Fisher and Paykel Smart Drive 5.5. When turned on @ the power point there is no beep. Power still reaches the display module (118V measured) but dose not power up when the power button is pressed? Is the problem in the module or elseware?
  • 343 Answers
F&P machines are capable of self-diagnosis, but you have to have the codes and the fault numbers to interpret the binary display.
This is a very simple and quick job for a F&P tech, who will also check any other component which may have caused a secondary fault.
It's risky to just install parts without doing the recommended checks because F&P machines can have component failures which cause other problems elswhere.
An experienced tech will check and replace the parts required and should offer a warranty which you won't get if you do the work yourself.
Probably not what you wanted to hear, but cheaper than ruining electronic parts with no recourse.
Good luck....Nomess
Posted on Sep 06, 2010
Fisher & Paykel smart drive
Turn machine OFF on the front panel. Hold down the Water Temp Down button and press the POWER button. Release buttons. You are in Diagnostic mode.With your service sheet ,Diagnostic chart will explain where the error lights pattern and the path to your solution are.My advice is this....there is a known problem with the wire harness connectors,and the contact that is made at the point of connection.One at a time remove each connector starting at your main control board ,some where there is a loose connection.
Jun 08, 2008 | Washing Machines
Fisher & paykel smart drive 9 mw059au no power
Most of the faults are pump related.
check the Ohms reading on pump should be 33- 35
If readings are less change your pump.
Jul 28, 2012 | Fisher and Paykel Washing Machines
FISHER & Paykel 6.5 Smart Drive - No display lights
You need to get hold of a multi-meterand check the resistance of the pump, It should be 33ohms or close to it, the pump is part of the power circuit and the machine will appear dead if it has blown or is unplugged, If the machine was running without the earth wire to the pump connected and the pump had a fault/blockage there is a very good chance that it has blown the motor controller module. It requires the earth to provide a fault path to earth.
Mar 03, 2012 | Fisher Paykel Eco IWL16
My Fisher and Paykel IW810AU has stopped mid wash full of water and just beeps constantly and flashes message I need Service Fault 105. Have turned it on and off at the wall with no change. Please help.
Hi, the faults 105 is reported when the Display Module detects an error in the communications between the Display Module and the Motor Control Module.
The primary source of the problem is the Pump and you have to measure resistance of pump. If resistance is less than 33 ohms, replace pump.
May 16, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & paykel waterpump / Burnt smell clothing
ok, have you checked for power at the power point? if you have power to the machine and the display doesn't light up after you have turned the power point on then your control module is faulty. only the phase 5 models don't power up if the pump is faulty, your machine is a phase 2 with a blue control module. by the way, what part of the machine did you pull apart? i think your pump was faulty which made the control module faulty. check the pump for a burning smell. if it is burnt then i"m sure your module is too. please reply if you need more help to fix this problem.please turn off the power b4 you work on it, don"t want any accidents . good luck.
May 17, 2010 | Fisher and Paykel Fisher & Paykel Washer
Machine stops and beeps every second. Tried various points in cycle. pump appears to work then stops. Its a smart drive excellence 7.5 kg
it sounds like your out of balance switch is open circult.out of balance switch is located under control module.test for continuity on switch.make sure power is turned off first.if u have problems reply 4 more help
Mar 16, 2010 | Fisher and Paykel Washing Machines
Smart drive 5.5 washing machine lights show power on but no go
OK Problem located (without Diagnostics) , the problem was a faulty START/PAUSE button. I took the display board apart and fiddled with the button (whilst the power was UNPLUGGED) Starts almost every time, when it does`nt fiddle some more.
Dec 15, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel Smart Drive 601 - won't turn on
Hi I Have this washing machine (FISHER & PAYKEL Smart drive 601) hasn't been turn on for 4 yrs. now I'm going to use it coz my other machine broke.when I turn it on ,at starting it only distribute a little amount of water then it span the drum slowly.after about 5 mins. The lights of cold and hot keeps blinking and beeping.sounds like an error beeps .The power and all the light button still on except the cold and hot lights keeps blinking then just stop workin. can u help me what the problem could be.
Thanks
Jaf
Jan 17, 2008 | Washing Machines
Washing Machines Logo
107 people viewed this question
Top Washing Machines Experts
