Question about Car Audio & Video
I bought a pioneer deck a few months ago and i just got subs and an amp today and me and my buddy hooked it all up and there's powering going to the amp and everything. anyways my problem is that my subs do not work and they work when i have a different deck hooked up so why wont they work with my pioneer
Did u have your remote wire hooked up right?
Posted on May 13, 2008
Subs make one very loud bang when car starts i have a kenwood kdc 528 deck and 2 pioneer 12in subs an amp
Hook it up properly to the deck remote on wire ,(Dude) End stay off the (Drugs)
Nov 22, 2012 | Pioneer Car Audio & Video
I bought a sony deck to replace the bose stock deck on my 1996 nissan maxima. I purchased the wiring harness and antena adapter also. I hooked everything up right and getting power but im not getting no...
each speaker in your car runs the wiring thru an amp. So each spkear has its own amp for the bose system. You can not hook up a none bose radio If you do you will need to run new wires and replace all the speakers. Sorry.
Jul 02, 2011 | 1996 Nissan Maxima
I had these 12in pioneer subs so I went and bought the new Rockford Fosgate they came out like a week ago my problem is every time i hook them up to the amp the protection red light turns on can you...
if the amps impedance is higher than the speaker, it will trigger the protection circuits, because the amp sees it as an overload, example the amp has 8 ohm impedance specified, and your speaker has 4 ohm specification, that is a clear overload. Bring the subs back to the amp's dealer and have the amp replaced; the one that matches your subs. Hope this helps... ;-)
Feb 03, 2011 | Car Audio & Video
I have a pioneer gm-d8400m the amp isnt working
flashing light could mean a few different things. 1- constant power may not be there. check with a test light or multimeter. should read around 12 volts. it would be a good idea to check all the power and ground leads. make sure u have a good ground. 2- bad sub. im assuming sub since its a monoblock amp. you can meter the subs. make sure the total ohm load is no less than 2 ohms. any lower the amp will go into protect mode. 3- bad amp. power supply may be bad. the newer pioneer amps are full of protection circuits. ive been a professional installer for a shop about 8 years and we sell pioneer. hope it helps.
Dec 25, 2009 | Car Audio & Video
My subwoofers will not play
go into the menu screen on the pioneer unit and go to setting if you have a loud function there turn it on.... if that doesn't activate the amp ...(did you hook up the blue wire from pioneer deck to amp and run it threw the car to the amp)..if no than your pioneer deck does not realize there is an amp present in system....... if yes scroll threw menu till you see audio look for Sub Woofer or Amp you may even have a button on pioneer deck marked SW go press it and turn amp to on this will provide signal from pioneer unit to amp if this doesn't work other thing could be you hooked RCA to AUX input (but if you have a SW for RCA plugs on back of unit make sure the RCA wires are in it) the loud or SW button should activate it (if there is only F and R for RCA plugs on back of unit use R hope this helps)
Mar 04, 2009 | Pioneer AVH-P4900 Car Video Player
I had my subs installed a month ago and a few days ago the subs are working,everythings connected but not working and my subs aren't blown out because i don't have my music that loud so whats the problem?
what model kenwood speakers do you have? what head unit do you have? do you know how they hooked up the rca cables to the back of the deck? if this deck has got 3 pre outs you may have lost the sub pre-out. are you amp lights coming on? if you are still having problems you can take a 9v drill battery or bigger and touch the wires from the speaker to the battery, make sure positive to positive and neg. to neg. the speakers should pop if they are ok, that should re-assure you on the speakers. let me know and ill help where i can. good luck
Feb 27, 2009 | Kenwood Car Audio & Video
Ive had 6 blown subs in the last 6 months
be careful with fosgate amps. They are more powerful then what is stated on them. I found this out when I blew a 15 with a punch 260ix. These amps are made for competion use. The 600.1 does not push 600 watts as stated. I had one tested and it actually pushes close to 800 watts. Turn ur bass level and ur gain to about 3/4 power and this should solve your problem
Feb 23, 2009 | Car Audio & Video
Pioneer DEH-225 Car Audio
The system remote control is usually a blue wire on your decks harness and it is for an amplifier for a sub or other speakers. It sends power to the subs amp when the deck is turned on. You may need to find the wires coming off the antenna and splice them into the red power switching wire 12v on you decks wire harness. Good luck
Oct 07, 2007 | Pioneer DEH-225 CD Changer
Car Audio & Video Logo
89 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
