Question about Maytag Legacy MAV208DAWW Top Load Washer
La lavadora Maytag model mav3757aww tiene problema con la trasmision no le funciona
SOURCE: lavadora kenmore HE3 parpadea la luz de delay cuando faltaba 15 minutos para terminar el ciclo.
Ha tenido una problema similar con mi lavadora. Cuando las luzes parpadean antes de terminar el ciclo de exprimir, es porque hay un codigo de error - hay una charta de codigos en su instrucctiones que llegan con la machina - y el codigo en mi situation indica que hay un filtro bloqueado. Si es su problema tambien, el filtro esta en fruente, al derecho - si quita la cubierta a bajo de la puerta (es connectado con dos o tres tornillos), y el filtro esta en una chica caja de cuacho negro, connectada a las mangeras que quitan la agua sucia. Disconnecta las mangeras y connectiones, y quita tambien el filtro, y si hay mucha basura al dentro del filtro, aqui esta su problema. Si limpia el filtro, el machina serve muy bien. Buena suerte!
Posted on Jan 09, 2008
blueextc3221
  • 15935 Answers
SOURCE: la lavadora no funciona sale codigo Lr
The LR error on your non-spinning Maytag Neptune is usually, though not always, accompanied either by a burn spot or a blown fuse on the Motor Control Board.
Maytag upgraded the motor and motor control board because this problem was so prevalent. Big rash of these a few years back... and insludes replacement instructions with the kit.
The LR code means "locked rotor" - the control is not seeing the motor turning.
The image below contains the wiring diagram for this washer as you requested but there are some other things to consider.
Usually when the LR code is displayed the motor has stopped turning for some reason.
By definition the LR code means the control has tried to turn the motor but was unable to.
The error code can be caused by to large of load, to much soap/suds in the water or a problem with the spin bearing.
The cause of the LR message can be little problem like suds or a major problem like the spin bearing and sometimes it's difficult to pin down.
You don't mention in your question if the LR code occurs every load or once a week.
Try running a rinse and spin cycle empty and see if the washer completes the cycle.
The 2nd image contains the information on how to enter and run a diagnostic cycle which may help pin the source of the problem down.
This test completes all functions of the washer is a short time. It will fill, tumble, drain and spin all is a few minutes.
At the end of a successful test cycle a PA should display which means "Passed" and is what you want to see.
Image 1: http://media.fotki.com/1_p,sqwrrqkkqkstsftxgtqsskgwtqkq,vi/kkwrfdskkxkgbffwfww/1/1303472/5961857/image53872img-or.gif
Image 2:http://media.fotki.com/1_p,sqwtrsgdwsqtqsqxgtqsskgwtqkq,vi/kkwrfdskkxkktggsfsw/1/1303472/5961857/image53908img-or.gif
From another source...
"Installing replacement motor, motor control harness, and motor control circut board.
Pretty easy install. On a scale of 1 to 10 I'd call it a 3.5.
If you can use a screwdriver, a wrench, and have played with legos before, you can probably do this job.
It took me about 3 hours to do, but this was with inferior tools, and two smoke breaks included.
Minimum tool requirements: Adjustable-head cresent wrench (8 or smaller handle), phillips head screwdriver, utility knife.
Recommended tool equirements: Small ratchet with socket set, ratcheting screwdriver with phillips head and small socket attachments, brew.
The instructions are pretty clear.
Once you pull the front panel off, there are two braces at 45 degree angles on the lower corners of the washer.
The instructions don't ask you to, but I would remove the brace on the left to make life easier.
This gives your arm more room to work and makes it easier to pull the motor out the front.
They ask you to remove the wiring harness from the motor first and then pull the harness out with the control board.
My wrench was too big to get to the bolt to remove the harness from the motor.
All I did was cut the harness - since they supply a new one - then pull out the control board, then pull out the motor.
As far as getting the pulley off, slip it on and off at the large wheel, this is much easier than taking it off at the small motor drive shaft.
The only other thing of note is to make sure you look at the diagram for the conectors a few times before you snap it together.
There are a few ways you could hook it up wrong so pay attention. There should be no loose ends when you finish.
Also, I couldn't get the flange back on on the rear acess panel when closing it up, but it doesnt seem to serve muc purpose besides asthetics, so I tossed it.
