Question about HP Pavilion m7570n (EX331AA) PC Desktop
Clicking Harddrive Okay so here's the deal a day ago, I realized that there was a loud clicking sound coming from inside the computer. I read a few other post on the internet saying that it might be the the harddrive might be starting to fail, because the micron gap between the wafers and the read head has become uneven. AS a precaution I made the set of recovery discs and backuped all of the valuable information. Is it true that the drive is going to fail, cause it is only 2 years old, or am I living in a nightmare. PLEASE HELP!!!!
  • Alexander Selby
    Alexander Selby May 13, 2008
    okay, I checked everything and it is definitely the hard drive that is clicking, but the system runs normally, and there are no hang-ups or anything.
    Problem Solver:
  • 11 Answers
If your Hard Drive is clicking it has become unreliable and is in the process of failing, you are lucky you were able to get all of your important stuff off and make your recovery discs. Hard drives can fail for a variety of reasons but it can happen at any time, if the computer is a month old or 15 years old... Honestly sometimes it just happens. This is why it is a good idea to constantly have at least one backup of your data.
Get a new Hard Drive, have it installed and have someone (or you) install the Operating System and then move all of your backed up data to your new operating system
Posted on May 13, 2008
  • 3,940 Answers
Loud Clicking CAN be a symptom of a failing hard drive. Generally it is also associated with a boot failure though (It is called the Click of Death). If the system is booting normally, there may be a different source for the noise. Most desktop systems have a minimum of 2 cooling fans, higher powered ones can have 5 or more. Many moving parts in the system can cause a click.
I would suggest you remove the side cover of the tower, and see if you can localize the source of the noise. (The instructions for your system can be found on http://h10025.www1.hp.com/ewfrf/wc/siteHome?dlc=en&lc=en&cc=us
Once you localize the source of the noise, you can address the problem.
When I turn on the harddrive it just blinks with a red light.....no connection to computer. Also hear a clicking sound
would you know if the clicking is coming from the harddrive?
if it is check your harddrive out.
Apr 03, 2015 | Computers & Internet
Clicking sound when ignition turned off
I had a similar issue on my Nissan sentra years ago. In my case it was the fuel injectors clicking because a diode in the cars computer had failed. It would only stop when I pulled the fuse for the injectors under the hood. You may have a similar issue. On mine it just sounded like a regular clicking under the hood. Very loud with the engine off
Apr 21, 2014 | Hyundai Sonata Cars & Trucks
My computer wont read my iomega external hard drive but read before now its just local disk c ...try to open but will freeze ...have a lot of stuff on hard drive so i cant just format it again...
This is quite a tough one, First does the external hard drive appear when on your computer at all? I would assume disk "c:" that you mention is your main drive or your internal harddrive. If you don't see your external on the computer when you have it plugged in and turned on. Then there is a promblem. 1) Make sure driver is installed, usually when you turn on the external harddrive or plug it in to the computer, the windows sound (found device) usually pops up. 2) Check all connections if all is properly made, and if you have another computer, test it on that computer if you get another different result. If same result is made, and all connection are properly secured. Then you external harddrive enclosure, or the harddrive disk inside it is bad. 3) Listen to your harddrive to see if you hear the drive inside it spins, or if it is making any noise. If spin you could be ok, if it is humming or clicking loudly like it's stuck, then you are kind of done for and could pretty much say goodby to all those files and stuff (with exception) 4) You can take the hard disk inside the external enclosure and hook it up to a computer (if you need help how to, let me know) and see if the computer is able to read it. If not, then definitly your drive is damaged. You can still recover the files, but can't gaurentee a full recovery. In that case, you can take it to bestbuy, office depot, and tell them about the promblem and have them do a data recovery. It is costly, I mean very costly. Anywhere from $250-$750+
Now, if your computer could detect it and give it a drive letter for exmaple D:, but unable to access the files, you can probraly do a error-checking when right click for propertie of the drive.
Feb 01, 2011 | Iomega 33089 250 GB Hard Drive
My smartdisk firelight suddenly started clicking and the computer wont read it what do i do
http://www.fixya.com/support/r4247716-usb_device
Start there and see if any of that helps but clicking is usually a sign of a dead drive or one that does not have enough power to operate it when it comes to USB
Bob
Jul 23, 2010 | SmartDisk FireLite 40 GB Hard Drive
My lacie hard drive fell a few minutes ago. It now takes a really long time to load up and open files. It also keeps making a clicking sound what could be the problem and whats the solution
It sounds like you have damaged the drive.
The clicking sound is a mechanical failure where the the read arm inside the drive is hitting the magnetic platters. You should backup your data immediately as drive failure is imminent.
Robert from Blitware
Jun 25, 2010 | LaCie (300728U) 250 GB Hard Drive
Clicking sound in computer then BSOD
There are very few mechanical parts in cpu...some of them are cpu fan. smps fan chassis fan hard disk motor or cd drive.......as you were talking about click...i doubt on cpu fan also clean the processor and coolant as there might be dust in it that prevent the cpu fan to cool down processor this might be causing system freeze....do reply back if this solves your prob
Oct 01, 2009 | HP Media Center m1270n (PP132AA#ABA) PC...
I have a refurbished Compaq Presario V2555us. It's a few years old, but has been a great laptop. It previously belonged to my girlfriend and the motherboard fried, so they sent it off for repair (this was...
The media test failure and the clicking sound from the hard disk indicated that the hard disk has failed. To get the laptop goining again, you need to replace the hard disk and install Windows on the new hard disk.
Jun 06, 2009 | HP Compaq Presario V2555US Notebook
Freezer/Refrigerator tempurature swinging wildly
The compressor is overheating and not starting. Could be just the start relay. If this happens again try unplugging it for about an hour then it should work for a while. Heat between doors is normal this is an electric heater designed to keep the doors from sweating. You just noticed it because the refrigerator wasn't cold.
Jun 26, 2008 | Freezers
CLICKING SOUND-Crosley 19 cu ft Refrigerator
Your start system need to be replaced on the compresser go toy the parts house and ask them for a Supco RCO410 or a Supco PRO41 they come with instructions this is a common problem and will get you back in order faster than orering the factory oringinal
Feb 18, 2008 | Crosley CRS40 Manual Defrost Compact...
HP Pavilion m7570n (EX331AA) PC Desktop Logo
145 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
