Question about Braun SI6225 Iron
We have a Braun freestyle iron that was working fine before we went on vacation for 2 weeks. On our return we found that the automatic steam function is not working and it also appears that it's not heating up to the maximum? Manual steam button is working fine.
2 Suggested Answers
SOURCE: Red light flashing
Blinking red light is a standby phase, its not going to get hot like this. Shake it or just start ironing, the red light will go solid and the plate will heat up. The red light will go off when the plate is hot enough. It will go on again (solid) after a few minutes to keep the plate at the right temperature. If you leave it standing around for a while it will begin blinking again (standby).
These irons are known for malfunctioning though, mine stays in standby and the plate never heats up! Hopefully yours is fine.
Posted on Apr 08, 2009
How do I dismantle braun freestyle
There are no user serviceable parts but if you grandma's diamond is inside, try to find snap-together locations between plastic parts and remove any screws you can at the back end. Most irons have screws only at the stand/rear end and can then access cord connections, etc. Once you get started it will be easier to see what the next step is.
Nov 03, 2014 | Irons
Breville TECHnique VIN158
if the iron use electronic control, will be a little difficult to adapt or reset .However i recommend follow this steps and fix it. God bless you
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Clean a metal soleplate:
  1. Unplug the iron.
  2. Use a sponge and commercial soleplate cleaner or baking soda and water to remove dirt buildup on the soleplate. Rinse well with water and dry. Don't use harsh abrasives or immerse an electric iron in water.
  3. Use very fine steel wool (0000) or an emery cloth to remove scratches and burns on the soleplate, then clean the soleplate.
Jun 11, 2013 | Irons
Continuous steam and green light flashing on my tefal steam generator iron.
I found this on a site and it works!! Put 50/50 mix of water and viniger in your iron, let it run, after a while start pressing the steam button, you may have to do this a few times, but it will eventually stop the light flashing, then the steam function will return to normal. You'll need to clean the iron out a few times afterwards
Jun 22, 2010 | Tefal Pro Express GV 8120 Iron
Bush IN632 steam generator iron not steaming
check seller........ spares2go on ebay u.k they may have a spare for you
Good luck
Oct 07, 2009 | Oreck TS100 Iron
Paid $50.00 for Shark model G1405Z. It lasted 3 weeks.
WalMart would have replaced it with or without a receipt for an identical priced product. You can take the bad one back with the receipt and ask for a refund, provided they ARE identical. The barcode is scanned onto the receipt.
Feb 12, 2009 | Euro-Pro Shark GI490 Iron
Rowenta Iron DZ6700
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Sep 11, 2008 | Rowenta Perfect Iron
Steam Question
Found the answer. The steam button is built into the handle. Push the button and you have steam.
Feb 27, 2008 | Steam Fast SP-660 Iron with Auto Shut-off
Red light flashing
Feb 07, 2008 | Braun SI6225 Iron
My iron doesn't steam up anymore
Time for a new iron. I last one went to the iron graveyard and I then spent $150.00 on the top of the range Phillips with the gold plate. Has cut my ironing down to a 1/4 of the time. Well worth it
Feb 02, 2008 | Micro Pro 7599 Iron
Braun SI6225 Iron Logo
118 people viewed this question
Top Braun Irons Experts
Are you a Braun Iron Expert? Answer questions, earn points and help others
