Question about GE 24 in. Profile PDW9280JSS Built-in Dishwasher
Dishwasher fails to fill with water, will drain correctly if water is poured into the unit
  • GE Master
  • 43,501 Answers
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Posted on Sep 07, 2010
Frigidaire Professional Series dishwasher started to have hot water suddenly fill up dishwasher and the pour out onto my kitchen floor. The dishwasher was not on. I had to press cancel button to get water...
I think your hot water inlet valve has failed open. It is electrically operated, and can stick in that position.
If not that, it is possible that the water level sensor signal has failed, but that should only be apparent when the washer is on.
It requires a service call.
Feb 04, 2014 | Maytag 24 in. MDB5601AWS Stainless Steel...
My dishwasher is leaking from just behind the door on the front left(left when I am looking so the washers right) I have cleaned the area, made sure all pieces are the same on both side and it is still...
can be a couple things, 1 is your dishwasher could be on an forward angle instead of tilting backwards slightly as theres nothing actually holding the water back from pouring out the front, 2 your using to much detergent and the excessive foam is foaming over the seal (very common) try using half what your using now, 3 the pressure switch within the machine is faulty, the pressure switch is the device which tells the control board the unit has filled with the correct amount of water and when all the water has drained when damaged they will not cut off the water which will eventually overflow the machine
Jan 03, 2011 | Frigidaire Professional Series 24 in....
Water fills in bottom of washer when off
The fill valve has failed. You can get a rebuild kit for the valve.
Also clean the tiny straainer in the valve.
Dec 30, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Kenmore dishwasher fills with water, then drains. Doesn't wash.
HI, this is a control fault that may be solved by unplugging the unit for 3 minutes. if this reset doesn't work and, the unit continues to fill and dump, i will then recommend to replace the failed control board.
Jun 17, 2009 | Kenmore 24 in. 15079 Built-in Dishwasher
Dishwasher keeps tripping electric
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwash
If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Jan 04, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Will not drain all fluid
i had the same problem and changed the drain line including the air gap.
Nov 14, 2008 | Kenmore 16129 Built-in Dishwasher
Miele dishwasher g843 scvi water backed up on bottom of unit
When you drain the sink the water will go to the path of least resistance. Disconnect the dishwasher, cap the hole and see if water drains. If not then you have a plumbing issue.
Inside the dishwasher there is also a non return valve located in the sump. This should prevent water from entering the unit. Make sure it is in correctly.
Sgt 48
Jun 01, 2008 | Miele 24 in. Incognito G843SCVi Built-In...
18 in dishwasher drains water during cycles
find out how the dishwasher is set up to drain. Pour water into dishwasher 4 or 5 gallons, see if water disappears. if so, your drain is ran wrong
Jan 05, 2008 | Kenmore 15121 Built-in Dishwasher
GE 24 in. Profile PDW9280JSS Built-in Dishwasher Logo
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
