Question about Hotpoint HTS16HBR Top Freezer Refrigerator
I have water coming out the front of the fridge....I've turned off the water supply to the ice maker in the freezer, the evaporator pan on the bottom near the compressor is bone dry and I can't find a hole on the inside where the water should drain from.
    President:
  • 2,468 Answers
Is the drain hose still connected to the drain tray in the freezer,and if so is the drain hose possibly plugged between the drain tray in the freezer and the drain pan in the bottom by the compressor,if it is it will overflow and find other routes to drain
Posted on Sep 06, 2010
  • randymccl857 Sep 08, 2010
    actually it was the fitting that connects the drain tube to the refridgerator.....thanks
  • danny Hendrickson Sep 08, 2010
    good to hear you solved your troubles and thanks for using fixya
Ice forming on bottom of freezer.
is the drain tube plugged up that drains defrosted water to the bottom pan,its located behind the inside rear panel just below the evaporator
Feb 07, 2013 | Refrigerators
Water leaks on floor, where isthe defrost drain pan? the manual indicates that water might build up in drain pan, the connections with the ice maker are all dry.
The drain pan is usually located closest to the floor - behind the kick space or toe space grill at the bottom of the fridge. Most often the water that collects in it is evaporated by the heat generated by the compressor and airflow from condenser fan located close to the pan.
Make sure the water is coming from the defrost drain hose - not from water sources elsewhere in the fridge (leaking water / melting ice into the fresh food compartment, etc.). If found, take action to correct.
Oct 19, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
I have a Samsung bottom freezer top fridge RB215LASH. Water leaks from the inside back panel down under the crisper. The drain is not clogged. Their is no problem with the evaporator coils freezing...
OK, first there is only two ways water can be entering the fridge under any circumstances, one is through the Ice Maker feed line coming from your wall to the back of the fridge and into the ice maker. The other is from the ice trays themselves leaking or overflowing or the filter itself is leaking. Look at the side walls of your refrigerator, are there water streaks running down the side? Have you reset the ice maker since you did your repairs? Have you replaced the filter lately?
Usual Causes
If the water pressure is too high, the ice tray can over fill or water can splash out. You can turn the supply shutoff valve to reduce the water flow. See the diagram below. If the ice cube tray has residual pieces of ice in the bottom, remove the pieces by pressing the reset button. You may have to do this several times to clear all the ice out of the tray.
Get back to me and I know you provided a lot of information, but this is a inline water issue relating to the ice maker and not really thinking it could be anything else. So if you can give me more information about the form in which this happens, such as you find the water after the trays are filled or if this is a constant but minimal flow, large flow, we can concentrate our plan towards this are of the repairs and diagnosis. Look forward to hearing from you soon.
Aug 04, 2011 | Refrigerators
Hi hope you can help, I have a 2 door fridge with a bottom draw freezer purchased new 2008 and I have lost the instructions.The prolem I need diagnosed is water leaking from the freezer draw. thanks.
Sounds to me like you have a leak, probably from an ice maker tubing connection or vinyl water supply tube itself. Have someone get a good flashlight and get a good closeup look at where the water is coming from. The water supply to the fridge's icemaker comes from the house wall, floor, or cabinet area of sink. Often they are connected to fridge, then someone moves the fridge to clean and the line gets run-over or tugged on too hard causing a leak. If that is cause, install a new line (hardware stores have these specific to ice makers, 1/4" vinyl or copper tubing) and it should be coiled several times in mid air near the wall, so if fridge is moved out it just uncoils not incurrs damage from un-noticed tension (full amount of water pressure in that little line).
2nd possibility for newer type fridge. All frost free fridges have a pan underneath that catches condensation from coils, from the pan the water evaporates into the air where balance is achieved and pan is never full. On rare occasions, like during moving, on some the pan isn't fastened down and can fall out of place, then condensation water from the coils falls to floor (not any great amount but some).
Jan 15, 2011 | Microwave Ovens
Maytag side/side model MSD2754GR- Ice maker while filling overflows running out of freezer section onto floor.
