Question about RIM BlackBerry 8700g Smartphone
Radio turns off by itself
I've had an ongoing problem with two different 8700G's where the radio shuts itself off without my intervention. To make a call or get email I have to manually turn the radio back on. There's no pattern to it. One day it will happen once, the next day five times. T-Mobile already replaced the battery twice and replaced the BB once as well.
    Genius:
  • 1,224 Answers
Phone has been dropped there is a key sticking or hair line crack in mother board of phone
Posted on May 13, 2008
I have a 1994 Jeep Grand Cherokee and radio turns itself off without intervention!!
Posted on Jun 24, 2009
JVD car radio. Why won't it shut off when key is shut off?
The radio has 2 power feeds, one is wired to battery so it has power all the time for memory and the other power feed is from the ignition circuit so when you turn the ignition on it turns the radio on. You need to determine if the ignition feed is shutting off with the ignition. If the power feed is shutting the power off then there is a problem with the radio. If not then there is a problem in the ignition circuit.
Oct 10, 2015 | 1998 Jeep Wrangler
Radio sound sometimes and not
IF the speakers are in the doors then the wiring harness in the door-jam is frayed, and you must cut the rubber to access the wires between the door and the door jam to get at the wires without taking the door apart.
Apr 21, 2014 | 2004 Chevrolet Impala
Radio will not shut off once key is removed
Ignition lock cylinder or ignition switch, something is stuck and still giving 12V to the radio when the key is gone
Apr 02, 2014 | 1998 Chevrolet Chevrolet silverado
Radio Station Keeps Changing Automatically
hi there is a option in the settings to automatically search for the station if frequency changes try turning it off to see if that helps
Mar 23, 2014 | 2006 Hyundai Accent
HEllo, I have a Motorola Radius CP200. When I
If the sound is continuous, like a long tone humming, it is possible you are on a channel which is not programmed. Try changing your channel knob to a different channel and see if the sound changes.
If the sound is not continous, and only happens upon pressing a button, we are not certain what you are experiencing without seeing the radio first hand.
If it were the battery you would get a low battery beep and then the radio would shut itself down. This can happen from a bad battery or a low battery. If this were the situation, you should check your charger and be certain the light comes on and stays on when the radio is placed on the charger. (Note: your radio should always be turned off when on the charger.) A quick test would be to swap the battery with a known good radio and see if you have the same problem. If so, you know it is not a battery or charging problem.
If none of these items help, send or bring the radio to a Motorola repair shop for a quick analysis.
Best regards.
Aug 21, 2013 | Motorola CP200 Two Way Radio
Hi all....I've got a 2001 Fiat Punto, and after disconnecting the battery the radio is asking me for code. When I turn on the radio, it says
Most car radios need a code when theyve been disconnected , also some car radios are made to turn off after 20 mins use so that it cant be left on accidently , this is a battery saving idea , it can be bypassed though by rewiring a live connection to the radio rather than a connection through the ignition
Sep 23, 2012 | Car Audio & Video
I have a 95 Honda civic. My cig. Liter works but my radio won't turn on no matter what I do. My clock resets every time I get in the car. I've replaced my wiring harness the fuse in my radio is...
Don't know if yours is one but some 95 Honda civic have a antitheft program. If the battery ever goes dead or voltage is removed from it, it will not work until a program code is given to bring the radio back to life. you might want to try searching 95 Honda civic radio code.
Jul 03, 2017 | Cars & Trucks
Motorola talkabout MJ270R switching off when transmitting
Turning off while transmitting is typically a sign of a weak or bad battery. However, since you mention it happens with either battery type, another cause might be the length of time you are depressing the PTT button. These radios have a fail-safe to prevent damaging the final amplifier of the radio. To protect itself the radio will shut down or stop transmitting after the PTT button is held in too long. This being said, I'd check the batteries first. The rechargeable battery pack which came with the radio has a one year life expectancy. A battery can test full when it is weak and might not hold the charge when placed under a load. And usually transmit is the first thing to fail.
Best regards.
Jan 24, 2012 | Motorola MJ270R Two Way Radio
When i turn my car on the my avic-f90bt pioneer goes on but after about 20 seconds shuts right off again and continues doing the same thing over and over again
Check your wiring. Sounds like you've got a bad ground, or missed a 12v source somewhere. Remember - There is a 12v constant that keeps your radio constantly tied in (so your clock stays correct, etc) and a 12v Ignition/ACC which tells your radio when you've turned the car ON or in ACC mode (which turns the radio on).
If you've mixed the two up, you'd probably get the results you're getting.
May 11, 2011 | Pioneer AVIC-F90BT GPS Receiver
Delphi MiFi
xm radio shuts down , then starts back up again with no intervention.
Oct 03, 2007 | Delphi MyFi SA10113 XM Radio Receiver with...
RIM BlackBerry 8700g Smartphone Logo
435 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
