Question about Toshiba Televison & Video
When I push the power button on the Toshiba 36A13 (on the set directly or from the remote), it clicks on, then clicks off, and the red power button flashes. The screen stays black. Any ideas?
  • Toshiba Master
  • 17,130 Answers
For sure the power supply is working but the main drive is tripping off. What can be done is to open the set and check on the main circuit if there is any drive component/IC that is heating when the set clicks and cuts.
If so disconnect the power supply and check for a short in this section. Disconnecct the suspected component noticed heating- disconneect power supply to it- and if the set power on then change this compoent.
It can be shorted capacitor, coils,transistor, diode or an IC.
Posted on Sep 06, 2010
Toshiba 32A41 32" TV - I turned the TV off at the power switch on the front of the TV. The solid red LED turned off as it has for 12 years. NOW, neither the remote nor the power switch on the front of
Sounds like the power supply is down mate unless it's just a fuse replacement it's probably more cost effective to buy a new one.you could try gumtree or eBay for one with a damaged screen.
Dec 01, 2014 | Toshiba Televison & Video
My tv has a red button on the front that flashes and no picture comes on when we try to turn it on with the remote
The Toshiba sets were well known for bad capacitors in the power supply. I recommend getting it assessed.
Mar 19, 2012 | Toshiba 32AX60 32" TV
I purchased a GE Universal remote and I do not know the code to set up for MV20FM4. Please help.
HelloHello
You haven't given the model number of GE remote you have purchased. Yet I hereby give you some universal remote codes for Toshiba TV/VCR combo. Try with these. If you fails to synchronise with; inform me the model number of your GE Universal remote:
Four digit codes for Toshiba TV/VCR combo are: 0260 0358
Three digit codes for Toshiba are: 013/ 049/ 089/ 105/ 109/ 117/ 118/ 120/ 159/ 178
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK. Thanks for using Fixya.
Apr 07, 2011 | Toshiba MV20FM4 20 in. TV/VCR Combo
Need a universal remote for the above my grand daughter pushed the on/off button into the cabinet and now cannot turn it on or of?
Hello
Just buy one Philips Universal Remote Control Model number [CL 034]. Your Toshiba TV is listed in its codes. Codes are:
0517 0419 0512 0613
........................... 0719 0112 0506 0111
........................... 0618 0627 0437 0041
................. 0094 0802 0111 0313 0715
Direct Code Entry
1. Press and hold the CODE SEARCH
on, then release the CODE SEARCH
button.
flashes.
NB: Switch OFF and switch ON your TV WITH ITS FRONT PANEL POWER ON/OFF SWITCH EACH TIME before trying an other code. OK.
Feb 19, 2011 | Toshiba 35A44 35" TV
MY Toshiba 65H93 doesn't come on.When I press the power button nothing happen.But when I unplug the it from the AC outlet and plug it back into the AC Outlet I here a clicking sound, but the set still...
Same here! Just happened yesterday after we had a power outage in the neighborhood and when the power to the neighborhood was restored my 65H93 would not power on with the remote or the power button on the front of the TV. I get the same clicking sound when unplugging and or pushing the reset on the front of the TV. I also see a red light come on inside for about a half a second after hitting reset or unplug/replugging it in. I'm thinking it has something to do with the standby circuit not coming on due to some problem with the power supply/circuit board?
Have you found out anything yet? I'll let you know if I find out anything also.
Thanks
Jul 18, 2010 | Toshiba 65H93 65" Rear Projection...
Red Hue
Go into the service menu and turn down the red push and red cut a few notches. Write down every value in the service menu and be careful to make sure you don't change anything else. Also, turn down the brightness a couple of clicks and the red glow will be gone.
Or, try this - Press Mute on the remote control twice, press Mute a third time and keep holding at the same time, press the Menu button on the TV front panel. If you do it correctly, you will see a small S on the screen. Congrats, you are in service mode. Press Menu on the remote to get to the adjustable settings. Be careful not to change anything without writting the original value down first. Also be careful of hitting other buttons on the remote. To reduce red push, Use the channel up down button until it says RCUT. Adjust the value using the volume button on the remote. I recommend setting RCUT to 80H, which is the preset value according to the service manual. To exit Service Mode, simply power off the TV. Good luck.
Jul 04, 2010 | Toshiba 51H84 51" Rear Projection...
Programing my toshiba ct-90157 remote to a sanyo dvd player
you can set up any like this
1. turn on what ever you want set up
2. press and hold set up tell light blinks or stays lit
3. push what you are trying to set up t.v. or dvd ect.
4. push power on/off tell it turns off
5. push enter when it turns off
Thank you for useing fixya please rate me
Feb 11, 2009 | Toshiba CT-90157 Remote Control
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
How to use Toshiba 32D46 32" TV with Comcast 3 in 1 Universal Remote Control
Most univ. remotes have a search mode if code entry won't work-
Do you have the comcast instructions ? Something like.....
1) Tv power on
2) Push set-up or program on remote
3)Touch tv button on remote
4) Point remote at TV and push power off. Repeat until TV turns off.............then
5)Push enter to save....
Hope I helped you........T.
Nov 07, 2007 | Toshiba 32D46 32" TV
Televison & Video Logo
85 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
