Question about Mitsubishi VS-45607 45" Rear Projection Television
We can't display cable display - do not know how to use controller to fix. We are elderly and need as much help as possible Thank you. No picture, no volume
  • 2 more comments
  • ratwater4948 Sep 06, 2010
    we have PIP picture.
    In the small PIP picture size, we have our cable PIP and we have no volume.
    How do we get our picture full size and get the volume back?
    We do not have a PIP/POP button - only a PIP
    Our model number is VS50703
    Pressing the PIP button slowly does not bring picture up to normal size, and does not bring sound. Neither do the PIP channel select or PIP input. Thank you so much.
    my husband had to leave for several hours.
    Can I still ask a question severalhours from now?
    I don't know how to work the remote or do any fix problems.
    Thank you - we are an elderly couple that only have one tv and are unfamiliar with set ups.
    Thank you so much
    We finally got the large picture, however, now the PIP box is solid black and even though we're pressing the PIP button, the solid small PIP box does not disappear. Thank you.
  • Mitsubishi Master
  • 5,807 Answers
Thanks for choosing Fixya for assistance in advance,
While i look for possible free operation manual, for your
unit for you to have,
here is a simple connection that you can do to view
and watch programs on TV:
At the back of your TV :
There are Video Input and Audio Input.
Connect the Audio and Video Out of your
Cable " Box " to it respectively.
Meaning connect the Video Out ( yellow ) using
RCA cable
like these one:
Sample connection:
Connect one end the " Red " RCA plug to the 'Cable
" Box" Video Out and the other end to the TV
Video Input.
Connect the other ( White) to the Audio Out of the
cable " Box " and the other end to the TV Audio
In .
select Video Input on TV to view and hear programs.
To select stations , use the " Box " Remote to
change the channel ( stations ) you would like to
watch.
Posted on Sep 08, 2010
  • Rommel Cana
    Rommel Cana Sep 08, 2010
    Using the remote , Turn OFF closed captions
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
Try to describe problem, how and what is connected to set for signal? SD TECH
Posted on Sep 07, 2010
  • SD Tech
    SD Tech Sep 08, 2010
    I am in California, allow for time differences, You have PIP but no main picture?
  • 11,896 Answers
Go to menu, find tuner option. See if there is a setting for AIR or CATV. It should be set to CATV.
Then you can watch your cable channels.
Posted on Sep 06, 2010
  • Nate Stansfield
    Nate Stansfield Sep 06, 2010
    Try pressing exit menu. Make sure Closed Captioning is off. If needed, unplug the tv for about 4 hours. Sometime while it is unplugged press and hold the power button for 10 slow seconds so the tv can reset. It should turn PIP or closed captioning off.
  • Mitsubishi Master
  • 11,800 Answers
On the remote there's a button labeled PIP/POP. Press it slowly until the image will return to normal, with sound.
  • Azrael SRL Sep 06, 2010
    Make sure the remote is set on TV then press Exchange - this should flip the PIP images. The big one with sound will be the cable and the small one will be blank. Now press PIP button - the small screen should be gone. If you can't do that from the remote then use the buttons on the tv: press MENU, go to PIP section and first switch the image then close it.
  • Azrael SRL Sep 08, 2010
    Then do it using the buttons on the case. Apparently the button on your remote has aged and has stopped working - you will have to replace the remote.
  • 666 Answers
If u have neither picture or audio and the power light does not blink to indicate that there is an error in the circuitry than it is most likely the power supply and will require both a technician and a part to fix
hope this helps
Robb
How can we fixed if the error display is E.EnC1
There is a problem with the channel 1 feedback loop.
Possible causes:
Loose connection at encoder or feedback card.
Defective feedback cable.
Defective encoder.
Defective feedback card.
Defective control card.
Defective inverter.
Feb 24, 2014 | Inverter KEB COMBIVERT F5
Screen goes blue and returns if cable cord moved
try do the same thing using the dvd or cd player plugged in.
Oct 21, 2008 | JVC AV-36890 36" TV
Toshiba 32AV500U HDTV keeps losing channel 2.1
check the location of their antenna and direction it is pointing . it possibly needs tweeked just a little toward the station transmitter
Mar 01, 2017 | Toshiba 32AV500U 32 in. LCD HDTV
No picture or sound
Your display needs to be reset, Turn the ps3 off. Then turn the ps3 back on but continue to press the power button until you hear the beeps then it should work fine :)
Aug 05, 2009 | Sony Playstation 3 (PS3) Console
Problem in transfer picture
hi..u should be able to transfer the pictures to pc
with the help of the data cable.If u r not able to do it
make sure that ur data cable doesn't contain any virus.
If u have virus in the data cable it is not possible to transfer the pictures.
thank u..
Feb 01, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Bose Lifestyle 12 version 1
Hi, The dead display is possibly down to a capacitor problem, see fixes already covered by me, it's a 33uF capacitor either on the display board or if a newer unit on the main pcb, these cost less than $1 there is only one just change it.
The no audio may be a simple fix, do you have sound from the head set socket?, if yes then look for one of my other fixes on changing a resistor near the control socket, if no then I need to have a think... If the unit has no sound or display after changing the capacitor it could be a power supply fault. Fix the display first and let me know.
Dave
Jan 29, 2009 | Bose Lifestyle 12 System
Sony DCR-HC32 display problem
replace the flexwire asap, it's hard to fix and you need pro help to do it. flexwire has a possibility of shortcircuiting the unit, the reason your small viewer started to show problem. Here in the philippines i'm not replacing it with an exact replacement, instead i'm replacing it with the more strong wires or cables such as the one used in laptop computers, still, you need profix to do it. [:0)
Oct 29, 2007 | Sony Handycam DCR-HC42E Mini DV Digital...
TV has sound with no picture display
Is it possible the pip and the main picture have been swapp and the main picture is showing as the Pip?Is a possibility,check it out and let me know.
Sep 29, 2006 | Tatung V30DMTT 29.6 in. LCD Television
No tv picture
Its possible that you changed the channel or the input line your TV gets the cable signal from. unless you caused more of a problem while trying to fix it, I would suggest you to go through the TV(not cable) channels to see if you can find the one that gives cable picture, or to go through the different input settings(TV/AV on older TV's, and 1, 2, 3 etc on newer ones). one general icon for the later is an arrow going into a circle. I think its the "select" button on your TV remote. Good luck
Mar 29, 2006 | Philips 30PW8402 30" TV
Mitsubishi VS-45607 45" Rear Projection Television Logo
43 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
