Question about Numatic GVE370 Canister Wet/Dry Vacuum
Hi, My George Wet/Dry Vac started to make a popping noise in use and a burning smell, I blew out the motor of dust with compressed air and it seemed better, but then suddenly just died, the wet spray pump still works, just no extraction motor at all. thanks
George pump not working
Posted on Nov 16, 2010
Vacuum motor noise and smell
If the ball was stuck and you sucked water into the motor it could cause it to smell like it's burning if it ruined the motor
Jan 10, 2014 | Shop Vac Vacuums
Has a burning smell
Sounds like the brushes on the motor are wore and burning up the armeture,,how old is it?
Mar 07, 2011 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Wet vac motor making noise and smells like burning
Hi I would suggest that the burning smell and the noise will mean that the motor is burnt out. You can get them pretty cheaply from the internet and they are quite easy to fit.
Mar 04, 2010 | Henry Numatic "" Canister Vacuum
Motor makes loud racket and smells like burning, but still works.
Bag? There is a paper filter and maybe a foam filter ... bag? Maybe this is a newer model that I am not familiar with. Anyway ... ...
It sounds like your motor has been eating dust. Please check here for your repair: http://www.shopvac.com/support/
Feb 21, 2010 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
IT WILL NOT START - IT TRIES BUT DOES NOT TURN ON.
Unplug the vac and spin the acorn nut on the separator in the water reservoir. If it spins freely and this vac has run for a few years you may need a fresh set of motor brushes. Do not attempt to run the vac if the motor hums or makes a burning smell. Worn brushes are normal and can often be replaced in an older Rainbow/ Rexair
Sep 28, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Dust blowing right back into the air
You need to check the filter and make sure it's on all the way. To do this take the top off the vac, make sure the filter is all the way up and in place. There should be a plastic nut to hold it in place. If you are using it for fine dust particles such as drywall dust, you need a special filter for small particles. The filter that comes with the vac just won't do it!
Mar 23, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Have a Sears shop vac, mod 113.172. The motor doesn't take in
If the motor turns, you should have suction. Put the hose on the exhaust side of the motor if there is a connection, and try to blow it out. If you can't, try using a garden hose or toilet snake to clear the hose. IF the hose is clear, and the problem continues, check the float in the cage below the motor. It should be down at the bottom of the cage. Also, if you haven't been using a bag or foam cover for the cage, it is possible for leaves to clog the motor.
Mar 15, 2009 | Shop Vac 925-13 Canister Wet/Dry Vacuum
How do i go from dry vacuming to wet vacuming with the rigid shop vac
can I run my sears shop vac without the paper bag, for dry pickup?
Jan 29, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Shop Vac
You **** up water the same way as dirt. It's designed this way, hence the name wet/dry. Just be sure not to get the water in the very top of the unit where the motor sucks the air for cooling ventilation, if water gets in there it can burn up the motor. A little hard way, personal experience, speaking there.
Jul 16, 2008 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Numatic GVE370 Canister Wet/Dry Vacuum Logo
504 people viewed this question
Top Numatic Vacuums Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Numatic Vacuum Expert? Answer questions, earn points and help others
