Question about Samsung SGH C450 Cell Phone
I need display track solution - Samsung SGH C450 Cell Phone
Forme mobile not on pls track solution
Posted on Feb 23, 2011
What does the "code" 5E mean on the Audiostrider 990 Pro
Go to Nordic track and find out:
http://www.nordictrack.com/
Jan 20, 2013 | Nordic Track NordicTrack AudioStrider 990...
Onboard LCD display
did you try to insert a different cd? see the settings like OSD button on the remote control or display to view the tracks.
CHARCOIS
Sep 13, 2008 | Toshiba SD-4900 DVD Player
Denon CD deck
This unit needs a service visit. It may be a common problem with that model but to me it sound like a power supply issue as when you play a disc more power is used to rotate motors and move the sled. This is indicating to you that it is in a weakened condition and will soon fail more significantly. The problem may be as little as a solder joint or a defective Filter capacitor which is common in some models of equipment.
Dec 11, 2012 | Audio Players & Recorders
Just hooked up a kdc-4019...its asking for a code and i dont have a remote...can anyone help me ?
I was looking around and found these instruction that resets code but you need a remote to do this, i dont think there is anyway around without a remote.
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that "..." disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
IN YOUR RADIO: DISPLAY WILL ASK FOR CODE AND CODE ---- APPEARS ON, SO, HOLD .DISP AND PRESS VOL UP AT LEAST 3 SECONDS. THE "----" WILL DISSAPREAR. NOW TAKE YOUR REMOTE AND DIGIT "KCAR" WITH THE NUMBER PAD.
PRESS "5", "5", >>' (NEXT TRACK) YOU GOT A "K"
PRESS "2", "2","2" >>' (NEXT TRACK) YOU GOT A "C"
PRESS "2", >>' (NEXT TRACK) YOU GOT A "A"
PRESS "7", "7", YOU GOT A "R"
PRESS >>' (NEXT TRACK)
IF DISPLAY SHOWS "APPROVED" YOU'RE DONE ;)
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key "5" ( 2 times ) and press the Track UP/Next Track key
* Press numeric key "2" ( 3 times ) and press the Track UP/Next Track key
* Press numeric key "2" ( 1 time ) and press the Track UP/Next Track key
* Press numeric key "7" ( 2 times ) and press the Track UP/Next Track key
push buttom "track up" for 3 seconds
The security is canceled and the set enters the TUNER mode!
Feb 06, 2011 | Kenwood KDC-4019 CD Player
Phillips cdr775/00 how do i record from laptop headphone socket into recorder i n=have tried my usual lead jack to two phonos it says start source when i do no signal comes into recorder analogue in
MANUAL RECORDING FROM COMPUTER HEADPHONE SOCKET.. FIRST RIGHT LEAD REQUIRED YOU NEED STEREO 3.5mm stero jack plug to lef right phono male leads... prepare for manual record place jack in computer headphone socket. check correct socket play track on computer their should be no sound. if sound present in wrong socket... if ok place phono left right into analogue aux inputs on cdr recorder.next make shure you have blank scratch free cd .next press ext(ernal) source repeatedly until the required input is selected i.e digital analogue optical etc..when auto track is on the disk will number automatically.with auto track on it their needs to be 2.7 second gap to rec number change. with the recorder stopped press rec type five times to enter in the manual record standby mode. manual start s to flash and the display shows REC EXT MAN followed by WAIT.after a few seconds press record . play the source track ie on your computer to set record level on cd recorder.. adjust audio card settings or volume control on pc etc .rotate easy jog/enter key until on the record /play level bar all the blue led are alight but not the red( clipping) display shows xx decibel eg 3bd. stop the source material (track on computer get ready to record ii.e to start track again..to start recording set you track going wilst pressing RECORD on the cd recorder, and immediatley the source material playing. the track number and recording time left appear in display . if check input message is displayed check the connections are correct etc .to stop recording press stop on cd recorder . update lights up and arrow goes out. after recording display will show UPDATE FOR SEVERAL SECONDS WRITTING TOC.. IF YOU WANT TO PLAY THIS DISC ON NORMAL CD PLAYERS YOU NEED TO FINALIZE THE TRACK . HOPE THIS HELPS..yammandan.
Aug 19, 2010 | Philips CDR775 2-Disc CD Recorder
Tracking storage options GPSMAP 295
Every waypoint in the track has date/time, altitude and position. Second and subsequent waypoints will enable calculation and display of leg length, time, speed and direction between each par of points. The track can be displayed in 3D; in Google Earth for example. As far as I know there is no way to change the interval.
Jul 13, 2009 | Garmin GPSMAP 295 GPS Receiver
Masterlink ml-9600
To delete a Track from a playlist, you must currently have that Track selected in the display. Pressing the DEL TRACK button will cause a confirm delete page to be displayed,where "Song 01" is the name of the Track to be deleted. Pressing UP/YES will remove that Track from the playlist, moving the next Track in the playlist in its place. Pressing DOWN/NO will cancel the operation and return the unit to its previous state.
NOTE: Deleting a Track from a playlist does not delete the audio samples from the hard disk. The audio remains on the disk in an "Audio File"
Jan 15, 2009 | Alesis MasterLink ML-9600
Need user manual
I have the CDR-200 and did not have the manual either. However, I did discover the same problem and found the solution. There is a "confirm" button on the front of the unit under the display area. After you press the record button "Record" will begin to flash in the display area and then you press "Confirm". It should start recording. Note however the following:
BURNING FROM EXTERNAL CASSETTE OR PHONO
Before starting this procedure make sure you have an AUDIO recording CD in the RECORDER tray of the CDR-200. A regular CD-R type of disc for computers is not going to work and may cause an annoying message on the display which does not go away until you put the right type of recording CD in the unit. It must be either an AUDIO CD-R or an AUDIO CD/RW.
