Question about Neff 24 in. S5443X2 Built-in Dishwasher
My Neff S5443X2 built in dishwasher is not washing my dishes properly. I don't think enough water in getting into the machine as the dishwasher tablet is whole at the end out the wash cycle usually stuck to something. What should I do? Do I need a part replacing by a plumber or can I fix it?
I left the dishwasher off all night then prest the reset button and it worked
Posted on Sep 09, 2010
Can I plumb a s5443 into a Hot water supply.
Thats the only line you need to install dishwasher,you need the hot line and not a cold,the hot is for the heat that is needed to thoroughly clean the dishes.
Oct 16, 2012 | Neff 24 in. S5443X2 Built-in Dishwasher
Will Neff dishwashers work without salts and liquid?
While salts are not required, if you don't have water it won't clean your plates very good, and will also burn our your pumps.
Jul 20, 2011 | Neff 24 in. S5443X2 Built-in Dishwasher
I have a white powdery substance left on my dishes and they are not cleaning properly
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101
Oct 11, 2010 | Neff 24 in. S5443X2 Built-in Dishwasher
Hard water area, all dishes streaks and inside machine cloudy white. I think salt is blocked, not topping up as much as I had to in the past
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Sep 13, 2010 | Neff 24 in. S5443X2 Built-in Dishwasher
I have a Neff Dishwasher S5443X2 and the dishwasher tablets are not dissolving. The tablet door is open when the machine finishes but most of the tablet remains. We tried using detergent but still the same...
Either:
  1. the water does not get into the dishwasher open the dishwasher 3-4 times during cycle, you should see some water at least once, if not - check water valve, water level float and water pressure.
  2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
  3. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
Jun 27, 2010 | Neff 24 in. S5443X2 Built-in Dishwasher
The dishwasher is not cleaning properly, glasses look like they have a film on them, plates also do not look clean & the dishwasher has a foul smell.. like rotting food in it.. we use the top quality...
Check the main drain system connected to the dish washer hose pipe. Clean the junction if clogged. This smell might orginate from the pipe.
Check incoming water quality. If hard water is noticed, use softener attachments to the inlet.
Fill dish washer salt in the dispenser. Refer user guide. The salt will help softening the water to certain extent. Finally check whether rinse aid dispenser filled with the rinse aid liquid.
Jun 01, 2010 | Neff 24 in. S5443X2 Built-in Dishwasher
Dishwasher not washing very well
usual reason is that the arms are not rotating freely - they only turn by water jetting out of angled jets. blockages are not always obvious as blockage material tends to go out of sight when water pressure off. favourite culprits are rice and sweet corn
Mar 09, 2008 | Neff 24 in. S5443X2 Built-in Dishwasher
Neff dishwasher will not empty
Could be a kinked hose, diverter solenoid is jammed or burnt out. If the dishes are clean and the pump is working...then look at the above. If the spray isn't happening, the pump could be a problem. They are usually direct drive and you'll note that the motor isn't working.
Dec 27, 2007 | Neff 24 in. S5443X2 Built-in Dishwasher
Contents covered in salt
Maybe you are not getting enough circulation fro the water circuators. Check for any blockage in the rotating arms where the water comes out. Also the water pump may be clogged or in need of replacement.
Dec 16, 2007 | Neff 24 in. S5443X2 Built-in Dishwasher
Neff 24 in. S5443X2 Built-in Dishwasher Logo
474 people viewed this question
Top Neff Dishwashers Experts
Samohthda
Level 1 Expert
shaun taylor
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
