Question about RIM BlackBerry Pearl 8100
Favorite Headphones are dying!
Okay, so I have these headphones, Sony MRD-Q33, I LOVE these headphones, they are great, but the left speaker won't work unless I position the jack that plugs into my ipod in a really weird way. I really want to fix these, suggestions?
-Thanks
  • Soapyilusion May 13, 2008
    Wow! Thanks for the quick respond! Thank you for the information, much appriciated!
    The chord is made up of this weird looking stuff. I don't really know how to explain it, but it's not just thin plastic. It's kind of rough. It looks like tiny fishing wire almost, witch is spinned into one sheild type thing. Can I still replace it with this stuff on it?
    Scholar:
  • 125 Answers
Most likely, the wire is broken at the plug. You will need to cut the wire back and replace the plug. Here is an example of what you need:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=CP-3502-ND
The plug is cheap, but you need some electronics skills and tools to do the work.
Posted on May 13, 2008
Left speaker only works when i push it to my ear??? please help!!!!
there is a way to fix the problem, buy some real headphones, if your price range is in the $300 range i would suggest the Fanny FW 3003 BLK, it has a dual layer 50mm driver with a built in amp with 4 way active noise cancelation for 20dB and bass boost up to 6dB.
May 13, 2012 | Monster Cable Products Monster Beats...
My JVC stereo headphone's wire is broken, cant i repair it by myself? please answer quickly because i can only hear from the right side of my headphone, and i love my music!!
If you take off the covering to reveal the speaker you can solder the connection back onto the left side of the headphones and that will fix it.
Mar 01, 2011 | JVC HA-NC250 Headphones
Only right side works
hello rrwunsch!
please check wiring first to find out if headphones broken or it is a connectivity problem. for that, if you connect with rca plugs - change right to left and vice versa. if still left headphone has no sound so the speaker is blown. hope it is only wiring problem.
regards
Feb 20, 2011 | Sony (MDRRF925RK) Consumer Wireless...
My sony 771 won t play any sound -- not the speakers because doesn't come through headphones either. Just cleaned the lens for CDs last night, then this problem developed. Can see the amp bars moving, so...
The lit indication ("amp bars") proves that the aduio signal is getting through the unit's circuitry @ least to that point; lack of sound @ the spkr & headphones indicates the amplifier portion of the circuitry is either inoperative or disconnected from the load (i.e., either the speakers, or the headphones). A common cause of this type of problem cropping up unexpectedly is the headphone jack itself; in most products of this type, the audio path from the amplifier output to the speaker connection runs through the headphone jack, so the the speakers may be "turned off" when the headphones' plug is inserted into the jack. If the unit's owner uses headphones regularly, the most common problem to be found with the jack is loose solder connections to the printed circuit board's traces from the jacks' lead(s); in units with this problem whose owner's irregularly use the headphones, it's more common to find oxidization of the electrical contacts within the jack itself.
Dec 10, 2009 | Sony Audio Players & Recorders
Sony MDR-W08 Left jack not working
jack or speaker,probably not worth fixing
Aug 10, 2009 | Sony MDR-W08L Consumer Headphones
Left speaker doesn't work
Koss has a no questions asked guarantee on some of the Pro-4 series, all you pay is shipping. Call the repair department to check.
Apr 22, 2009 | Koss PRO-4AA Consumer Headphones
Sony ericcson head phones
sony ericsson's should just have a 3.5 headphone jack insted of the dodgy plug they have now.
Jun 30, 2008 | Sony Ericsson HPM-70 Consumer Headphones
Midiland ir-hf1 right speaker broken
Hi evtan
The only thing I can suggest you do is to swap the right and left inputs to the transmitter base over whilst wearing the headphones. If the fault transfers to the other channel, then you have a faulty interconnect lead that needs to be replaced. If it stays with the same channel, then the headphones or the base staion will be faulty. Best bet then is to return it to the place you purchased it from and request a replacement unit,. Thanks for using FixYa....a FixYa rating is a great reward from you to me for helping out :) Cheers
regards
robotek
May 08, 2008 | MidiLand IRS 858 Consumer Headphones
How to Rewire Sony MDR-7506 headphones
Okay, cut and strip the cord. There should be two copper wires and (on Sony headphones, at least) a red and a green strand. On a new 1/8" jack, there should be three connections. The middle one is left, and is where the green one goes. The short one on the side is right, and is where the red one goes. The long bit is the common, and is where the copper one goes. Before you solder, however, remember which strand is which, because you have to sand or burn off the colored enamel. (Use a fine grain paper, or use a standard lighter or stick match- anything else might damage or melt the wire)
Nov 26, 2007 | Sony MDR-7506 Professional Headphones
RIM BlackBerry  Pearl  8100 Logo
54 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
