Question about Kenmore 75022 / 75024 / 75029 Gas Kitchen Range
How do you turn off the self cleaning feature on kenmore gas stove 790.75660?
  • Kenmore Master
  • 43,501 Answers
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Posted on Sep 07, 2010
What buttons do I turn on my 25 yr old Kenmore stove to use the cleaning feature
I think that range had a mechanical clock. On it, you have to set the start and stop time (and push or pull the knob(s) to activate it), close the lock lever, and set the temperature and function dial(s) to self-clean. Unfortunately, if your clock isn't working (which is a common failure on stoves this old), you won't be able to run the self-clean cycle.
Sep 14, 2014 | Kenmore Kitchen Ranges
Managemylife com
From the manual:
To turn the Cooktop Lockout Feature OFF:
1. Press and hold (_ until "CLO" appears (Figure 3). Continue holding
until a second beep sounds (after 3 seconds). I_1will disappear from
the display indicating the cooktop may be used normally (Figure 4).
Note: Starting a Self-Clean cycle will automatically turn ON the Cooktop
Lockout feature. The cooktop will remain locked until the Self-Clean cycle
has completed and the oven door has unlocked. If a power failure occurs
after the Cooktop Lockout has been activated, you must turn OFF the
Cooktop Lockout feature before being able to use the cooktop features
again.
Dec 14, 2013 | Stoves Kitchen Ranges
After self- cleaning my Kenmore Gas Range, I have not been able to get the 'Cooktop Lock' light turned off! So while I can use my oven for baking I can't turn the gas on the top of my stove! I have...
This may be a silly question but, did you just try turning off the circuit breaker for a couple minutes to see if it resets itself when you flip it back on?
Nov 21, 2010 | Kenmore Kitchen Ranges
I do not know how to use the self clean feature on my Kenmore Gas stove
Hi
Press the self-clean button to start the cycle. The panel becomes blank (---), then press the up arrow (^). The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning. After self cleaning is done wait for 15-20 minutes and open the door. Please post back for any further assistance. Hope this helps...
Daniel
Aug 28, 2010 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
I have a Kenmore Gas self cleaning stove. I have
Try power cycling the range by turning it off at the breaker. Wait 10 seconds and then reset the breaker. Reset the clock. Sounds like the computer in the range needs to be rebooted. Hope this works.
Jan 11, 2010 | Kenmore Kitchen Ranges
Kenmore oven door stuck closed
if you open the lid on your stove,you will probably be able to reset the switch manually (the latch).with the lid up its located toward the front behind the safety latch.(by no means attempt to force,bypass,or disable this switch)this is a safety feature designed to protect you from the high temps generated by the cleaning cycle.hope this helps.thanx for using fix-ya
Oct 08, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
How to use the self cleaning feature of kenmore gas range
I NEED THE BOOK ON HOW TO USE THE OVEN ON THE STOVE RANGE
Nov 18, 2007 | Kitchen Ranges
Cannot get oven unlocked after self cleaning
turn the circuit breaker off for several seconds
this should reset the system
Apr 02, 2007 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Self Cleaning Feature..Lost my manual
Kenmore posts manuals online at http://www.managemyhome.com/mmh/ .
You will need to register your email first and then search by model number.
Jan 15, 2007 | Kenmore 78773 Gas Kitchen Range
Kenmore 75022 / 75024 / 75029 Gas Kitchen Range Logo
109 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