The $200 for the parts and shipping was well worth it. I saved about $150-250 to do it myself...."
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question $#$Er
Posted on Oct 01, 2010
TheMobilian
  • 8220 Answers
SOURCE: mire adquiri una lavadora performar maytag y al
Might be a locked pump. Or the pump bearing is going out and is real stiff. Remove the belt and check that pump. If it is hard to turn then that is your problema. The pump can lock up and never leak on these. Seen it.
Posted on Jan 29, 2011
mc1bean
  • 3053 Answers
SOURCE: mi lavadora maytag atlantis no esprime bien deja
Hello, jose
I am trying to help you out here. Maybe this will help some? I am know on Fixya as the cleanup expert pro. Which means I spend my own personal time to seek out customers that maybe have not had there problem yet solved by the other fantastic great experts. I do this on my own for free. Think of me as a Specialized Trouble Shooter.
I have found out that it appears that lots of customers appreciate my efforts and help. So, I thought I would take some of my own personal time
to see if I can help you. Even though this Informational site may not have your exact model or brand, But this site will help you a lot. Here is the site link about everything you want to know about washing machines and possibly yours, from repair to trouble shooting it.
http://home.howstuffworks.com/how-to-repair-a-washing-machine.htm
Please if this helped you at all, if you can find the time and in your heart to rate my help and some kind words written would be appreciated for my free help, I would appreciate it. Like I said I just try to help, If anything this is good information for future problems. If you felt that my free help was a waist of time for you, I'm sorry. I do not get paid to help people on the site, I do it cause I like to help and maybe make a smile on someones face.
Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive, Appliance, and Electronics. Drop In anytime for my help.
http://beta.fixya.com/users/mc1bean
Thanks Mike
Posted on Nov 01, 2011
jaelduran
SOURCE: lavadora maytag mlg 2000 aww
hola por que cuando encho ropa a la lavora y le pongo el ciclo adecuado y a los 20 min o segundos me aparece un error f20 mi lavadora es maytag frontal ke puedo hacer????????
Posted on Dec 03, 2012
Desconecte una caja doble de dish y ahora uno de los televisores no funciona
Hola Jorge, disculpe la demora en responderle, quizas en este momento ya no necesite la respuesta para este problema pero me gustaria proveerle los detalles de todas maneras por si en futuro necesita ayuda esto le pueda ayudar. Este problema lo puede ocasionar distintas razones. El primer paso a tomar es: Por favor verifique que luces estan prendidas enfrente de su receptor. Bajo donde dice MODE la luz debe de estar en DUAL (2 cajitas) si esta en SINGLE, abra a puerta enfrente del receptor, oprima el boton que dice 'Mode' para poner el receptor en DUAL. Si este no es el proble may esto no lo arregla necesito que en el cuarto del televisor numero 2 (donde NO esta el receptor) usando el control que vino con la TV cuando la compro que ponga la Tv en el canal 60 si tiene una imagen necesito que agarre su control de DISH y en el control oprima el boton de SAT (el cual se encuentra en la parte de arriba a mano izquierda) una vez haga esto, trate cambiar canales. Si esto no funciona, otra vez con el control original de la Tv trate de poner la Tv en el canal 73. Si le sale una imagen, agarre el contriol de DISH, oprima SAT y trate de cambiar canales.
Si lo recien explicado no le funciona, valla a la TV 1 otra vez. Con el control 1 en mano Oprima Menu y una vez tenga el "Menu Principal" en la pantalla Oprima el numero 6, espero dos segundos y oprima el numero 1, espero otra vez dos segundos y oprima el numero 5. Este proceso lo lleva a una pantalla llamada 'Modulator Set Up' En esta pantalla donde dice 'TV 2 OUT' bajo 'Channel' que numero de canal tiene? 73 o 60? Basado en el numero valla al cuarto de TV 2 y usando el control que le pertenece a la Marca de TV (no el control de DISH) ponga la Tv en ese canal. Esto tambien debe de resolver el problema. Si necesita asistencia con su servicio de DISH sientase libre de contactarme a: kimberly.escobar@dish.com
Kimberly.Escobar
Social Media Representative
DISH L.L.C
Sep 22, 2013 | DISH Network 322 DTV Receiver
Buenas tardes me podrian ayudar con una impresora modelo 3100cn , me manda un mensaje 016-317 restart printer
Hola! Realmente es un dolor de cabeza este problema debido a que su sistema,el sistema operativo,siempre reconocera el mismo.Trate de apagar el printer,luego desconectelo de la PC y de la toma de corriente y espere unos 15-20 minutos.Luego vuelva conectar el printer y encianda la PC.
