Question about Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener
Install garage door spring - Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener
    Scholar:
  • 143 Answers
Springs are better left to professionals. These are the most dangerous part of your door or opener system. They are under extreme pressure and put other parts of the door under this same pressure. Unless you know what you are doing then leave it to the pro's. Thanks BB
Posted on Sep 10, 2010
How to fix a tempro model 2500 standard 1/3hp garage door opener
Bill manually try lifting/raising the door, you should be able to raise door manually easily or there is a adjustment required on the tension springs, you may have to have a tech. do this, links below may help.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Installing Garage Door Opener DIY 5147
Garage Door Opener Installation Made Easy
How to Adjust Garage Door Spring
Garage Door Torsion Spring Repair
Apr 18, 2016 | Building Materials
How to install a garage door
man if you don't know call a person that installs them those springs are killers .
May 01, 2015 | Building Materials
How do I install new springs for my garage door?
All depends on if it is an extension spring or a torsion spring setup. Either way, I would hire a professional to order the correct spring for your particular door, and for safety. If you really want to tackle this yourself, give me more information, and I can walk you through the procedure.
Oct 02, 2014 | Building Materials
Can I fix a broken garage door extension spring myself ?
Yes you can!
Raise the door all the way. place clamps or vise grips on the frame to keep it safely up.
Very carefully, remove the unbroken spring and get a pair of new ones from the nearest overhead door company.
Install the new springs and then and only then remove the clamps.
Jul 13, 2014 | Building Materials
My garage door will not open but approx. 8" , no cable broken , chain on track. Today I found that one spring is broken. how hard is it to replace.
I have built many garage doors and installed many door openers. The typical garage door spring is not that hard to replace. I have to have 2 steel rods 1/2 inch in diameter to slowly tighten the spring.
Oct 17, 2013 | Stanley Hardware 730610 110 Lb Garage Door...
Installed two new springs on automatic doorman model 455 and it won't close or open. chain will not move door where are adjustment screws? I think that may be the problem
Does it make a noise? Did it run before you changed the springs? Did you replace springs on opener or on the door? What adjustment screws are you looking for? Do you think they went out of adjustment when you changed the springs?
Sep 04, 2011 | Sears Craftsman LiftMaster Chamberlain...
Torsion spring is broken for our liftmaster 2265R model garage door opener and i need a new one where do you buy one?
Here are instructions for replacing the spring. You can call any local garage door company and they will sell you the springs. I absolutely don't recommend this job for a DIY'er. It is dangerous.
http://ddmgaragedoors.com/diy-instructions/replace-garage-door-torsion-springs.php
Feb 23, 2011 | Sears Craftsman LiftMaster Chamberlain...
Broken spring
call an overhead door company. the springs are under high tension. Better safe than sorry.
Nov 25, 2008 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener Logo
107 people viewed this question
Top Chamberlain Car Audio & Video Experts
Glenn Mayer
Glenn Mayer
richie46
Are you a Chamberlain Car Audio and Video Expert? Answer questions, earn points and help others