Remove the back panal in the freezer compatment to reveal the evaporator. You will notice the drain pan frozen up with ice. pour hot water on it or blow hot air with a hair drier. If the fridge is turned off the ice will melt and clear the drain hole. When the ice is cleared the water will be alowed to flow out to the evaporating pan under the fridge. Be sure that the water runs freely out of the fridge and allow a few hours to dry. Good luck. Be careful not to damage the evaporating coils.
Dec 07, 2010 | Maytag MSD2756G Side by Side Refrigerator
Water seeps out of freezer side of fridg onto the floor, I have totally remover the water line going to the ice maker and it still has water seeping out. It builds up Ice on the bottom of the freezer and...
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curtain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Sep 25, 2009 | Magic Chef Refrigerators
Water is leaking under the refrigerator. This is
If everything else on the refrigerator seems fine (freezing and refrigerating are fine), then you probably have a problem with the drain hose under the evaporator coil. On frost free freezers, there is a heater that comes on periodically to melt off all the frost on the evaporator coil, and that defrosted frost (water) goes out a drain hose and collects in a pan at the back of the unit where it can evaporate.
Either the drain is clogged with ice inside the freezer, (in which case you might notice ice building up on the bottom of the freezer, or perhaps water collecting on the bottom of the refrigerator if your freezer is on top) OR there is something wrong with the pan at the back of the refrigerator, like a crack, or it somehow got tilted so that the water pours out. It is located behind the panel on the back.
Or perhaps, and this would really ****, the water line that supplies your ice maker is leaking, if you have one. If you do have one, I would recommend turning the water line to the fridge off before pulling the fridge out.
Sep 14, 2009 | Kenmore Refrigerators
Ice forms on the bottom of the freezer and water leaks on the floor water to the ice maker was turned off and that did not solve the problem.
Assuming that this is a self-defrosting freezer (which almost all are today), the defrosting coil or the timer may be bad. The defrosting coil actually warms up the freezer slightly every X hours. This thaws the ice that starts to form in the freezer. The vapor is then evaporated and exists out through a drip tube to the bottom of the freezer/fridge into a pan. The pan usually has the compressor fan blowing over it to evaporate the contents.
Jul 28, 2009 | Frigidaire FRS6R5EMB Side by Side...
There is water dripping filling up the bottom under the salad container. The model is a LRTN22311TT.
Remove contents of fridge and check the drain line running down the top back of the back of fridge and follow to lower section of fridge (usually a back ledge or under the crisper sections) and locate a small round drain hole. Also, check to see that the drain collector (funnel looking thing at top back of fridge section) is located under the freezer defrost drain opening, to allow water to flow through the fridge into the drain pan under the fridge.
If something has obstructed the drain funnel, path, tube, or lower drain hole, remove the blockage to allow water to drain into underneath of fridge into drain pan for proper evaporation of water produced from the usual daily defrost cycle of fridge/freezer.
If that is not the problem, it could be that you have a leaking water supply line for your ice maker and you'll need to see if the freezer is allowing excessive water to flow out of the ice maker into the fridge section.
Another simple check/solution is that the fridge is not properly leveled, meaning that the front of the fridge should be slightly higher than the rear to allow for proper drainage and self closing of the front doors. This will help keep the water flowing in the built in channels and drains.
A perfectly level fridge isn't the right way to install most moveable refridgerators, while built in fridges (Sub Zero, etc.) are designed for plumb and level installations for proper functioning and use.
Apr 09, 2009 | LG LRTBC1825T Top Freezer Refrigerator
Ice build up in bottom of freezer
Check the ice maker. sometimes they get cracked a will leak water into the freezer compartment. Also check the ice maker fill tube for leaks or someone could have spilled something. Although this is tipical of a clogged drain. What happens is when the fridge go into derfost, it will melt all the frost that is on the evaporator, turning it into water. The water drains down to a trough under the evaporator and down a drain hole in the trough ( this trough is behind the evaporator cover ) Removing the melted frost from the freezer. If that drain is clogged, the water cannot leave the freezer. Then when the fridge starts back up ,it will freez the water that was not drained. After repeated defrosting the water will fill this trough and run off into the bottom of the freezer to be frozzen when the fridge starts to cool again.
Nov 16, 2008 | Refrigerators
Hotpoint HTS16HBR Top Freezer Refrigerator Logo
185 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
