Question about Webroot Spy Sweeper (spysweeper) for PC
Webroot won't sweep
My spy sweeper won't sweep and says something about defination files needs updated but nothing happens when you click the update button and i have a new version it worked till about 10 or 11 days ago it expires in 2009
  • nsmith0 Jan 20, 2009
    click on sweep button but does nothing, also says critical sheilds down
  • Anonymous Mar 17, 2014
    clean sweep is on day two, is that alright?
  • 60 Answers
1- Install using this serial: SSDC-ONLN-AAAA-NNNL-NINC
Then
2- Go into the C:\Program Files\Webroot\Spy Sweeper
Then
3- Right click the "install.dat" file-->go to Properties--> at the bottom check the boxes "read-only" and "hidden"-->then click Apply
And finally....
4- Run SpySweeperFix.v1.1.exe
Allow SpySweeperFix.v1.1.exe to run on the next Windows start up, this gives you the definition update till 2020, otherwise, you'll just get till 2008!
Hope this helps, if not, post back.
Posted on May 29, 2008
Webroot can't get updates eror disp0201
your defination file is corrupted reinstall the software then update it
Jul 01, 2009 | Webroot Spy Sweeper (spysweeper) for PC
Webroot spysweeper won't sweep
This sounds like the program glitched. Try removing it and reinstalling. Then have it check for any updates.
Aug 05, 2008 | Webroot Spy Sweeper (spysweeper) for PC
Spysweeper does not work when you click on it
Web Root Spy Sweeper is an adware itself, this program install a key in the startupregistry with the name spy falcon, making you beleive that is a realadware .Sweeper auto quarantined some files need by the operating system............a better alternative is spyware terminator (click here) and is complete freeware8523dbf.jpg
Jan 03, 2009 | Webroot Spy Sweeper (spysweeper) for PC
I have a subsription with McAfee and I cannot download the software before having this webroot spy sweeper removed.I cannot find it on my computer and never had a subscription with this webroot spy...
first uninstall the webroot spy sweeper through the following steps.
1.click start
2.go to control pannel
3.open 'add or remove program'
4.a window will open wait for some time until the list is populated
5 i)in that list find webroot spy sweeper and click remove
   go through the uninstall wizard and finish the uninstallation process
5 ii)if you didn't find webroot spy sweeper there then it can be a virus
You need to download a program called MalwareBytes because that searces your entire computer
, finds the virus and completely destroys it.
http://www.download.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html
Click the green 'download now' button (don't worry - this is free) and once you've downloaded it, got the updates and done a system sweep which takes a long time but it's worth it, you should be fine. It also solves the desktop, wallpaper and screensaver hijack, too.
6. restart your computer
7.open mycomputer click search and do a search for webroot spy sweeper
delete all the files and folders regarding webroot spy sweeper
8.now download mcafee before installing mcafee uninstall MalwareBytes and restart your pc
because at a time only one antivirus software should be used
i think this solution will help you
if the problem is not fixed please inform i will suggest some other ways
Dec 19, 2008 | Webroot Spy Sweeper (spysweeper) for PC
Spy sweeper
In which place you click on the icon of sweep.
In the menu, on the screen or directly from the directory where you can find the sweep.
There are all kind of possibilities.
Problem with the registry.
File is moved
Version expired.
Probably the easiest way is to reinstall sweep.
Nov 05, 2008 | Webroot Spy Sweeper (spysweeper) for PC
i had the same problem getting also an error message when i would log in about a valid definition file and go to program option page to update the definition file, after trying fixes from others i found one that said to reboot computer and put in safe mode, then open spy sweeper in safe mode, everything was in large print and nothing was turned on, so i rebooted the computer again and this time when the screen came up came up normally and not in safe mode and most of all there was no error message, my spy sweeper is now opened and now it is sweeping like it is suppose to do i don't know who was the person that posted the resolution but thanks it works so everyone try it.
Aug 01, 2008 | Webroot Spy Sweeper (spysweeper) for PC
Won't sweep
you may need to manually update the program by going to the Options tab and click Update. If you receive a dialog box stating, "Continue, Shut Down, Restart Program" or something of the sort, click Continue using Program and it will update the definitions. then restart computer and sweep. If this doesn't work then your program may need to be reinstalled with a valid subscription key.
Jun 28, 2008 | Webroot Spy Sweeper (spysweeper) for PC
Mycomputer, when first turned on reads: "the connection to the spy sweep has been lost or terminated."
Related to this question -
http://www.fixya.com/support/t206134-webroot_spysweeper_sweep
It's your Webroot Spy Sweeper that's having problems - it may be related to your antivirus or firewall (try updating them), or if you're using Vista there's an incompatibility with the automatic update. Some of the possibilities can be found on Webroot's support site -
http://support.webroot.com/
Start with updating Spy Sweeper to the latest version (by manual update) and then branch out.
Jun 19, 2008 | Computers & Internet
Spy Sweeper won't sweep
I have seen this problem a couple times. The only fix that seems to work is uninstalling Spysweeper and then reinstall it again. If you go to start>Programs>webroot you will see an uninstaller. Run that, reboot the computer, then reinstall again from your install disc.
Jun 04, 2008 | Webroot Spy Sweeper (spysweeper) for PC
Error message:could not locate a valid definitions file.Please go to the program options page and click "update definitions" to download a definitions file.
Use Norton-Cleensweep to uninstall.
You can download Norton System works.
Use torrent for Free download of NORTON SYSTEMWORKS. (www.btjunkie.com)
May 25, 2008 | Webroot Spy Sweeper (spysweeper) for PC
Webroot Spy Sweeper (spysweeper) for PC Logo
193 people viewed this question
Top Webroot Computers & Internet Experts
Coss
Mike
Are you a Webroot Computer and Internet Expert? Answer questions, earn points and help others
