My 5-year-old 15" set goes on fine but turns off by itself in 10 seconds. Not a cable issue, no electrical surges on other appliances--I have unplugged it for several hours and tried again, but the same thing happens. Reception is fine on other sets. Can this be fixed?
  • sharon_rosen Sep 06, 2010
    I am a viewer, not a technician. This is not useful information for me. Can you at least tell me what such a repair can cost?
    President:
  • 1,961 Answers
Hi !may i know the brand and model of your TV and lets begin thanks!
Posted on Sep 07, 2010
  • Televison & ... Master
  • 17,130 Answers
Can be the aging issue of dry soldering. If the fault is so consistent or evident on tapping of the set or if you think it is a thermal runaway., then it is important to take a look inside and check the areas of heat.
If you can solder these sections , take it as the first option.
however if the fault is very much time based it can be relative to the microprocessor which can be tripping off in a set schedule.
the fault can be fixed for sure but if the fault is with the microprocessor, then you will need to take some voltage checks to confirm tin the off and on state.
Posted on Sep 06, 2010
Hi my parents have a 10 year old Electrolux oven eob63100k it works for about 50 mins then turns itself off and after approx 15 mins comes back on again all by itself any ideas?
Thermostat issue when it reaches heat its set to it should turn off and then come back on when it drops below that temp
check if thermostat is clean
Sep 26, 2017 | Electrolux Ovens
When I turn on my Sony TV, ti stays on about 30 seconds then shuts off, What do you think is wrong?
Do a Power Reset.
1. Turn off TV.
2. Unplug the power cord of the TV from the electrical outlet.
3. Let the TV remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.)
5. Turn on the TV.
If issue persists after doing the steps, reset the TV to factory default settings.
1. Turn on the TV.
2. Using the supplied remote, press and hold the UP arrow button.
3. While holding the UP arrow button press the POWER button on the TV itself.
4. When the TV goes off, release the POWER and UP arrow button.
5. The TV will turn on by itself and the initial setup screen will be displayed. Just follow the on-screen prompts to finish the setup.
Sony KDL 46V5100 random shut off 15 20 sec
Feb 25, 2016 | Sony Televison & Video
Refrigarator not working after power outage
When power goes on and off suddenly, it can cause the compressor to overload and "trip out" This is supposed to protect the compressor from being electrically damaged. In most cases, after 10 or 15 minutes, the compressor will reset. It is usually safer to switch off the fridge or unplug it for 10 to 15 minutes to ensure a full reset. If it doesn't start, the power surge may have damaged the compressor relay. or overload device on the side of the compressor. I would doubt that it damaged the compressor itself. Be aware of the relay and overload device, unfortunately, there are Techs who will quote for a compressor job when all it needs is a relay or overload.
Feb 22, 2014 | AEG Refrigerators
Electrical problem with FA561XF
Could be the breaker. Sometimes breakers just get old and will not hold when a power surge goes through it as when an electric motor first starts up. You have already replaced the compressor with a new one so I would check out the breaker situation. STAY with the same size breaker
Nov 24, 2013 | Smeg Refrigerators
My tv screen begins to turn blue while watching tv.
The box may be the issue----try unplugging it and wait a bit and power it back to let it boot up--same with the set.
Also if you have a DVD player look to see if it has this issue or not.
Nov 04, 2012 | Vizio 42 in. LCD TV
Set is 7 years old - it turns off intermintently
Ours used to do that - and then we moved it to another state with us. Since the move it doesn't shut itself off anymore. I suspect that the problem was dirt and dust inside which got knocked loose in the move and the shutdown was due to thermal limits being exceeded. You may want to try vacuuming or blowing out the dust inside if you feel comfortable opening up the unit.
Feb 15, 2010 | RCA D52W135D 52 in. TV/DVD Combo
Lamp goes out after 10-15 seconds
Recently had a similar issue.
When I took the lamp out (Let it cool for awhile first), there was dust all over one side preventing air from the fans from cooling the lamp, so it shut itself off after getting too hot.
Apr 27, 2009 | Sanyo PLC XU48 Multimedia Projector
I have GE Madellion 870 Washing machine I guess I have motor problem motor stopr after smoke Now Motor spins for few second then stops after 15~ 20 minutes, it will run again for few seconds if my...
Hello ashankhan,
huuum,happy to assist you!
You said,
motor stops after smoke
if my motor burned then why it still runs for few seconds.
The motor is shot and it still works until it heats up, and then it binds up after it over heats!
How old is the appliance?
If the appliance is 10 years old or more you may not be advisable to put good money into bad! New appliances are so much more efficient today that they can save you a lot of money in energy.
Therefore they pay for them selves in only a few years.
You can buy New and save today.
Find the small privately owned and operated appliance store and you will get better service and good treatment! They also will be the best informed!
Bless You, let me know how it goes.
huuum
Please give me a good rating for my fine advice before you sign off.
Thank You
Sep 18, 2008 | Dishwashers
Washer smells like electrical burning
Peace aminajmay,
ngafm At your service!
Sounds like an electrical fault.
If I were there hands on I could be definite.
Only a hands on laundry tech can make the diagnoses.
BUT, how old is the washer?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
Bless You ngafm
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
Thank You
Sep 09, 2008 | Washing Machines
Wont work
Peace Friend,
Sounds like the coupling between the transmission and the agitator is broken!
Only a trained laundry tech can make the electronic diagnoses.
How old is the washer?
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
You will be fine
Bless You ngafm
I
Sep 07, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
