Avol - portable dvd player pdvd718 it no longer plays dvds is there an easy way to clean them
Noggin
  • 944 Answers
SOURCE: whats region 1 dvd?
dvds are coded differently depending on which region of the world they are intended for. there are eight regions - check this link for more info; http://www.amazon.co.uk/gp/help/customer/display.html?nodeId=502554 this was a pointless idea that was supposed to limit video piracy, but only actually causes problems and increased production costs The US is in region 1, so the problem is the settings on your dvd/vcr as to what region it is coding the discs as. You may be able to change this in one of the menus, but it may be designed for only one region code output. Check the manual - if you need a manual or have trouble then please post the make and model of your dvd vcr recorder and we can try to help Hope this helps you :)
Posted on Mar 24, 2007
SOURCE: DYNEX DX - PD510 Portable DVD Player
I contacted Dynex via their website, I received a reply the next day will all sorts of "standard" things to do, clean the disk, make sure it is a disk for region 1, turn it on with the power supply plugged in, it may be moisture, leav it on for an hour with no disk etc. I had already tried all of these things including a 24 hour turn off, no joy, they didnt listen to the symptoms I had sent them. WHen I replied to them they said I needed to call their support line in the United States and they would assis me, I replied by email that a call from Aus to US would cost more than the unit if I had to wait in a queue and asked if we could please solve the problem by email, I have not had a reply and it is 5 days later. They acted like no one else has had the problem which of course is garbage, If I dont hear from them I will contact our Consumer Affairs people and make a complaint, they are still selling the DVD players in Australia, annoying isnt it?
Posted on Nov 17, 2007
SOURCE: Insignia Portable DVD Player does not play DVDs - says no Disc?
Posted on Jan 12, 2009
  • 814 Answers
SOURCE: dvd player will not reconize a dvd when trying to play
Try cleaning the dvd compartment of all dust and debris with a can of compressed air. Check and make sure all the dust and debris is cleared of the laser transport and lens. Use cotton swabs and small amount of isopropyl alcohol to clean off the laser lens and tracks and gears of the transport . Use a cotton swab with a small amount of alcohol on the tip to clean the laser lens. Rub the swab gently across the lens, until it appear bright and shines. Use the other side of the swab to remove any excess moisture from the lens. Use cotton swabs to clean the rails and gear of transport. Applie small amounts of alcohol to the tips to loosen caked on dust or dirt. Use compressed air again to clear the dust and debris from transport area. After the through cleaning. Try the player again, using a dvd to see if the operation returns to normal. If not, try resetting the dvd player to factory setting. You can do this using the on screen menu to go into the settings. Use the remote control and press the settings button. Use the up and down arrows to highlight the preferences section and press enter. Once in the sub-menu use the up and down arrows to highlight the default function and press enter. This will have reset the dvd player to the factory settings. Now try using a dvd to test the player to see if it operates normally. If it does not play normally, you may have a proplem with the spindel, check it to make sure its is making good contact with motor, if it appears loose, applie a drop of super glue to snug up the grip. After it dries completely. Test the player again with a dvd. If the unit still fails to operate normally, you may be having problems with either the drive motor or the power supply circuits. For these problems you need to contact a service center. They will have all the service information to troubleshoot these problems properly. You can call Phillips customer support at this telephone number 1-888-744-5477. They will be able to tell you how to get the dvd player tested and serviced. I hope this information helps you with your problem.
Posted on Jun 01, 2009
brownline45
  • 310 Answers
SOURCE: Sony portable DVD player wont load DVDs
maybe the spindle motor is defective so it cannot read the disc. just bring that your dvd to sony service center to fix your dvd.
Posted on Jun 19, 2010
Grinding noise whle movie plays on portable dvd player
Is it happening with all the dvds you play on it, if so then you should clean the drive with a branded dvd drive cleaner.
Jun 09, 2012 | Philips Televison & Video
Problems reading dvds
Have you tried cleaning the lens of the portable player? You can purchase a DVD cleaning disc, this disc has microfiber brushes which clean the laser len assembly of the player as the disc spins.
Hope this helps
Jul 06, 2008 | Televison & Video
Foreign disc messed up portable dvd now it wont play british dvds
Croikie!!!
See if there's a factory reset option in the menu
Also,try cleaning the laser lens with 90% alcohol and a swab ( Gently) then buff it dry
Apr 19, 2010 | Sony DVP-FX811K 8 in. Portable DVD Player...
Portable dvd player will not play dvds
I cleaned the eye of the dvd player that reads the dvd's
Jul 17, 2009 | Akai Televison & Video
After playing a cd in unit will no longer read DVDs
Had the same symptom. The unit would play CDs but not DVDs. The DVD laser was at fault. Purchased and replaced laser unit KHM-313AHC (ebay- $20) and it now works fine.
Jul 16, 2009 | Disney D7500PDD Portable DVD Player
Plays cds but not dvds
If the lens is clean (clean with cotton swab and alcohol), then the optics are failing. DVDs require more power and accuracy to be read than CDs. The ability to read CDs but not DVDs is usually a good indication that the optics are starting to fail.
Dan
Feb 18, 2009 | Televison & Video
DVD Player freezes on some commercially produced DVDs
The microprocessor or memory componets on the player isnt functioning asits supposed too. This is rather troubling and there isnt any easy fixes possible.. My suggestion is seeing as its new return it and get a replacement. Chances are it will fail very soon.
Jul 09, 2008 | Insignia IS-PDVD10 Portable DVD Player
Won't play some DVDs
ya try cd lens cleaner ok they sell at store its a cd with litte brushes on it cleans lazor ok thx nick
Feb 11, 2008 | Mintek MDP-1010 Portable DVD Player
Televison & Video Logo
367 people viewed this question
Top Televison & Video Experts
Electro Med Services...
