Question about Pentax Optio S5i Digital Camera
Every time I change the battery in my pentax s5i the time and date revert to' as new' and I have to reset date and time. I have been using the camera for 6 years without this problem. Any ideas?
    Guru:
  • 1,705 Answers
It may be a circuit designed to maintain date/time settings when the battery is removed that has failed.
Although a very good camera, I would imagine the cost of repair would be greater than the value of the camera.
A couple of thoughts though, if you are making an immediate swap with a charged spare battery, then there's a fault, you may find a firmware upgrade on the Pentax website which may help.
If there is a delay in replacing the battery, then having a spare, fully charged battery available at the time, may circumvent the problem.
Posted on Sep 06, 2010
Testimonial: "Thanks. I'll have a look on the website. This is such a great little camera. I actually have another that I bought on ebay in case this one ever fails"
Can I use 4gb memory card in pentax optio s5i support
No. The S5i works with SD cards, which max out at 2GB. It will not work with higher-capacity SDHC cards.
May 06, 2014 | Pentax Optio S5i Digital Camera
How to turn on date stamp on pentax option S5i?
The camera won't deface your photos by scrawling a string of numbers on them. Depending on the program and printer you use to print your photos, you can print the date on the image, in the margins, or on the back. Please refer to the documentation for the program.
If you're printing directly from the camera, you can turn on the date stamp by checking the "Date" box as described in the "Setting the Printing Service" section in the camera manual (page106) in my copy.
Jan 24, 2011 | Pentax Optio S5i Digital Camera
Date has reverted back to2006
Press Menu and select the Setting Menu. Navigate down to "Date Adjust" and press Right-arrow, and the Date Adjust screen will appear. Navigate around and change the settings. Press OK when done.
If you've misplaced your manual, you can download one from the manufacturer's web site at http://www.pentaximaging.com
Feb 03, 2010 | Pentax Optio M20 Digital Camera
Can a pentax optio S5i support a 8GB memory card? Do I need to download a driver to support an 8GB memory card/
No the Pentax Optio S5i does not support an 8gb memory card.
8gb would be an SDHD card, the S5i came out before SDHD so it does not support them.
Standard Secure Digital Cards come up to 4GB in size so you could use one of these. The highest standard card I have is 2gb and that is fine in mine.
My S5i locks up if you put an SDHD card in.
The only firmware update that Pentax supply does not effect this, SDHD needs different hardware.
Jan 02, 2010 | Pentax Optio S5i Digital Camera
Can't change date or time on my new Pentax K2000
Date/time are set at "first use" or through the tools menu.
Remove the batteries.  Leave the camera overnight, this may be enough to lose the current settings and allow setting new date/time.
Press Menu button.
Press right arrow on the 4-way controller to get the Tools (spanner) highlighted.
Press down arrow to get to date (or time).
Press right arrow
Now set to your preferred format.
If this does not work, try changing another item in the Tools menu.  If that change is not accepted, then it's into the dealer.
Jun 21, 2009 | Pentax K200D 10 Megapixel Digital SLR...
Pentax S5i
I have lost my cd for my optio s5i pentax camera and have a new laptop how can I get another cd or download software so I can transfer photos onto my laptop
Jan 28, 2008 | Pentax Optio S5i Digital Camera
Pentax optio s5i
Try taking out the batteries and re-inserting them after some time. If it doesnot work, most probably it is an hardware issue. Take it to the service center.
Sep 24, 2007 | Pentax Optio S5i Digital Camera
S5i won't turn on in Capture mode
Hi Aunty Edna. I had exactly the same problem with my S5I 4 weeks ago. Went out and bought another camera then decided had nothing to lose by doing heart segury on S5I. Found it has a watch battery soldered to board under memmory card holder which was flat. I replaced that with a similar battery and it fixed the problem. Its not an easy job but if you know someone good with there hands it would take about an hour.Hope this helps. Regards Andy
Dec 15, 2006 | Pentax Optio S5i Digital Camera
S5i date problem
It looks like Pentax has your fix! Have a look at the following: http://www.pentaximaging.com/customer_care/show_firmware?firmId=1010
Sep 08, 2005 | Pentax Optio S5i Digital Camera
Pentax Optio S5i Digital Camera Logo
187 people viewed this question
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
