FixYa.com
Tags:
Fuji FinePix A330 Digital Camera
Fuji FinePix A330 (by 2 users)
posted by bondgirl1401 on May 13, 2008
thank you for your idea about how to get the camera to work. Just like the other person, my camera works fine until I push the button to take the picture then it turns itself off. You mentioned resetting the factory settings. I went to the menu and then 'set up" then "reset". but it didn't work...is there something else I need to do or try? Thank you for your time.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by LynnF, posted on Jun 06, 2008
I have the same problem with this camera and it's not the batteries, I know because I have tried numersous digital rechargable's and also just regular duracell AA's.
Best Solution
Helpful (85)
001opey
Rank:Apprentice Apprentice
Rating: 85%, 1 votes
try a new good batteries as i did ,work fine after went rechargeable type hold a lot more juice then cheap on
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jun 27, 2008
Not Rated (0)
althurman
Rating: 0%, 0 votes
had this exact problem for months... thought it was bad batteries, or bad buttons. Finally I took apart the camera and found out that the circuit board that has the button/switches mounted on it, shorts out when pressure is applied (pressing the buttons). The back of the circuit board makes contact with the chassis and shorts out, thus turning off the camera completely. My fix was to insert a small spacer (I used a small piece of plastic roughly 1/16 of an inch) in between the circuit board and the chassis preventing the contact between the two when you press the buttons.
Can you Help with these Digital Cameras problems?
Formatting what?
Hello, I have had the same card... Answer This...
usb cord not recognized...?
I have a fuji finepix A330, Ive... Answer This...
DITIGAL CAMERA
i turn my camera on and its... Answer This...
M512 MB card dosen't work
I recently purchased two new... Answer This...
software
need to load software on... Answer This...
Repair Service
Find Digital Camera Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
