Question about Fisher and Paykel IWL12 Top Load Washer
Instruction panel screen is blank - Fisher and Paykel IWL12 Top Load Washer
  • 343 Answers
If power is getting to the machine and the screen is blank it's likely that a fuse or a circuit has failed. This could be because another component in the machine has failed and caused the main controller board to overload, or the main board itself has failed.
Either way you should call a F&P tech, so that the board and/or the other components can be tested. If you replace a main board without checking the rest of the machine it's highly likely that the same fault will cause the board to fail again.
A tech from F&P will warranty the work and save your investment.
Probably not what you wanted to hear, but absolutely the best course in the long run.
F&P machines are easy to work on and test, so the job shouldn't take too long.
Good luck....Nomess
Posted on Sep 06, 2010
What parts to fix a blank screen besides power supply and main boards (have tried both)?
STOP Get a SERVICE MANUAL and follow instructions before you make it any worse by "Mucking around with it" it needs to be serviced in a set careful methodical way u cant just replace boards and hope as those boards may damage or be damaged, to have any chance u need to get the book plain and simple less expensive too.
Aug 21, 2015 | Toshiba 39L1350U 39" LED TV 1920x1080, 120...
Problem with setting up PC mode on my LE40S7 LCD TV
hi it shouldnt matter to much its just a guide line just might mean you get a less clearer picture if you was watching say a dvd but your telly should still let you acess this menu have you tried acessing the menu without the laptop plugged into it let me know ok
Feb 11, 2008 | LG 42LC2D 42 in. LCD HDTV
Philips instruction manual
YOU NEED TO REPLACE BAD CAPS ON MAIN POWER BOARD 4167e67a-4c77-4574-ae00-a26d52afd0ea.jpg
Jul 29, 2014 | Philips 42PF5520 42 in. EDTV-Ready Plasma...
Hi. My lcd 32 LG2000 tv has locked remote won't work, buttons on side of tv won't work and it has a blank screen.then about a minute after pressing them keylock appears on screen and I don't know how to...
Have you the instructions?
There is a proceedure contained in the vast instruction manual.
Not sure, I believe there is a reset button ? or a sequence to restart.
Dec 26, 2010 | LG 42LC2D 42 in. LCD HDTV
How to change the Windows Logon screen saver from GPO
OK I know how to change the logon screen saver. I have a small batch
file to do it as part of our install process and it works. What I
would like to do is use our university logo and have it move around
the screen.
How do I have my scr file move around the screen like logon.scr ?
---blank-scr.bat---
:: Install a blank screen saver
@echo off
copy /y %Z%\packages\blank.scr %WinDir%\system32
:: Change logo screenscaver from logon.scr to blank.scr
reg add "HKU\.DEFAULT\Control Panel\Desktop" /v SCRNSAVE.EXE /t REG_SZ
/d blank.scr /f > nul
:: Change blanking time to 60 seconds
reg add "HKU\.DEFAULT\Control Panel\Desktop" /v ScreenSaveTimeOut /t
REG_SZ /d 60 /f > nul
Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Nov 11, 2009 | Microsoft Windows Server 2008 Enterprise...
Dell 6000 laptop screen blanks out - bought new screen
ManualsBack to Contents Page
Display Assembly and Display LatchDell Inspiron™ 6000 Service Manual
Display Assembly
Display Bezel
Display Panel
Display Latch
Display AssemblyRemoving the Display AssemblyCAUTION: Before you perform the following procedures, see the safety instructions in the Product Information Guide.NOTICE: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as the back panel) on the computer.NOTICE: To avoid damaging the system board, you must remove the main battery before you begin working inside the computer.
  1. Follow the instructions in "Preparing to Work Inside the Computer."
  2. Remove the hinge cover.
  3. Remove the keyboard.
  4. Open the display all the way (180 degrees) so that it lies flat against your work surface.
  5. Remove the four M2.5 x 5-mm screws (two on each side) that connect the display assembly to the computer.
  6. Loosen the screw that connects the grounding wire to the system board.
  7. Use the pull-tab to disconnect the display cable from the system board.
  8. If a wireless Mini PCI card is installed, disconnect the antenna cables from the card.
  9. Lift the display assembly from the computer.
Apr 06, 2009 | Dell Inspiron 6000 Notebook
Samsung 204B random blank screen
I too have a dual monitor Samsung SyncMaster 204 setup. My monitors started flickering, then a week later had turn on problems like your describe. I found a fix on this fixya website and followed the fairly techie suggestion. It worked. I wrote up a .pdf set of instructions so others might also benefit. Hope this helps. Doug
Feb 07, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
Turn on Laptop gets to desktop with icons then screen goes blank
By "where I want to go", do you mean going on the internet? If all you are getting is a blank screen, then you have the "about:blank" virus. Go here, print out the instructions, and read them well. Then read them again and follow them closely. At one time I had it on a desktop system and the instructions worked just fine.
Dec 10, 2008 | HP Compaq nx7010 Notebook
Phaser 6350 dp
If it is totally blank the control panel needs replaced (LED screen)
Xerox has been replacing those for free...go to xerox.com
This is a customer replacement item. Instructions can be found at:
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=254,E=0000000001178576660,K=1045,Sxi=3,Solution=obj(3229)
If you need further instructions, a video link is at the bottom of that page...
Aug 24, 2008 | Xerox Phaser 6350DP Laser Printer
Fisher and Paykel IWL12 Top Load Washer Logo
64 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
