Question about AKG D8000S Professional Microphone
It doesnt work when connected to amplifier - AKG D8000S Professional Microphone
I bought a hifonics bxi2006d new and doesnt turn on
you should not have any spark from your ground...you may want check and make sure your ground is properly installed. Try wiring the amp without the cap and see if that works.
Mar 28, 2010 | Hifonics Brutus BXi 1206D Car Audio...
No sounds from the left speaker even with the balance turned fully to the left. all connection are fine.
Check the speaker, switch the left and right ones and see if the left speaker still has no sound. If it works the speaker is bad, if it doesnt your left output is bad...
Dec 06, 2009 | Sony TA-FE370 2-Channel Amplifier
Problem with amp
Check your ground it may not be good enough also check to make sure your remote wire is reading 12 volts with the key on. If it doesn't then you run a jumper off your ignitionin the fuse panel.
Sep 22, 2009 | Sony XM-1002HX Car Audio Amplifier
Power to the amp but the blue light doesnt turn on
probably a blown capacitor open it up and look at the capacitor see if any one of them are curvy on the top blowend
Jun 27, 2009 | Alpine MRP-M350 Car Audio Amplifier
Amplifier unit of MHC-W770AV stopped working all of a sudden.
Start with the simple things first, hunt round for fuses near where the mains goes in. Keep on the lookout for anything that looks burned or broken. If there's no power to anything it will be something in the power supply section.
Apr 12, 2009 | Audio Players & Recorders
2005 Dodge Neon SXT Kicker Amplifier
if its a new amp there should be a problem. make sure you have your remote wire hooked up to your radio(its blue). make sure your fuse on your amp wire isnt blow and make sure you have a good ground. if your runnin the ground off the car make sure the paint is scratched off that area
Mar 08, 2009 | 2005 Dodge Neon
Extra speakers
hi in the back of your tv you should have 2 sets of 3 plugs called rca one set is input the other one is output if u using standard speakers connect it to the input remember the speakers need to have the rca plugs,if you use a amp connect your amp to the input to outlet and reverse from the tv.
Feb 06, 2009 | Sony FD Trinitron WEGA KV-29LS35 29" TV
No sound from the amp
Make sure that your amp turn on wire is connected from behind the radio to your amplifier. Usually the turn on wire is a blue wire but it can be any. This blue wire connects from the blue/white wire behind the radio to your small connection turn on connector on the amps power connections. You have 3 ( 12V , Ground, Switch or the smallest connector)
Also check the amplifiers fuses, and the main powerline fuse as well. If this doesnt work then write back to me.
Oct 10, 2007 | Alpine MRD-M1005 Car Audio Amplifier
Amp
The remote wire from the amp is connected to a blue wire behind your head unit. This is a power antenna activation wire; it's only active when the tuner is selected. Switch the remote wire to a blue/white wire at the head unit.
Jun 20, 2007 | Sony XM-D6000GTX Car Audio Amplifier
AKG D8000S Professional Microphone Logo
Top AKG Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Ben Armstrong
Are you an AKG Audio Player and Recorder Expert? Answer questions, earn points and help others
