Asko 20005 Washing Machine Stopped Running
I have an Asko Washing Machine that stopped running mid cycle. Now it won't turn on or do anything. Is this a fuse problem? I found two fuses on the back and took them out. However, I can't tell if they are any good or not as they are solid white...can't tell if they have blown or not. Trying to find a solution before paying a technician $90 just to show up at my house.
  • 487 Answers
If all your power did shut down of the machine it might well be a fuse problem.
If you have a mult meter you can check the resistance of the fuses. they must be near 0 . infinit resistance means blown.
otherway to test it lol for the DIY under us take a 9 volts batterie and conect one pole to the fuse . now connect tongue to fus and other pole. Little shock? no blown fuse.
nothing than the fuse is blown. ( by the way not the most pleasurable feeling)
Let me know if they were blown or not.
Posted on May 13, 2008
But what if the fuse keeps blowing? I have the same problem, we replaced the fuse, the machine came back on, we did our happy dance, I put in a load, started it, it ran about 10 minutes, I was vacuuming the laundry room, so I could keep an eye on it... I glance over, and the display is dark!! My son pulled the fuses again, and the blown one (same one as before), the holder part is dark on the plastic on the outside, the bottom of the new fuse was melted and could barely get it out. Once out, saw that the inside of the holder looked 'fried'. So now we're not sure if there is something else blowing the fuse, or if it's some component in this fuse installation that needs to be replaced, other than the fuse... or maybe we need to buy the same fuses that were in it before? I wish Asko would give out more information on their machines...
Posted on Jul 05, 2008
Doesn't work. Why does it stop mid-cycle?
washing machine stopped mid cycle, won't drain : DIY - Reddit
https://www.reddit.com/.../washing_machine_stopped_mid_cycle_...
RedditSep 3, 2014 - helpwashing machine stopped mid cycle, won't drain (self.DIY). submitted 1 ... I get home. Any ideas on how I can just drain the water out of it?
Troubleshoot - washer stops mid cycle, won't drain or spin ...
? 1:58
https://www.youtube.com/watch?v=6Gc0ZgLD6a4
Jun 20, 2012 - Uploaded by searspartsdirect
Troubleshoot - washer stops mid cycle, won't drain or spin .... I agree, this was not helpful, and did not address the no spin issue. like thanks. ... how to fix a Kenmore / whirlpool washing machine that wont drain agitate or spin ...
Washing machine stops mid cycle - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Sep 9, 2013 - Possible causes when washing machine stops mid cycle by a ... If thewashing machine can't drain the water out then it will stick on the rinses, ...
Why does my washer stop half way through cycle - Ken
Dec 18, 2015 | Washing Machines
Fault 02
Hi
Fault code 2 indicates "Water level too high "
Please look for the following causes:
· Plugged/Bad water pump
· Faulty water valve
If you are not able to check these, it may be necessary to call for a technician. Always be careful of electricity!
Jan 02, 2008 | Asko W6021 Front Load Washer
My affinity front load washing machine stopped mid-cycle. The door won't lock so it won't run and it has water sitting in it. Is there anything we can try before calling a repair man?
There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Sorry but both require a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jun 06, 2011 | Frigidaire ATF6000ES Front Load Washer
Asko 20605 washer stopped mid-cycle, now no power?!
The ECU should be tested. Look for the service manual inside the chassis for troubleshooting procedures.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 04, 2010 | Asko Washing Machines
Asko washer 20004 stopped mid cycle, water is
Do not play with water and 240volts or 120 volts....it is a LETHAL cocktail.
Get a techo to save you the headache and possibly YOUR LIFE!
Oct 19, 2009 | Washing Machines
Asko w6021 washer leaves clothes damp and often stops mid cycle
I AM NOT MUCH OF A MECHANIC, BUT I DO KNOW THAT IF WATER DOESN'T SPIN OUT OF THE WASHER, IT COULD BE THAT YOUR BELT IS BROKEN OR YOU NEED TO REPLACE THE MOTOR COUPLING.
May 13, 2009 | Asko W6021 Front Load Washer
Asko D1796F1 builtin...lights are on but no one is home
Our Asko D1796 dishwasher has the lights on the panel working as usual but you can't select a cycle and it won't turn on. We unplugged the pipe. If we turn it off and wait for 12+ hours we have gotten it to work twice.
Mar 02, 2008 | Asko D1796FI Built-in Dishwasher
Washing Machines Logo
322 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
