Question about Dryers
Only works for a few minutes: set timer, push start ingiter glows, valve clicks fire cycle repeats 2-3 times then fails to re-ignite the vent hose is disconnected at this time the vent has been cleaned to near new condition Could it be that the valve coils fail after things warm up? Could it be a termostat that fails after things warm up?
    President:
  • Dryers Master
  • 2,651 Answers
Failing to reignite soiunds like a bed set of coils to me, bad thermostats would never allow iginition the first time
Posted on May 13, 2008
Maytag dg313 series 7 dryer will not light
Thermocouple. The igniter heats the thermocouple to turn on the gas valve and fire the burner.
Nov 29, 2013 | Dryers
Gas Dryer Ignition Issues
did you try bypassing the cycling t-stat also?
Aug 25, 2012 | Samsung Dryers
Sg7800 maytag dryer stopped giving heat
Sounds like burner not igniting. On front of dryer in the lower right there should be a gas valve/burner access panel. Usually you just have to pry out at bottom of panel & swing out and up to remove. This gives you access to valve coils and igniter. With panel removed set timer for heated dry and start dryer, observing first the igniter which should glow bright orange-red, then after a couple seconds you should hear a "Click" which is gas valve opening and a blue flame ignites for heat. If no glow is seen after a few seconds or at least a minute, igniter is bad, if it does glow and no click is heard from the gas valve, the coils (electro magnets) on the valve are bad, or the "Flame present" sensor is bad. Chances are it's either the coils or igniter.Try this on all heat settings, if you get heat at only one setting it might be in timer contacts, but not common. Again you can repair/replace both the igniter (usually just plugs into a receptical) and the coils (2 donut looking objects on the gas valve, replace both.) Access door may be on back if not on front, but normally their on lower right of front.
Feb 13, 2011 | Dryers
Maytag Gas Dryer, 18 years old. Vents are clean through the entire system. The thermal igniter/coupler glows for a few seconds and sometimes ignites the gas and it's fine. However, sometimes it glows and...
Hello- You will need to have the Coils replaced, they are not holding the valve open consistently, it is a fairly common issue and presents itself as you describe. The parts are fairly inexpensive but you should have a Tech out to change them for you. These are great dryers and I would have the Tech look through it while it's opened up...drum wheels and belt should be checked for ware. Hope this helps, best regards.
Sep 26, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer starts with heat. After 10-15 minutes, when dryer calls for more heat, here a metal clicking noise, flame does not ignite. When it's clicking, I can look down the back from the top and see a glow....
Your gas valve coils are defective. Part #694539 and 694540 are required. Once the coils get hot they collapse internally and the gas valve shuts off. This is a common problem when valve coils get weak from use.
Nov 09, 2009 | Whirlpool LGQ9857L Gas Dryer
After starting my GE gas dryer , the burner fires and everything seems fine . The burner stays on for a few minutes and shuts off like it's supposed to . After a few minutes , the glow element turns on to...
Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Aug 01, 2009 | Dryers
Ignitor fires early or gas valve turns on too late - no ignition
Put your hand on the gas valve and see if the click of the valve is opening just before the ignitor goes off if it does your valve is going bad
Nov 12, 2008 | Heating & Cooling
Maytag Neptune MDG300aww Gas Dryer Heats On and Off
hI YES THE COILS IS WHAT YOU HAVE TO CHANGE thANKS FOR THE QUESTION tHE APPLIANCS DOC
Sep 12, 2008 | Dryers
After a few heating cycles the burner does not ignite
The problem you are describing is usually associated with a bad gas valve coil. The dryer runs normally until it gets hot, then starts making a strange clicking noise. After it cools down, the dryer runs normally again. The gas valve coils (there are two of them) usually run about $20 a piece. I recommend replacing both of them at the same time just to be sure. I hope this helps.
Apr 15, 2007 | Maytag MDG3600BW Gas Dryer
Dryers Logo
47 people viewed this question
Top Dryers Experts
