Hard drive bad,tried to replace, said no keyboard found, tried reseting bios, replaced battery. still no luck. what now?
  • 57 Answers
Try to change the ports or uodate the drivers in the device manager lacation must be the c:\ drive
Posted on Sep 06, 2010
  • 113 Answers
Ur pc need to be checked if u r in bangalore call 9972888885
No signal on monitor for hp dc-7700
how many hard drives do you have two or more when reset bios default it can happen.you must be sure to start from the drive there windows is.bios optimal default probely changed drives
Apr 01, 2013 | HP Compaq dc7700 PC Desktop
My hp desktop says internal hard disk not found how do i reset my drive
First reset the CMOS. Check your motherboard specs for how to do this or remove the small round silver battery from the motherboard; wait 30 seconds and reinstall it. (It is a good idea to replace with a new battery.) This will reset the CMOS. Then reboot to see if HDD is detected. If not, go into the BIOS setup (repeatedly hit F10 at HP logo screen) and check to see if your hard drive is listed. You may have to set it to "on". If it is listed in BIOS, but not detected another drive (a bad one) could prevent it from being detected. If you have any removable or external drives attached to your computer, disconnect them. Reboot your computer to see if your HDD is detected. If not, open your case and disconnect the data cable from all drives except your primary hard drive. This includes the floppy, optical, zip, backup, or secondary hard drive(s). If your HDD is detected, reconnect each drives data cable one at a time rebooting between each. If after reconnecting a drive and rebooting, your HDD is not detected the last drive is a bad drive and preventing your HDD detection. I have found that sometimes a bad drive that is connected will let the HDD be detected then on later boots the HDD will not be detected. Also it is possible that your BIOS is corrupted. Let's hope not. Another possibility is a bad motherboard. I hope this helps you.
Aug 11, 2012 | HP Computers & Internet
Toshiba satellite l305-s5933 cant access bios and wont boot
If you want to reset the Toshiba BIOS , You can try visiting this web page..
http://web.archive.org/web/20080821232354/http://www.11a.nu/software/bios-pc-bios-security-and-maintanance-toolkit/
: Run the DOS executable ..
: And most of the BIOS password resets are done using the same ..
You can try..
Jan 06, 2012 | Toshiba Satellite L305-S5933 Notebook
Strike F1 to continue, F2 to run the setup utility
Got to BIOS by pressing F2,check or any floppy setting and disable it even in boot order setup.This will solve your problem otherwise replace the lithium CMOS battery.
As you have reset the BIOS setting to it's default setting.Floppy drive is enable by default whether your system have a physical floppy drive or not.
Dec 24, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
PXE-E61:MEDIA TEST FAILURE PXE-M0F:EXITING BROADCOME PXE ROM
hello, sounds like bad hard drive. here is what you can try, go in to BIOS and reset it factory default save and exit, let the system start again go back in BIOS and check to see if you see your hard drive there, also this time disable Boot from Network option. seeif your system actually starts up... or you get "no operating system found", if you saw the HDD in BIOS and get no operating system found, you can try reinstalling windows.
if you still media test failure and it loops, you need a new hard drive.
let me know if it helps...
good luck
Amar Sondhi
Dec 03, 2009 | Dell Inspiron 1501 Notebook
CANT GET COMPUTER TO START ASKS TO PRESS DEL TO RUN SET UP THEN PRESS TAB TO DISPLAY BIOS POST MESSAGE
Hi:
Not sure what sort of process got you to where you are needing this, but you might try reseting your motherboard by clearing the CMOS , by pulling the battery. If that doesn't help, have your power supply checked.
Nov 10, 2009 | ASUS K8V-MX Motherboard
Primary hard disc drive 0 not found
replace your hard drive, its toast !!!
then reinstall OS or run the repair/restore disc.
if you did not get one contact dell.
Oct 21, 2009 | Dell Latitude D600 Notebook
I had a new hard drive installed on my computer and now my keyboard will not work. My mouse does, but not the keyboard. I temporarily have a wired keyboard hooked up. I can't seem to reset the wireless...
i found 2 computers in the trash. the keyboard and the mouse does not work with a hard drive in it.i cant even get into the bios. when i remove the harddrive. the mouse and keyboard works fine. what could be the problem.
Oct 10, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Turned on and is asking for bios password
If you have the hard drive installed in a desktop, remove your CMOS battery for about 5 minutes. Replace and you should be good to go. You will need to reset the time and date on your pc.
Good Luck
C2Solutions
Aug 19, 2009 | Toshiba MK4026GAX (hdd2193) 40 GB Hard...
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
