To get the PUK code, please contact your mobile network operator customer care and they can help you to get your PUK code.
Dont attempt to inpur incorrect PUK codes as this may block out your SIM card completly and you cannot unlock it even with correct PUK code later.
I hope this is helpful to you
Thanks
Please call the Customer Care of your Network Operator (sim card provider), they will tell your the code. There's no other way or no means to get the code except from the Service Operator. They might ask your few questions related to the Sim Card, like your name or your address, tell them promptly and they will give you the puk code for your sim card. It's also important to note down the Sim Card Number (number written on the sim card) if in case they ask you the sim number. You will also be assisted on how to disable the security settings.
Note: if you keep entering random/unknown numbers/codes, the sim card will be locked and will be rejected. It'll not be usable anymore.
Good luck.
Thanks for using FixYa.
These directions are for an AT and T phone, but other than that would be the same for any carrier.
A PUK (PIN Unlock Key) code is required to unlock SIM cards that have become locked following three successive incorrect PIN entries. If your SIM card becomes locked, you will need to get a PUK code from your phone carrier to unlock your SIM card.
You can obtain your phone's PUK code from your carrier in one of these ways:
Log in to Your account.online
Use a Technical Support Chat
Contact your carriers Customer Care
Get Your Phone's PUK Code Online
Go to the Phone/Device page.
From the My Phone/Device screen, select the Unblock SIM Card link under the My Make & Model heading.
The Unblock SIM screen will display your PUK code and will give you instructions for unblocking your SIM Card.
Once you receive your PUK code, you will need to enter it into your phone to set a new PIN code.
Note: If you enter the wrong PUK code 10 times in a row, your SIM card will be invalidated, and you will need to purchase a new SIM Card. The phone will display the following error: "PUK blocked call operator
