Question about Gaggia Baby Espresso Machine
Gaggia Baby Twin won't power on. I press the power button and the lights on the panel flash but don't stay lit.
  • 2 more comments
  • dhillis2 Sep 06, 2010
    Switch is good per ohm meter.
    What else could it be?
    this is a baby TWIN and it does have electronics
  • dhillis2 Sep 07, 2010
    Is there anything else that it could be?
    Circuit board is around $ 100. if that is it I'll replace it but that's about my limit
    This is non responsive I can cut and paste myself
    Genius:
  • 1,035 Answers
The most common solution to this problem is to replace a fuse in your machine. This is a relatively simple process that only requires a few tools. Please call us to order fuse DM1040. When you are ready to install this fuse, follow these instructions:
1. Unplug your machine.
2. Remove the top panel on the machine as follows:
Gaggia Classic and Gaggia Coffee- Remove the 2 screws on the top.
Gaggia Carezza
a) Remove the single screw in the funnel that leads to the reservoir.
b) Remove the screw on top of the steam knob.
c) Remove the steam knob.
Gaggia Espresso- Remove the single long screw in the funnel that leads to the reservoir. Note: Be careful when removing the top of the Gaggia Espresso, do not force it or it may crack.
3. With the top of the machine removed, you can see the brew boiler. It is the large, silver component right over the brew group with all of the wires going to it.
4. Locate the Phillips-head screw on top of the boiler that is holding down a brass-colored clip. It should be on the left-hand side if you are facing the front of the machine.
5. Under the brass-colored clip, locate the semi-clear soft tube with wires coming out of both ends of it. The fuse link is in this soft tube.
6. Remove the Phillips-head screw and cut the 2 small plastic ties at either end of the rubber tube.
7. Slide the rubber tube toward the front of the machine. You may have to move the switches on the machine if they are in the way. You will also have to cut 2 or three plastic ties that hold the wires together so that you may move the rubber tube forward.
8. Leave the rubber tube on the wires so that you can slide it back over the new fuse.
9. Taking note of where each wire connects to the, cut the wires that lead to both sides of the fuse. Note: Cut it very close to the existing crimp connector so that the wires will not be overly shortened.
10. Strip the wires that you just cut back about ¼-inch. This will expose the metal part of the wires.
11. Before you install the new fuse, make sure that that the rubber tube will be long enough to cover the whole fuse and that it connects with at least ¼-inch to spare. Cut the fuse shorter if necessary.
12. Install the new fuse (it does not matter which way it faces) using the crimp connectors provided. The connectors are 2 different sizes. The small one is for the single wire from the front of the boiler and the larger connector is for the 2 wires coming from the back of the boiler.
13. Crimp the connectors onto the wire and fuse firmly, but not so firm as to cut the connector.
14. Gently tug on the fuse and the wire to make sure that there is no movement and the connection is secure.
15. Slide the rubber tube over the fuse. Note: Make sure that that all exposed wires and the fuse are inside of the rubber tube.
16. Install new wire zip ties on the ends of the fuse link and replace any that where cut when moving the rubber tube.
17. Replace the brass-colored clip and Phillips-head screw, making sure that the fat part of the fuse link is located under the clip.
18. Make sure that the fuse and rubber tube are securely held in place by the clip. Put the machine back together, plug it in and test it out.
Posted on Sep 07, 2010
  • Gaggia Master
  • 19,396 Answers
Hi.
The Baby Twin is definitively not the most reliable Gaggia model. This machine does not have much electronic, if the machine goes off immediately, then it is porbably a On/Off switch, or a wiring problem.
Ensure that problem is not the power connection by connecting power cord to a different outlet. If that does not fix the problem, then the machine must be disassembled. First test is done removing the power switch and reading Ohms at its contacts to see if the switch is staying closed.
The best thing to do from the user point of view is contacting Gaggia, which customer service is quite good, and asking a quote on repair. If I was in your shoes I would ask if a part exchange or upgrade toward a different model is possible.
