Question about Motorola Mobility RAZR V3
My new Razor will not ring
My new phone does not ring or vibrate for an incoming call. It was working fine until I started customizing it. The incoming call goes directly to the voicemail.
  • kashaletha Jun 02, 2008
    having same problem my motorola razr 2 won't ring.
    Brigadier General:
  • 7,752 Answers
Do a master reset and clear of the phone
Posted on Jun 02, 2008
My iPhone incoming calls ring but do not vibrate, but all other notifications vibrate correctly.
Strange. I would try resetting your iPhone. Hold down the home and power buttons until it powers off. It should start up automatically but if not just press the power button. This has worked for me in the past when my iPhone has acted strangely.
Don't worry about a reset or hard reboot. You won't lose any data or settings.
Aug 06, 2012 | Apple iPhone 3GS Black (16 GB)
How do you adjust the volume on the Samsung T255 StraightTalk phone?
Sound Settings
You can customize various sound settings.
Incoming call
Note: When downloading MegaTones® or HiFi RingersTM, charges may apply.
Ringtone.
This menu allows you to select a ring melody. Highlight Ringtone and press . Use the Up or Down key to highlight a ring tone or press the Left or Right key to select a file from either the Default Melodies, Voice list, or Sounds folders. Press the Select soft key.
Volume
This menu allows you to adjust the ring volume to one of 7 levels plus Silent mode and Vibration mode.
  • Use the Right or Left key to increase or decrease the volume.
Alert type
This menu allows you to specify how inform you of incoming calls. Use the Right or Left key to select an Alert type.
The following options are available:
- Melody: the phone rings using the ring melody selected in the Ringtone menu.
- Vibration: the phone vibrates but does not ring.
- Melody and vibration: the phone rings and vibrates simultaneously.
- Vibration then melody: the phone vibrates three times and then starts ringing.
- Melody then vibration: the phone rings using the ring melody selected in the Ringtone menu and then vibrates.
Message tone
This menu allows you to set up the ringer for incoming messages. You can set the Tone, Alert type, and Repetition.
  • Use the Up or Down Navigation keys to make your selections.
Keypad tone
This menu allows you to select a Beep or a Xylophone for your Keytone and to select the Volume (0-7) that the
phone sounds when you press a key.
Jan 25, 2011 | Samsung T239 Cell Phone
Droid X phone won't ring for incoming calls.
Found on Motorola Support:
1. Make sure that the "Smart Profile: Face Down" feature is enabled.
2. Hold the phone face up in your palm.
3. Call your Droid X from another phone.
4. As the phone is vibrating, DO NOT ANSWER.
5. Still holding the phone, flip the phone face down as it vibrates.
6. Still holding it face down, hit your volume key to silence the phone.
7. Flip the phone back over so it's face up. You should feel a quick vibrating jolt indicating the ringer is back on.
8. End the call. It shouldn't matter which phone you end the call from, as feeling the jolt is the key.
9. Leave phone face up and call yourself again. If the ringer is now working again, turn OFF "Smart Profile: Face Down" until there's a true fix.
10. If it does not work initially, try all of the steps again a few more times and hope you get lucky.
Jul 29, 2010 | Google Android
Phone doesn't ring, but other sounds fine
:) Sometimes happens to me also. I faced a similar problem before, I think one of the installed programs on your device does it, I couldn't remember the name of the application now but whenever I launch it, my phone sound goes to minimum, Just to let you know. Have a nice day.
May 21, 2009 | HTC Touch Cellular Phone
Phone won't ring or vibrate and keys click and beep when pressed
I brought my phone in to my service provider and they removed the battery and sim card (because I was unable to turn of my phone with the power button) and rebooted the phone. It's all good now.
Mar 19, 2009 | Nokia 2600
How do I increase my ring tone volume on my Moto Razor .?
You can set the length of your incoming ring to in the Call forwarding portion of the phone. Usually, it is set to 25 seconds. It can go as high as 30 seconds. To set the ringer to be longer or shorter, it goes by 5,10,15,... set of 5 increments. up to 30.
I would also recommend to use a factory set ringtone, set the profile to LOUD or OUTDOORS. With vibrate option on. Some downloaded ringtones don't play as loud.
Feb 10, 2009 | Motorola Mobility RAZR V3
Need instructions to change from ring to vibrate
press the volume all the way down on the side until it says vibrate
Dec 30, 2008 | Motorola Mobility RAZR V3
RAZR v3xx
go to settings and set a ring or vibrate alert do it by going in profiles and edit them
Nov 27, 2007 | Motorola Mobility RAZR V3xx Cellular Phone
Motorola Mobility RAZR V3 Logo
306 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
