Question about Samsung L77 Digital Camera
Problems to find a proper USB-cable - Samsung L77 Digital Camera
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Samsung Master
  • 102,366 Answers
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Posted on Apr 08, 2011
The battery is not charging
You can try and reset the player. resetting a Clip player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly.
Some things to check for when your player does not act like its taking a charge.
USB Cable Make sure that the USB cable is properly plugged in and use the original cable that came with your player.
Computer in Hibernation mode Make sure the computer isn't entering hibernation or sleep mode while the device is connected. The computer must be ON in order to charge your player.
USB Port 2.0 Make sure the player is connected to a USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location Try plugging into different USB ports (i.e. USB port in the back of the computer); occasionally the front USB ports have limited power to charge up the device.
Battery Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
Latest firmware Depending on what Sansa player you have, make sure it's up to date with the latest firmware.
AC charger (optional) AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port.
I have some tips posted here on MP3 players and their problems. Connection problems MP3 player not found by computer
SanDisk Mp3 Player Frozen
Dec 25, 2010 | SanDisk Sansa Clip MP3 Player
External hard drive 3,5" few months it was working properly, and it says usb device not recognized and it doesnot show up. please for solution
Hello sir/ma'am, hi, most likely you have cable problems, check and see if you can find another cable. The cable is the USB data cable, that connects from your PC to the external hard drive.
Please also check if your USB port is working fine, just simply plug in a thumb drive to confirm.
If its not the cable, its the external hard drive. Usually, the red light appears or the device is reading the drive continuously with no action. let me know your progress.
Aug 13, 2010 | Verbatim VER95327 USB Hard Drive
No connection beetwen my Sony ercsson p900 and my computer by usb
hello there!!! thanks for using Fixya.com!
just a little information...
PDA USB Sync/Charger/Data Cable for Sony-Ericsson P800,Sony-Ericsson P900 Features:
  • USB Sync/Charge Data Cable for Sony-Ericsson P800,Sony-Ericsson P900
  • Auto Sync with computer in USB port and charge Sony-Ericsson P800,Sony-Ericsson P900 PDA with same cable
  • Directly connects with USB port, need no extra power
  • Plug and play, need not software installation
  • Eliminates the need for cradle and AC/DC converter when traveling
  • Compact, lightweight and easy to use
  • One of the best USB hotsync data cable for Sony-Ericsson P800,Sony-Ericsson P900!
    If you experience problems when using the USB cable during synchronisation:
    1. Check that the USB cable is properly connected to the phone and the computer.
    2. Make sure the phone is turned on.
    3. Restart the computer, without disconnecting the USB cable or turning off the phone, and try to synchronise again.
    4. If you still experience problems using synchronisation software, e.g. Sony Ericsson PC Suite or Active Sync, try to uninstall and reinstall the program you are using.tang-shop_2031_105590869 Or you may go to this website for further information http://www.sonyericsson.com/cws/support/phones/detailed/usbcableissues/p900
  • Feb 09, 2009 | Sony Ericsson w580i Cellular Phone
    Can't sync my P1i
    this might be the case. if not enable active sync on phne
    good luck
    Jan 16, 2009 | Sony Ericsson Cell Phones
    Samsung E900 USB Socket
    the phone cant cherge thru usb buy a new chaarger
    Apr 13, 2008 | Samsung SGH-E900 Cellular Phone
    Garmin legand c
    Just some suggestions:
    Have you tried another USB cable and/or another USB Port?
    The cables are not fault proof and yours may be damaged.
    After testing the cable, if you are still unsure of the cable, try the USB cable with another device to see if it will work with the other device. If yes, then it is probably not the cable.
    Your comment "I can hear it ding when pluged in but says the proper plug in is not there" suggests a software problem.
    Did you Uninstall the driver before trying the downloads and factory disk? Try this but use the factory disk in the first instance as this worked before (you can update later).
    Have you gone in to Device Manager to check to see if there are problems with any of your hardware (especially the USB Controllers and the GPS Unit itself. To find Device Manager - RIGHT click on My Computer - select Properties - then click on Device Manager.
    Problems show up as a yellow exclamation mark.
    If you see any of these - RIGHT click the device - go to Properties - and select Reinstall or Update driver.
    Note: These instructions are for Windows OS.
    Good luck.
    Apr 09, 2008 | Garmin 010-00358-00 GPS Receiver
    I cant put pictures onto computer?
    you have several options.
    1. see first what operating system you computer runs.
    if it is vista or mac, it will be recognized as unknown device,
    look for SSCAM100 or DCIM folder. you will then see the camera files in that folder.
    2. you should also download the cd driver, the cd that comes with the camera, to your PC. this will help the connection be proper.
    3. if you're using desktop, try to connect the camera at the back of your tower. look for a USB port at the back of the tower and connect USB cord to it.
    4. make sure you're using the proper USB cable, the cable that comes with the camera. for your S630, it is USB cable type 2.
    5. also, make sure before you connect camera to PC, camera is turned off, when the USB cord is properly connected, that is the time camera should be turned on.
    6. when unpluggin the camera to PC, make sure that you are safely removing the device from the PC so you will not have future connection problems.
    hope my suggestions work for you.
    Jan 06, 2008 | Samsung Digimax S630 Digital Camera
    General USB Troubleshooting
    While USB connections are significantly faster and easier to set up than older serial or SCSI connections they are not foolproof. Here are some tips: Be sure to connect the cable properly One side of the cable is "keyed" so it will only fit properly one way. Do not force it in if it does not smoothly connect. Notice how the USB plug is "keyed" and will only fit properly in one direction. The USB connector on the back of the computer. Connect directly to a USB port on the computer. While USB hubs allow many devices to connect to a computer they are not always reliable for high-speed connections like digital cameras. Connect to a port on the back of the computer. Many computers have extra USB ports on the front or on the keyboard. These are generally built-in hubs which may cause problems as described above. Connect to an AC adapter or use a freshly charged battery To prevent problems during transfer be sure that the camera has enough power to complete image transfers. Remove other devices To troubleshoot problems, remove any other USB devices and connect just the Nikon product for testing.
    Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
    Samsung L77 Digital Camera Logo
    24 people viewed this question
    Top Samsung Cameras Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Are you a Samsung Camera Expert? Answer questions, earn points and help others
