Question about Dishwashers
I get an LE error message on my LG Dishwasher. I replaced the pump. Still get the LE error. Replaced the main control. Still get the LE. No blockage in the pump. What now?
  • 5,081 Answers
When you receive the LE error code, unplug the machine for approximately 15 - 20 minutes. This will reset the microprocessor.
Oversudsing is the main cause of LE error codes. Using non-HE detergents or too much detergent will cause stress on the motor. Oversudsing can also cause leaking and odor.
A breakdown in the signal between the microprocessor and the motor may cause the error code. This can occur if there is a loose wire.
A couple of notes about this - there are at least three motors on this unit - the main pump, the drain pump, and the 'vario motor' which appears to control the direction of water flow through the sprayers. The main pump is the one likely to go bad. Another cause of the LE code is broken wires in the door. The wires in the door get stuck in the black sound insulation and eventually break. Sometimes, this causes the LE error code. Check the wires in the door first. They are located behind the large front panel. It's easily removed by undoing 6 screws.
Posted on Sep 06, 2010
  • rhammervo414 Jan 21, 2011
    Thank you very much. This kind of personal experience advice along with the LG Service Manual is really helpful in tracking down the problems. bob
Take the front door panel off and look for a purple wire embedded in the insulation. the wire has most likely broken. Simply splice it back together and you will be back up and running
Posted on Nov 12, 2011
Lg dishwasher displays LE error
Display Condition LE = Motor Error
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is
locked.
The rotor of Washing Motor is
locked.
The Blade is locked.
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
Additional details in this article: dishwasher/how-to-fix-lg-dishwasher-le-error
Hope this helps (remember to rate and comment this answer).
May 26, 2011 | LG Dishwashers
Our dishwasher shows an LE error code when started. What is wrong.?
Le error is a motor error. either there is something lodged in the pump holding the blades or the motor itself needs to be replaced
Jun 22, 2010 | LG LDF6810ST Stainless Steel Built-in...
LE error message on the panel
Depending on the serial # of the dishwasher it may need a new wire harness and inner door liner.
LE is a motor circuit error.
Contact LG @ 1 800 243-0000 they may help you out.
Jan 15, 2010 | LG Washing Machines
"LE" Error Code appears on control panel
LE is a motor error Wiring connection is OK? The Impeller of Washing Pump is locked. The rotor of Washing Motor is locked. The Blade is locked. REMEDY Check the wiring connection. Replace the cause of restriction. Replace the Washing Motor. Replace the PCB.
Sep 24, 2009 | LG 24" Built-In Dishwasher - Black
Dishwasher showwing LE error message
Hi Tanja
LE is motor error.
Empty water from inside the machine and try tripping the circuit breaker for a couple of minutes.
If that does no clear the error , then one of the following faults may have ocurred:
Wiring connection broken either bad connector on pump side or on timer control side, or faulty wiring harness.
The hose connected to impeller, or the impeller itself is blocked.
Motor or pump locked.
Faulty timer board.
Aug 15, 2009 | LG Dishwashers
Error code LE and OE
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. Check the exit hose, it may be clogged.
LE Code refers to a motor overload.Since the pump is blocked,the motor becomes inefficient in working.Once you get the pump cleared from blockages,I assure that you can get rid of these errors.Good luck with the machine.Please do post the results and comments.
Apr 12, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Im getting error code "LE" on my lg dishwasher
While LE is the LG error code for "Motor Error": The Motor is working abnormally, it does not always mean that the motor itself has failed.
As you replaced the pump motor, are you certain that the Impeller of Washing Pump is turning freely? Next, is the Blade spinning freely?
If everything above is obviously not locked, the next item is the controller board. (PCB)
Hope that helps. Please report back with your findings! Good Luck.
Mar 19, 2009 | LG LDF6810ST Stainless Steel Built-in...
Hi there I have a silver LG dishwasher..I am intermittentleey getting the Code PE. I have take the pump off the exit water pipe and chaeck for blockages etc... there are none. Any ideas?
Please confirm the model number of this LG diswasher.
On recent LG units, the avaiable error codes are: IE OE E1 FE tE LE
The PE code is abnormal. Can you confirm.
I would expect to see the error OE if water is not fully pumped out. Remove the filter from the sump area beneath the bottom rack. Look closely for debris causing a blockage/lock. Please get back to me with your findings and ask more questions as needed.
Jan 25, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
LdF7811ST LG DISHWASHER
LE stands for "Locked Motor". It means the main pump motor is bad.
Dec 07, 2007 | LG 24 in. LD-12BS6 Stainless Steel...
Dishwashers Logo
1,045 people viewed this question
Top Dishwashers Experts
