Question about Mitsubishi VS-45607 45" Rear Projection Television
Video when i turn on the TV the audio works fine, but there is no picture of any sort, just audio.
  • Anonymous Nov 07, 2008
    I HAVE GOT A MITSUBISHI VS-50VA2 PROJECTION TV WITH SIMILAR PROBLEM THE SOUND IS GREAT BUT NO VIDEO AT ALL. I HAVE RE SOLDER THE POWER AND SUB POWER BOARDS FOR COLD SOLDER CONNECTIONS BUT NO CHANGE AT ALL PLEASE ADVISE ME. WILL BE APPRICIATED ANY OF THE INPUTS.
    NOTE: THE GUNS DOES NOT FIRES UP AT ALL.
    MRXANGO
Where do i find l2c50 part #325c146030 ?
Posted on Feb 10, 2009
  • kingrfrance6 Feb 10, 2009
    where do i find l2c50 part #325c146030 ?
  • 927 Answers
Good Day, Maktideva;
No video could be caused by many things but the most common problem with this TV is: CHECK FOR OPEN L2C50 PART #325C146030 ON THE SIGNAL PCB.
Hope this was helpful and not too late.
Good Luck, big IRISH.
Posted on Jul 31, 2008
Philips Magnavox 9P6031C103 projection tv quit working 2 years ago (before, the picture began to shink and expand until it finally quit completely with no audio nor video -- turned it on two years later to...
Based on what you described I would say your TV has the "shrinking and expanding" fault. Its a common problem on that model and the symptoms can range from the video shrinking and expanding or no video or no audio....You can read more about this fix on the site www.TvRepairKits.com
Jan 13, 2013 | Philips Magnavox 9P6034C 60" Rear...
No sound
Sounds like a loose connection that has finally failed in the audio out circuit
Jun 04, 2008 | Hitachi 61HDX98B 61" Rear Projection...
Mitsubishi VS-55609: No video/audio - just static
You are on the right track. If you cannot see a picture on either antanna A or B then the tuner is suspect.
You may try hooking the cable straight into the TV if you are using a cable box, if not then you should be getting a picture when your other video devices are turned off.
The fact that you get a picture on video tells me that the AV circuits are fine.
Thanks
asnowman
Jul 25, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Tv has audio but no picture. tv was working perfectly fine last night with audio and pic but now no picture
kindly check ur video cable if ur r useing audio/video cables for you tv
if not u need to check for ur tv tube
Jun 04, 2010 | Mitsubishi WT-46807 46" Rear Projection...
TV works fine for 12-18 hrs. Then picture goes off
It seems that your unit has some sort of Thernmal problem or a problem that is shutting down the Power Supply section to the Video side of things.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Jan 21, 2010 | Mitsubishi VS-6055 60" Rear Projection...
I have an old mistubishi vs-5041 the audio on the tv is perfectly fine but their is no picture what so ever its just a black screen any suggestions on how to repair
It seems that your unit has some sort of Video Output problem or a problem that is shutting down the Power Supply section to the Video side of things.
Jan 21, 2010 | Televison & Video
Mitsubishi VS-4551A TV Problem
This rear projection t.v. will turn on and the audio works fine, but there is no picture of any sort just audio
Oct 17, 2007 | Televison & Video
Mitsubishi VS-45607 45" Rear Projection Television Logo
127 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