Si esto no le funciona desinstale el printer e instalelo otra vez.Es importante que la desinstalacion sea efectiva y que no quede rastros de los archivos del printer.Recomiendo RevoUnistaller para este proceso.
Si aun tiene problemas vuelva.
Suerte!
Jan 27, 2011 | Dell 5100cn Laser Printer
Problemas de avance esta muy burra
Revise su filtro de aire. Si tiene la lampara incendida en su tablero con el motor amarillo, is un sensor que causa sus problemas. Le recomendo un diagnostico aun. Le da la solusion al problema especifica al cual se puede solutionar rapido con cambio de la parte defectosa/gastada. Suerte.
Jan 10, 2011 | 1998 Ford Expedition
Ayudame con mi phone E71 pro Qwerty
Para que conpania es el telefono? Y cual es tu compania de telefono? Si te esta diciendo que solo puedes aser llamades de emergencia es porque no sirve con las SIM cards que le estas poniendo o no tiene senal.
www.usedcellphoneshop.com
May 24, 2010 | Nokia E71 Smartphone
Tengo una lavadora Whirlpool modelo LXR7144EQ1 que al exprimir la ropa no gira la tina si me pueden Ayudar de una Resolución de este problema
tengo una lavadora whirlpool, el problema es que no gira para exprimir, todo lo demás funciona, el motor recibe la señal para la función exprimir, sin embargo la transmisión no funciona.
Jan 09, 2010 | Whirlpool Washing Machines
Al encenderlo lo unico ue funciona es el ventilador, ue inmediatamente se apaga, no lee el disco duro ni el CD, la pantalla no presenta ninguna informacion sigue completamente negra
Asi parece un problema de placa base.
Para empezar quite la bateria y deconecte el adaptador para resetear la ordenadora.
Intenta remover disco duro, el unidad CD , la bateria, y si el ordenador tiene dos modulos de RAM quite un modulo y intente arrancar el portatil con esta configuracion minima de perifericos, con el adaptador enchufado.
Si el laptop no aranca asi, usted probabilmente tiene un problema de placa base.
Aug 14, 2009 | Toshiba Satellite M35X-S109 Notebook
Problemas de transmision automatica
hola que tal, tengo un saab 9000 1988 y tengo problemas con la transmicion aveses me hace los cambios y abeses no, si abansa para atras y para adelante pero me abienta los cambios cada que quiere,,, alguin tiene idea de que pueda ser?? nesesito ayuda ya estoy desesperado...
Aug 02, 2009 | 2001 Hyundai Accent
Problemas con la tramision automatica accord 1992. Entro D4 acelero y llega a una velocida y luego que acelerado y baja de velocida. en R a veces no quiere la reversa. ¿ que sucede una solucion po favor?.
D4 quiere decir que su transmision /transaxle tiene una problema. Lleve su auto a una tienda de partes como Autozone . halla le dan un scan gratis.Y le dicen que pueda ser la problema con su transmission.
Nov 17, 2008 | 1992 Honda Accord
Cuales son tus fuentes?
Primero que nada, muchas gracias por tu pregunta y por darme la oportunidad de despejar (o ampliar) una duda tuya.
Cuando en un modelo de hardware dice que es la Serie 5100, significa que hay mas "subseries" de modelos en esa misma base de hardware, digamos que la 5100 es la básica y la 5160 la tienes tu y tiene un puerto de USB cuando la 5120 no la tiene. Es un ejemplo.
Otro, en cuanto a laptops HP. La serie Pavilion dv8000 tiene varios modelos, la dv8360 tiene 512 MB de RAM mientras que la dv8600 tiene 2GB y cuenta con bluetooth.
Las placas de hardware son una base para crear mas modelos, le quitan o le aumentan algo, pero fisicamente son similares.
Esto contesta tu pregunta?
Recibe un cordial saludo desde Mexico.
- CoolDragon.
Sep 10, 2008 | HP Photosmart D5160 InkJet Printer
Maytag Legacy MAV208DAWW Top Load Washer Logo
48 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
