Question about Sony SLV-640HF VHS VCR
VCR SLV-640HF I'm not sure what the problem is, the tape is stuck inside the carriage. when you press any button, such as Eject, Play or even rewind and fast forward.........the unit makes a small click as the gears try to take hold, but instead just stop and the function fails.....I removed the carriage to remove the tape and to see if I could see any visual mechanical problems, but I dont see anything, any ideas what could be wrong? after some research I learned it could be as simple as the Mode Switch that sends information to the CPU, but i'm not exactly sure whare its located, or how to r/r it.
  • yosemitesam7 May 13, 2008
    No, nothing is slipping that I can visually see from looking from from the top side angle of the unit.....the Upper Cylinder Head starts to spin then slowly slows and stops....the rest of the Transport componets, does not cycle, but moves 1/8th of one inch, then stops completly like its stuck and resets itself in 1 seconds time frame.....any clues?
  • Mikey Finley Jul 25, 2008
    I've had the same problem for a couple of years now. The front display also says L 22 11 whenever I try and do anything (such as play, eject, etc.). Any suggestions would be appreciated.
  • 979 Answers
The mode switch is the device that monitors the various positions of all mechanical components in the transport area. It is usually an encoder type device, located near the center or right side bottom of the transport. But, before I'd condemn the switch, I would certainly check and see the the transport is "cycling", and that nothing is slipping. This is usually the case when this symptom crops up...accordianman
Posted on May 13, 2008
  • Michael Borelli May 13, 2008
    Insuffiecient cycle happening. Something not completing the mechanical cycle that it needs...accordianman
VHS tape is running at high speed when insert it to VCR. no playback..buttons doesnot work.
Check if the fast forward button is more inside than the rest of the buttons. May be its stuck in the ff position. After all they were just micro switches below the plastic buttons strip. The specific ff micro switch may be stuck, if I were you I would try some switch cleaning spray to loosen it. But be prepared that the control ic is busted.
Jun 21, 2014 | Panasonic Televison & Video
How many motors are in the VCR section? example 1 motor for play, 1 motor for hi-speed rewind, 1 motor for hi-speed forward.
There are only 2 motors on the VCR sections.1 motor for the rewind backward and speed foward.1 motor for take in the VHS tape and eject the tape.The play button also used the same rewind backward and speed forward motor to push the film foward to the VCR play head head drums to play the tape.
Nov 24, 2010 | Panasonic DMR-EZ485VK DVD Recorder/VCR
I was rewinding a tape and the VCR just stopped. When I hit either play or rewind the VCR makes a kind of whine or grinding sound and then the following message appears in the display: 3L 22 AA. What...
Have you tried ejecting the tape?
If the cassette will not eject, the tape is probably fouled on the capstans and will need to be "surgically" removed, VERY CAREFULLY from the machine.
Apr 16, 2010 | Sony SLV-975HF VCR
VCR tape is stuck - will not rewind or eject.
There schould be a release buuton on the rear of the machine. It's usually recessed and may be difficult to see. Press this with the yip if a ballpoint pen and extract the tape. If the tape is wrapped around the record/playback heads your only option is to remove the top cover and manually remove the tape. Sounds difficult but if you take your time it's not too bad a job.
Mar 08, 2010 | Sony Televison & Video
Sony SLV-640HF VHS VCR ejects any tape after a couple of seconds
While the tape may appear to be loading properly, it is not. These units have a known problem with the grease at the loading arm getting sticky. This means that the tape is not loaded properly and will not move through the VCR properly. This is detected as the hubs not moving and the unit will eject the tape to prevent damage. This is a simple repair for anyone that has done these before, but requires an alignment check. This check requires a special alignment tape and equipment.
This should be a labor only repair.
Dan
Aug 31, 2009 | Sony SLV-640HF VHS VCR
Tape stuck in VCR, won't eject.
you posted 2 different problems here...
to answer this one ". The tape is stuck, won't eject and I'd like to get it out without damaging the VCR unit."...open unit, find motor that moves tape ejector and spin that motor by hand (power off)
the other problem, "the VCR will not insert a tape. It keeps rejecting it."...open unit and fully turn ejection motor until home position is reached...this is a home sensor switch not being activated.
Feb 04, 2008 | Televison & Video
Code 3L117C ???
None that I could find. Trash time for this Sony
Dec 10, 2007 | Sony SLV-798HF VHS VCR
VCR Tape is stuck in Sony Video Recorder, model SLV-620HF.
In vcr you mean? try unpluging the electric cord for 1 hour
then plug it back up. it just might eject it out. mine did.
Nov 11, 2007 | Sony SLV-640HF VHS VCR
Tape stuck in vcr
Hello tcsabug,
First locate the load and unload motor, it is the one with the rubber drive band. release the drive band and rotate the gear to raise and pull the carriage back into position.
This should remove your cassette, and put the carriage back into position.
I hope this helps,
Thank You,
Shuttle83
Oct 16, 2007 | JVC HR-J633M VCR
Televison & Video Logo
193 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
