Question about Maytag Neptune MDE5500AY Electric Dryer
My Maytag dryer MDE5500AYW is making a rattling noise. It sounds as if it is coming from the rear of the machine. How do I access the insides of the dryer?
  • 10 Answers
I had the same problem but it's the FRONT Panel you need to remove first. Before you start, unplug the thing first. BTW I did the whole proceedure in 2 minutes using an electric screwdiver / philips bit.
To open the dryer front you first take the door off by removing the two philips head screws, then slightly lift the door and pull toward you (the door hinges have little hooks on the end that inserts into the slots (this little design keeps the door from falling off during removal and install-nice). Then remove the two philips screws on the other side of the door opening (opposite the door hinges). These screws hold two plastic brackets (be sure to see how they are aligned before you remove them so you know how they go back on.
Now the front frame panel looks like an "H" . Grab the top two arms of the 'H" and give a quick pull. The top arms of the 'H" will come loose. The bottom part is held by a couple of clips, just pull up and the front panel comes off.
You will be able to see inside, you can also remove the two screws holding the top on (they are in the corners in the front) .
Posted on Sep 09, 2010
  • grandma785 Mar 17, 2011
    We had a noise at one spot when drying was running. We followed your instructions on opening the front panel, which was exact. On checking the drum, there was a screw that had worked its way lose and was hitting the side of dryer. Now it is quite again! That you so much
MY NEPTUNE DRYER DOOR MAKES A RADDLE SOUND WHEN I CLOSE IT. I DRIED WET TOWELS. HOW TO I GET RID OF THE SOUND. I ATTEMPTED TO TAKE THE DOOR APART TO FIX THE PROB. DIDNT WORK
Posted on Jul 12, 2013
What does it mean when I hearslight squeek when the tub turns, sounds like it is coming from the rear of the machine
bearings? or sometimes litle things can get stuck in between tub and housing and cause funny noises
Sep 08, 2014 | Maytag Neptune Washing Machines
My maytag neptune model mde5500ayw make a sound like metal grinding, comes and goes, it looks like the felt liner in the back is loose in one area. Is this the cause of the bloody awful noise?
If the noise is intermittent then most likely the loose felt is not the best problem. More likely is the rollers that support the drum. You can take them off clean and oil with a good bearing oil and that might work or you can replace them if they are too worn
Oct 23, 2012 | Maytag Neptune MDE5500AY Electric Dryer
Maytag gas dryer makes loud rattling noise. Not a squeaking noise, but something between a rattle and a fast, rhythmic knocking. Tumbler works, heat works, but insane noise.
sounds like the drum isnt balanced. either make sure appliance is properly balanced on the floor or make sure you are not overfilling the tub.
May 24, 2011 | Maytag MDE8000 Dryer
My maytag neptune dryer is making a scratching noise.
If the sound seems to come from the front of the drum it's probably the felt guides. The bottom one will wear first and make a grinding, rattle like sound. You can access it by removing the front panel which includes the door. It fits around the drum at the front. Here's a diagram. Some models have a two piece and some a one piece guide. Part 4 on this diagram is one. It's called a seal here. DIAGRAM
If the sound comes from the rear, there is a nylon bearing and metal socket at the rear center of the drum.
Feb 06, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Can i change which side the driver vent is located?
Hello Laurie. Your dryer allows rear vent, left or right vent. Here is a diagram which shows you all three http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Dryer-Parts/Model-MDE5500AYW/3048/0151200/M0606011/00002?blt=06&prst=&shdMod=
Just pull the dryer out from the wall to access the rear and sides. Joe
Thanks for choosing Fixya!
Jan 11, 2011 | Maytag Neptune MDE5500AY Electric Dryer
The dryer is majing a horrible noise. what could this be? Calvin
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Washer-dryer-combo-Parts/Model-LSE7806ADQ/3048/0152000/M0601021/00005?blt=06&prst=&shdMod=
Dec 09, 2010 | Whirlpool LTE5243D Top Load Stacked...
I have a Maytag Neptune clothes dryer and have had it for years with no problem, love my dryer!!! However, this morning I tried to dry some towels and a code 8.8. displays on the display screen.. Please...
There is a technical sheet inside your dryer's cabinet. You can usually find it by accessing the rear of your dryer. All the fault codes should be explained in this paperwork.
Dec 02, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag neptune dryer making banging noise on each rotation on the left side facing the front. its almost like a thumping noise what do i need to do please?
The drum baffle screw has unscrewed itself and the head is thumping against the inside top panel. Pull door, lift lid, rotate drum to find screw sticking out and tighten.
Aug 03, 2010 | Maytag MDE5500AYW Electric Dryer
My Maytag gas dryer makes a loud rattle and clanging noise.
Prob. some failure of a bracket or loose inside...
Have a local tecnician check it out.
i think that ll be best cause i can't imagine that will be an easy fix.
I hope this is useful, and greets,
Olivier.
Oct 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
953 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