1. When copying from an external cassette deck, you should set the source (press source button) until the setting is "Analog".
2. The "Dual" button should not be in effect. In the lower right portion of the screen you should only see a small number "1" with a circle around it. This indicates the CDs currently being used by the burner. In "dual" mode you can copy from the Playback CD of the CDR-200 to the Recorder CD. In dual mode you see "1" and "2" with circles around them. The active CD tray will flash on the display.
3. When copying from an external cassette unit, you use the "Record" button to start the recording. At the end of the cassette track you MUST press the STOP button by the CD Recorder tray. After you press STOP the unit will say "Update" which indicates it is closing out the track on the CD-R. You can continue to write tracks by pressing RECORD again, then CONFIRM when the tape is positioned at the right PLAYBACK track. It is usually helpful to have a few seconds of blank tape at the start of the PLAYBACK track before pressing RECORD. Press play on the cassette deck, then RECORD followed by CONFIRM on the CD burner.
4. When the track has finished burning you must press STOP to close the track on the CD-R. After you press STOP, the unit will display "Update" to indicate it is updating or closing the track. When the process completes, the unit will display the tracks it has written to the CD-R and will be ready for you to copy another track or FINALIZE the CD-R. When the unit is waiting after the STOP, you can change the cassette tape, reposition to a playback track and ready the playback tape for more recording. When the PLAYBACK tape is ready repeat STEP 3. Repeat steps 3 and 4 until you have about 14 or 15 tracks on the CD-R.
5. When you have finished recording about 14 or 15 tracks onto the CD-R, you will want to finalize the CD-R. Press the FINALIZE button, and then press the CONFIRM button. You will see the the unit start to display the progress of the finalize by advancing the level meters of the left and right channels in the display. When the unit is finished finalizing it will return to the number of tracks display for the CD-R. After finalizing the CD-R you can play it back to make sure the burn was successful. Be sure to wait for the tracks display before removing or playing the CD-R after the finalize is done. Removing before the finalize is done may damage the unit and may render the CD-R bad.
BURNING FROM THE PLAYBACK CD
1. Set the unit to "Dual" mode. As described above, you will see "1" and "2" with small circles in the lower right portion of the display.
2. Make sure the "Source" mode is set to "Analog" by repeatedly pressing the SOURCE button until it shows "Analog".
3. When copying from the PLAYBACK CD tray you will not use the RECORD button by the CD Burner tray. You will use the 'DUB" button just to the right of the display.
4. Put an audio CD in the PLAYBACK CD tray and press the skip track button ">>" until you arrive at the track you wish to record from. If the track you want to start at is track 1, then you don't need to skip tracks.
5. When positioned at the correct playback track, press the DUB button. The unit will show "CDR" and then "DUB" on the display. When it says "DUB" press the CONFIRM button. The unit will start recording. You can adjust the record level during the first few seconds to make sure you don't have the recording volume level set too high.
6. When the track is finished, you should see the unit indicate on the display "Update". This indicates it is closing the track and it should do this automatically. If it does not do this you may have to press STOP near the RECORDER Tray to force closing of the track. Usually the unit indicates "AUTO" in the display area and I believe that is what controls the automatic track numbering feature. I am not sure how the AUTO feature is turned on. I noticed on the CDR-200 it is on by default.
7. After the UPDATE is complete, the unit will display the number of tracks it has written to the CD-R. You can at this point change the PLAYBACK CD to another one or advance to another track for continued recording. When at the correct track simply go back to step 5 and continue.
8. When you are all done copying tracks from one or more CDs, and you wish to finalize the CD press FINALIZE and then press CONFIRM to start the finalize process. I noticed on the CDR-200 if you wait too long after recording a track the unit may start the finalize process automatically. This happened after at least 5 minutes. It is best to try and stay with the copy process to monitor what is happening. The finalize can also start if you have written to many tracks to the CD-R and it runs out of space. Typically, your safe if you burn about 14 to 15 tracks to a CD-R at a time. You might be able to fit more if the tracks are very short (2-3 minutes each).
One last note about the connections on the back of the unit. Read the labels of the connections on the back very carefully. The CDR-200 and probably the 201 have separate outputs for the PLAYBACK CD (CD) and BURNER CD (CDR). You will want to connect these to seperate inputs on your audio amplifier. Or you might also wish to merge them using adapters into one input on your audio amplifier. If you keep them separate you will need to change sources on the audio amplifier to hear each tray. For example, you might need to switch to "CD/TAPE" for the CD, and "AUX" for the CDR. It is probably easier to merge the two using audio adapters which can be readily obtained from RadioShack.
I hope this helps!
May 08, 2008 | Classic Electronics CDR201 CD Recorder
No tracks displayed on Z10's when using creatives mediasourse player
Dear lamby111
You can check the settings and in that u may choose the display options. But u need to go through the entire settings.
Feb 02, 2008 | Logitech Z-10 Computer Speakers
Tracking display will not go away
Try unplugging the unit for 30 minutes and see if that takes care of it. Just turning it off won't clear it because as long as power is coming to it ex. plugged in, it won't clear. If that doesn't take care of it you may have a problem with the selector board. If so get yourself a new VCR as it will cost more than it is worth to fix it.
Jan 14, 2008 | Toshiba W522 VHS VCR
Samsung SGH C450 Cell Phone Logo
52 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
