Question about Aiwa UZUS301 2 Speakers
Aiwa UZUS301 2 Speakers. Question: how do I open the satellite speaker boxes to re-connect cables which were ripped off accidentally. Can't find any screws to dis-assemble speaker enclosures.
  • spamyard Sep 06, 2010
    "gently separate" Guess you don't know me and screwdrivers! I'll give it a try though.
    Wasn't really expecting anything specific just wanted to know if there was a "trick" to it. There isn't.
  • 787 Answers
Those satellites don't have screws to hold the two halfs together, they use plastic clamps. Usually, those are placed one on the top and one on the bottom ... I'm guessing that's also how yours is built. Use a normal screwdriver to gently separate the two halfs to find the clamps' positions.
Posted on Sep 06, 2010
Do not know how to wire my sa-w10 speakers together
For surround sound, you need an A/V receiver with 5.1 or 7.1 surround capability. Depending on what kind of receiver you have, the DVD player, satellite/cable box, etc hooks to the receiver, those signals go out to the TV, and the speakers hook to the receiver. The receiver decodes the signal from the cable/satellite box or DVD player and routes it to the appropriate speakers. If the TV program or DVD isn't HD or coded for surround sound, the best you can expect is 2.1 channel stereo sound. OR, you can hook everything (DVD, satellite/cable box) to the TV and run an optical cable from the Digital Output of the TV to the receiver, which is basically the same thing, just a different way to hook everything up. Hope this helps
Feb 23, 2014 | Audio Players & Recorders
Sx-nd22 speaker to be connected whihc one is positive and which wire is negative
http://www.retrevo.com/support/Aiwa-NSX-D22-manual/id/1076dj393/t/2/
Page 4:
1 Connect the front speakers.
Connect the right front speaker to the SPEAKERS R terminals and place it on the right side of the unit. Connect the left to the SPEAKERS L terminals and place it on the left side.The speaker cords with the white stripes go to the + terminals.
Jan 15, 2011 | Aiwa NSX-A777 Shelf System
How can I hook up my Bose cinemate on my Philips HD tv when no there is no Audio out and I want to use it for my dvd player, cable box, and video systems?
You don't need to send audio TO a TV. I's a TV, not a source of anything. Many of us use monitors (no TV speakers). The Bose speakers are presumably superior to the TV speakers so whatever the TV is watching (cable/sat/dvd) shuld have its own audio.
Page 11.
If your TV does not have any audio output jacks, you can connect the CineMate™ speaker
system to the audio output jacks of another source, such as a DVD player or cable/satellite
box. However, you will hear sound only from the connected source through your CineMate
speakers.
http://www.retrevo.com/support/Bose-Cinemate-Speaker-Systems-manual/id/526dj591/t/2/
Dec 25, 2010 | Bose Cinemate Digital Home Theater System...
How do i connect the boston BA745 comp. speakers to my gateway desktop?
Assuming you have the BA745 2.1 speaker set up, all of the cables connect to the subwoofer and then to the computer or the satellite speakers (these are built into the speakers IIRC). Take the cable with the black box (2 pins) to red and green. The red and green plugs go into the matching color ports on the computer and the pins on the black end fit into the jacks between the those for the two satellites. Plug the single end speaker cable into the subwoofer port all the way to the right on the back of the subwoofer. Plug the wire with the two plugs into the matching color jacks (blue to the left, red to the right). Then plug in the power adapter cable in the farthest left jack and plug in the other end to a surge protected power strip (that is plugged in and turned on).
Oct 24, 2010 | Boston Acoustics BA745 Computer Speakers
How do i connect aiwa speakers with 26
LG does not have direct speaker connectors. You will have to use the audio out RCA jacks on the set through RCA cables into a seperate amplifier. Hope this helps.
Oct 14, 2009 | LG 26LH20 LCD TV
Open the HK 695 Audio System Satellite speaker
Open the satellite speaker's metal mesh with a steel needle. then u will find the inside screws to open it.
Oct 01, 2009 | Harman Kardon Audio Players & Recorders
No volume
Things to check,
1. are you using an external cable/satellite box.
if the answer is yes , verify if you have the audio out of the reciver connected to a surround sound system
If you do have it connected to a surround sound system , verify the surround sound systems volume is up and on the correct source input on the surround sound system
2. if you do not have a external cable/satellite box and and or your not using a surround sound system, and the cable line is connected directly to the television via a coax cable.. then verify that in the audio settings configuration of the telivision you have not accidentally disabled the internal speakers, some tvs have this option , please consult your manual.
Sep 24, 2009 | Philips Magnavox 27MS343S 27" TV
I have just been given a pair of aiwa speakers sx-fz1800,there is two cables comming out of the back,which one do i use.
One pair goes to bigger speaker (woofer) and other pair for smaller speakers in box, to get full frequency response, you need to hook both cables.
Sep 10, 2009 | Audio Players & Recorders
Integrate computer (huge MP3 library) into home theater sound (AIWA's fantastic speakers)
Sounds like the wiring for the speakers has been modified to bypass the crossover. Best to open up the speakers and see if there is a crossover. Both speakers should be wired to a crossover and the crossover wired to the speaker out on the amp. Crossovers can be bought from Jaycar in Aust or Madisound in US
May 12, 2009 | Audio Players & Recorders
Philips lx3600d
Common problem with the Philips - here is how to fix this issue:
There are a few possibilities.
1)You can connect a red and white AV cable (or the red and white portion of a red, white and yellow cable) from the TV Audio OUTPUT to the "Audio In/TV" portion of the HTS (NOTE: Many TV's do not have an Audio OUTPUT).
2)You can connect a red and white AV cable (or the red and white portion of a red, white and yellow cable) from the Audio OUTPUT of your cable or satellite box to the "Audio In/TV" portion of the HTS.
Note: Using a red and white cable may not give you sound on all 5 speakers.
3)Get a digital audio or SPDIF cable and run it from the TV, Cable or Satellite Box's Digital Audio OUT to the "DIGITAL IN" of the HTS. This will give you the best sound quality. When using this (or any of the other) type of connection, press SURR until you get sound from all 5 speakers.
Also, the manual can be obtained from www.usasupport.philips.com
-Tha Mp3 Doctor
Dec 20, 2007 | Philips LX3600D System
Aiwa UZUS301 2 Speakers Logo
85 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
