Question about Jenn-Air JCD2389G Side by Side Refrigerator
My frig side is freezing everything no matter what the setting is on. I have it turned off now in hopes that it will defrost again then start working properly. Any help
    President:
  • 2,468 Answers
You need to replace the main board in the rear of the unit as the compressor relay is stuck on this board and wont let the compressor cycle on and off per cold setting
Posted on Sep 06, 2010
My compressor will not switch back on after I replaced defrost heater, defrost thermostat and thermistor.
A proper diagnosis must be performed on this unit to determine the sequence of operation. So far, you have verified that it doesn't operate correctly. Parts have been changed, so it is now impossible to troubleshoot the unit from an armchair. Time to either grab some test equipment and a manual and start diagnosing or to call in a tech who can figure out what went wrong.
Feb 15, 2015 | Frost Refrigerators
My Maytag side by side refrigerator [mod. #MSD2656KES, Serial #50518503JL] is freezing everything on the frig side on the two top shelves. Coils have been cleaned. Temp set:Freez=3, Frig=2. One week ago...
I have this same refrigerator, also purchased in 2006. Same exact problem. Fridge freezes, starting actually in the water line, you will notice water on door does not work, then top two shelves start to freeze. Lasts for a few days, then prob does not happen again for 6 months almost to the day. I've had this problem for almost 3 years!!! My service tech said to buy another, glitch in this system he can't figure out. Replaced damper x2, control board, and thermostat x2. Not sure what else to do. I hate the thought of more food lost to spoilage!
Aug 09, 2010 | Maytag 25.6 Cu. Ft. Side-by-Side...
Ge frig does not freeze on freezer side
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frig Freezing EVERYTHING!
Your refrigerator has electronic dampers that may be only stuck. I think it would not hurt to defrost the refrigerator and lets have a look at those damper motors and see if they are responding to your control settings. Let me know, Sea Breeze
Jun 17, 2009 | Samsung 26.0 Cu. Ft. Side-by-Side...
Temp is erratic too warm, too cold ....
Sounds like the defrost timer is not working correctly or the start capacitor is malfunctioning,Both are cheap and easy fixes.
May 09, 2009 | Refrigerators
Everything in frig is freezing no matter what setting we put it on
It looks like the refrigerator won't stop running not matter what temperature you set the cold control and that is the problem ,its need to be replaced.
May 01, 2009 | Refrigerators
Kenmore side by side frig not cooling in frig comparment and
Something has failed in the defrost circuit-
Defrost thermostat
Defrost heater
Defrost timer
Reply back if you know how to diagnose electrical circuits, and I'll help you further.
Feb 01, 2009 | GE GSS20IEP Side by Side Refrigerator
HSS25IFMDWW- freezer frosting up but working
sounds like the defrost thermostat or you may have a crack in the water line causing the freezing.
Jun 10, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Defrost Problem
there is a drain in the middle of the defrost water collector and it is probably blocked - usually with ice. dry ot the tray and put very hot water in to melt the ice. you may have to do several times. do this until water flows away freely
Jul 25, 2007 | Maytag MSD2756G Side by Side Refrigerator
Jenn-Air JCD2389G Side by Side Refrigerator Logo
42 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
