Question about Canon USA LASER PRINTER CAB STD CB1701 Stand Cabinet
Bold Lines in printing paper - Canon USA LASER PRINTER CAB STD CB1701 Stand Cabinet
    Problem Solver:
  • 20 Answers
It seems that there might be some toner residue that got stuck on your printer drum and that is creating this problem.. use a soft piece of cloth and rub the lines off the drum through the gap at the front of the drum unit. The drum can be rotated by turning the gear cog on the side, then once the reside has been removed from the drum and it is clean, the lines will have disappeared. I wouldn't use any solution on the drum, just gentle rubbing should suffice.
Posted on Sep 13, 2010
Dell 2145cn won't print red properly
Check the red ink printer cartridge. also check the settings
Nov 07, 2012 | Dell 2145cn All-In-One Laser Printer
Bold lines on Fax and Scan
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.  2. Select "Clean and Fix Horizontal streaks."  Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.  2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.  3. Get a damp paper towel.  4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.  5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.  6. Next dab the cartridge on the towel to make sure that the ink is flowing.  7. Snap the cartridges back into the printer.  8. On your computer, select "Old Cartridge install."  9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
May 26, 2009 | Lexmark X7550 InkJet Printer
Bold black lines across the paper when printing,scan or copy not on faxing
I realise this is probably too late for you Janet and you will have bought a new drum unit by now or replaced the printer! The three lines appeared on my print-out from a new drum I installed and after investigation it transpired that there was some toner residue that had dried on the drum (from testing at manufacture stage probably) and reprinted three bold lines on a sheet of A4. The solution is to use a soft piece of cloth and rub the lines off the drum through the gap at the front of the drum unit. The drum can be rotated by turning the gear cog on the side, then once the reside has been removed from the drum and it is clean, the lines will have disappeared. I wouldn't use any solution on the drum, just gentle rubbing should suffice.
Apr 13, 2009 | Brother MFC 9180 All-In-One Laser Printer
Printing 2 lines on tab paper
I am printing on tab paper. Is it possible to have two lines print on a tab? If so, how? Thanks.
Mar 18, 2009 | Sharp MX-2300N Color Copier
Lines rule across my print out paper at photocopying mode
Make sure you don't have a scratch on the glass of the scanner. If you have a mark, or scratch that matches the line ruled on your print, then there is your problem.
It;s also possible the scanner is jerking as it goes across the bed, which is causing the line. Is the line solid, dashed, bold, thin or just kinda there?
Mar 14, 2009 | HP DeskJet F380 All-In-One Printer
Hp laser Jet 1018
While printing A/4 size a bold doted line appear on the rigt side of the paper from top to bottom
Apr 17, 2008 | HP LaserJet 1018 Printer
Bold letters in Acrobat 8
on adobe click on Edit>Preference>Page Display>Rendering>uncheck Enhance thin lines.
Mar 11, 2008 | Adobe Computers & Internet
Canon USA LASER PRINTER CAB STD CB1701 Stand Cabinet Logo
old marine
old marine
