mac-boot
  7. Press Return.
Dec 11, 2009 | Apple iMac G4 Desktop
Becker Car 10 CD Changer wont eject and hear a cycling sound
cyclying sound may be laser "trying" to read the disc, try a new store bought disc and see then , if it plays ,lasers on the way out , if u get the same sound try to obtain the service manual for the unit , most repair shops will not look at it if they dont already have a service manual . see owners manual for what discs it will paly , rw "burned " mp3 ect . its not ejecting because of possibly different issue .if error is displayed contact grand prix electronics (they made the unit) and see if they can revise solution
Nov 30, 2009 | Car Audio & Video
KW-AVX710 Screen stays black (off) untill I hit the open button
So I decided to verify all the connections after I got frustrated with it. Everything was correct except one wire that was on the new harness I got that for my car that was labeled "12V fused" (supposedly the key on power source). I tested it with my volt meter and it did not have power at any time, even with the key on. The constant power source wire was hooked up so that's why I was able to open the face and eject CD's and DVD's but not do anything else (like when your ignition is off). So I ran a new wire from my fuse panel and everything works now. Just like my Thermodynamcis professor says "nullius in verba" (take no one's word for it), just because the wire was labeled doesn't mean it's right! Hope this helps.....
May 25, 2009 | JVC KW-AVX710 Car Video Player
Disc wont eject
Hi jamie,
It seems you have opened the top cover of your unit. Now take a dry cotton bud clean the roller which you can find right in front. Please do not use any liquid to clean the same.
Please cast your vote for me if this solve your problem.
ramesh22
May 17, 2008 | Pioneer AVIC-N1 Car DVD Player
Jensen 9410 will not load or eject
i had my jensen three weeks everything was okay until all of sudden the unit wounld not load or eject CD's or DVD's
Mar 20, 2008 | Jensen VM9410 Car DVD Player
DRIVE UNIT WONT OPEN OR EJECT
You can eject the cd by pushing a paper clip into the small hole in the draw.
Sep 26, 2007 | Acer Aspire 5100 Notebook
Jvc-avx1 wont eject
Try to power down the unit and the power it back up then press the eject button. If this does not work there might be a hole in the front of the unit which you could insert a paper clip which will actuate a mechanical release switch.The last thing you can try is to open up the unit and manually rotate the load and unload motor and this will eject the DVD. Restore the cover and then start up the unit to see if things are ok.
Sep 16, 2007 | JVC KD-AVX1 Car DVD Player
Cds Stuck in cd changer. stuck at no. 6.
i have a infiniti i-35 2002 and my cd player won't play or eject i was switching cd's on no. 4 and when it went in it got stuck inside it won't play no. 1thru6 are there any suggestions
Jun 16, 2006 | Bose Wave music system Multi-CD Changer...
Panasonic CQ-VAD7300U Car DVD Player Logo
191 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
