Question about Smeg 24 in. DWI612 Built-in Dishwasher
I have a DWI 612C Smeg dishwasher I have an error code of the 2 right hand LED's flashing Have tried to reset the programmer (turn off, on then press program 4 times in 2 secs, wait 15 secs and turn off) This enables me to select a programme, but when the programme starts, after five mins it beeps and carries on making the draining pump noise and the programme never starts When I turn it off and back on I get the far 2 red lights flashing again Have looked for signs of blockages and can't find any that are obvious, please help!
  • 883 Answers
SOURCE: Zanussi Aquapulse DE6544 not emptying
find the power source (usually at the circuit breaker panel)-then turn the breaker for the dishwasher off and return to on after 10 minutes and try restarting.
Posted on May 27, 2007
  • 8 Answers
SOURCE: Smeg DF612S
Check to make sure there r no kinks’ in the drain line or that it is not clogged it sounds like the sensor is tripping because there is too much strain on the pump just like a breaker.
Posted on Nov 08, 2007
  • 52 Answers
SOURCE: My Smeg dishwasher DWF 64 SSE won't go onto rinse or dry
Easy one first try this to see if it helps
Water pre-heating
Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Posted on Jan 29, 2008
  • 1462 Answers
SOURCE: SMEG DWI410 TRIPS CIRCUIT LATE IN WASHING CYCLE
just possibly
take the kick panel off. On some smeg, there is a small suppressor capacitor on the lhs tucked in the wiring. this breaks down. snip it off - no need to replace
Posted on Jul 18, 2008
SOURCE: Smeg Dishwasher STA945.1, flashing lights
have you check the pipe's for blockage
Posted on Sep 11, 2008
What is error code E1? Dishwasher is not drawing in water on any programmes and this is the code I get
I get this a lot. Its due to a leak inside the bodywork, letting water build up in hte base and operating the float switch. You will have to pull out the dishwasher, tip it backwards and mop up all the water that comes out. (usual precautions about turning it off etc apply). That will get it going. Then find the leak. Mine leaks from the O ring seals on the air break chamber inside the right hand cover. I have used silicon sealant in the past, but I need to remove it and replace the O rings. Trouble is, I cant see how it comes undone on the inside (is it a bit nut?)
Kinata
Aug 16, 2010 | Smeg DWI614 Built-in Dishwasher
just possibly
Jul 18, 2008 | Smeg 18 in. DWI410 Built-in Dishwasher
I have a smeg dishwasher which keeps displaying error code 8. I know this has something to do with the water supply to the baskets but have checked and there does not seem to be a blockage. Any help...
Hi
I saw your post today and see your fault was dated back in July 2008. Well its a year late and I had the same problem coming up on my machine SMEG DWI 614, error E8 to be exact. After 6 hours of trying to resolve this cleaning PCB, etc. (one can see its the recession and money is scarce) I finally pulled out the diverter valve, dismantled it and left it in some boiling water with limescale remover. I made sure the plastic teeth in the mechanism could spin properly and inserted back into the machine....
And finally the machine works once again. It was 6 hours of my time but probably saved me +/- £150.
Later
Jul 12, 2008 | Dishwashers
Smeg DF612S
Nov 07, 2007 | Smeg 24 in. DWI612 Built-in Dishwasher
HOTPOINT BFI620 one led flash error
This is a bad control board that if replaced will only repeat in a short time .My advice is to contact the manufacturer and complain,you have the right as a consumer to do so.
Oct 31, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Smeg dishwasher
Hi, You can download SMEG dishwasher manuals from here: http://www.smegtech.com/site/smeg/myapp/libretti/index.php?lang=EN Al.
Feb 02, 2007 | Smeg CSU2001 Built-in Dishwasher
Smeg 24 in. DWI612 Built-in Dishwasher Logo
253 people viewed this question
Top Smeg Dishwashers Experts
Cleverer2
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