See:Gaggia : Returns Policy
Posted on Sep 06, 2010
  • 2 more comments
  • Ginko
    Ginko Sep 06, 2010
    Check and eventually replace the fuse. If there is nothing there, then next step is following the lines from main and reading voltages while machine is off. The same job can be done reading Ohms with machine not connected
    For safety reasons I must mention that major repair any test needing power on must be done by trained personal.
    Here the complete diagram with part list. That should be a great help.
    Fuse is part 63.
    I do not think the problem is a short, all parts in this machines are 120V or 220V, a short will trip the circuit breaker, and machine won' restart at all.
    Either than that, there is no electronic. Problem is faulty switch, the fuse, wiring problem.
  • Ginko
    Ginko Sep 06, 2010
    If it has electronic, then it is control board or fuse. If it starts then goes off, then fuse is unlikely. Fuse stays open after breaking. I would replace fuse just in case, but if switch is OK, then problem is likely the control board. A defective component or a cold solder joint can easily cause the same symptoms. As said, the full testing is done reading volts going to control board. Problem is likely control board.
    Here the Baby Twin schematics.
  • Ginko
    Ginko Sep 07, 2010
    Re:Circuit board is around $ 100. if that is it I'll replace it but that's about my limit.
    For that reason the board must be tested. This board is also quite simple. Usually they can be fixed at component level.
    I see that my previous comment received a negative rating. I do not
    understand the reason. By the way on your request the question will be
    passed to a different expert. Sorry about your decision, I have spent some times on your espresso machine.
    Goodbye and good luck.
    Ginko.
  • Ginko
    Ginko Sep 21, 2010
    Thanks a lot. Go and replace the fuse.
    Goodbye.
  • 10,865 Answers
Hello. Most likely the brew head needs cleaning. Do this:
1. Ensure that the brew switch and steam knob are turned off and the machine is cold.
2. Unplug the machine.
3. Remove the reservoir, drip tray and drip pan and carefully lay the machine on its back.
4. Use a short Phillips-head screwdriver to remove the shower screen. It is fastened into the group head with a chrome Phillips-head screw (if you damage the shower screen and/or screw, we have replacements available and they are not too expensive).
5. Under the shower screen you will see the “Shower Holding Plate” that is held in place with 2 Allen screws. Remove the 2 Allen screws with a 5mm Allen wrench. Note: If the shower holding plate comes out after removing the 2 Allen screws, skip to step 6.
If the shower holding plate does not come out after removing the 2 Allen screws, use a large flat blade screwdriver to gently pry out the Shower Holding Plate. Note: Be careful not to damage the ridge that the shower screen fits up into. If it still does not come out, you may need to apply some descaler solution in the gaps with a turkey baster or something similar. Be careful not to break or scratch the holding plate.
6. Soak the shower holding plate and shower screen in descaler and use an old toothbrush or group brush to clean the shower screen. DO NOT push a pin through the holes in the screen. It can cause future clogs because it will enlarge the small holes.
7. Rinse the parts thoroughly.
8. Replace the Shower Holding Plate and Shower Screen.
9. Tip the unit back up and replace the drip pan, drip tray and water reservoir.
10. Fill the reservoir and plug the machine in and your machine should be ready to brew again.
All the panel lights glow after I reset (heated dry, normal, etc)?
Not sure what you mean by a temp restart only time lights should all be lit is if you placed the unit into diagnostic. Lets go one of two ways if you hit the normal wash button it lights along with heated dry you hit start button it flashes and won't go solid you have an open door switch, if everything is off and start light continues to flash you have a stuck key on the keypad.
Feb 15, 2014 | Whirlpool 24 in. DU1055XTPS Stainless...
The CLEAN light is flashing on my Kenmore QuietGuard3 , but it won't clean anything. It starts a cycle for a few minutes, stops and starts flashing clean again. Any suggestions?
You will have to reset the dishwasher. First try and turn off the mains power and back on after a short time. If the clean light flashing starts again then you go through the hard reset procedure.
press NORMAL WASH then HEATED DRY buttons one after the other until all the lights on the board lit up (3X's). The dishwasher will enter into a cycle; Press Cancel. This should stop the flashing.
If you are supplying dishwasher from hot water inlet then make sure the inlet water temperature stays within the recommended range of 145 deg F.
Apr 21, 2013 | Dishwashers
Error code e01
do the following steps: God bless you
To start test program, press and hold both POWER SCRUB PLUS and RINSE & HOLD program buttons, then turn unit on by pressing ON/OFF button. When program buttons are released, lights above them will flash. To end test program, press ON/OFF button.To check program indicator lights (POWER SCRUB PLUS, REGULAR WASH and RINSE & HOLD), press and hold each program button. When REGULAR WASH program button is pressed, CLEAN light also comes on.
To start testing, press both POWER SCRUB PLUS and RINSE & HOLD buttons a second time. When testing has ended and a fault was detected, the following indicator lights will be lit:
POWER SCRUB PLUS = Heater fault
REGULAR WASH = Water filling fault (over or under filling)
RINSE & HOLD = NTC (temperature sensor) fault ? note circulation motor stops shortly after it started during an NTC fault
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), REGULAR WASH light will come on and unit will continually fill and drain where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), RINSE & HOLD light will come on immediately and testing will end shortly after water has started circulating.
If more than one fault occurs, more than one light will be lit.
Jul 21, 2012 | Dishwashers
Power button stays depressed and does not start power menu. power is on, drum light is lit.
You will need to replace the control panel. The button is pressed in the down position and won't allow you to do anything else till this part is replaced.
Jun 12, 2011 | LG DLE2514 Electric Dryer
Hi i have a dish network universal remote cant seem to get the right code for tv
Turn ON the electronic device you want to program the remote to control.
Press the TV Mode button on the remote until the appropriate mode light is flashing.
Press the Power button. The mode light will stop flashing and stay lit.
Press the Up or Down arrow button to set the remote to the next code. The Down arrow button scans backward and the Up arrow button scans forward.
When the correct code is reached, the device (whether a TV, VCR, or other) will turn off.
Press the pound key button to store the code in the remote control memory. If the code is valid for your remote, the mode light will blink 3 times.
Turn the device back ON by pressing the Power button.
Press sat mode key once you power back on the tv to be able to operate the receiver box.
Try some other functions to make sure you have the correct code. Occasionally the Power button may work when others do not.
If the other buttons work you are finished.
If the other buttons do not work, repeat the previous steps. The scan will resume from the last code stored.
The mode light will flash rapidly when the scan has returned to the starting point and all codes have been tested for that mode. The remote control may not control some device models.
Jun 30, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Year old Bosch SHU33A0UC won't start. Lights on
Light's on mean you have power.
Initiate the self test program by doing the following -
ON/OFF button.
RINSE & HOLD = NTC (temperature sensor) fault – note circulation motor stops shortly after it started
during an NTC fault
where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150ºF) and water won’t stop
Let me know what you figure out. I can repair these boards most of the time.
Dec 18, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Gaggia baby espresso machine-Steam button is stuck
The only thing that comes to mind is that the machine is in steam/hot water mode. Unless you replace the switch and turn off the steam light so that it sends the water to the correct location. Also you might want to remove the shower screen and make sure it is clean.
Nov 26, 2009 | Gaggia Baby Espresso Machine
I need the insignia remote control code.
there are several and here they are 1181,1180,1175,1171,0103,0189,0217,0135,0133,0116,0167,1148,0456,0029,0905,1406,1407,1408
try each one seperate
press and hold the setup button until the red light stays on then if it is a universal remote press the desired mode button (example t.v.) the light should now blink and then stay on enter a 4digit code .
note:if the code is valid the light will turn off if the code is invalid then the light will flash.
now try it with your device on by pressing the channel up and down button.
note: if the remote does not control all the functions try another code.
If none of the the codes work try following these steps:
1.manually turn on the t.v.
2.press and hold the setup button.
3. press and release the tv button the light will blink once and then stay on.
4.press the channel button repeatedly up to 300 times until the device changes channels. the light will blink and then stay lit.
5. press and release the mute button to store the code the light will go off.
Aug 29, 2009 | Insignia 42" LCD Flat-Panel HDTV
Gaggia Baby Espresso Machine Logo
1,025 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
